TRD Pro vs Off road with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by kane22, Jan 15, 2024.
  1. Jan 29, 2024 at 7:34 AM
    #181
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    djwantke likes this.
  2. Jan 29, 2024 at 7:45 AM
    #182
    The most typical size people go to is 285/70/17, which usually measures close to 32.7" tall × 11.2" wide. It varies by manufacturer and style, but that's what it calculates out to.
  3. Jan 29, 2024 at 8:04 AM
    #183
    Same story for me
    ToyotFan likes this.
  4. Jan 29, 2024 at 8:54 AM
    #184
    COL4Runner
    COL4Runner New Member
    We just went through the PRO/TRD ORP decision 2 weeks ago and ended up with a 23' TRD ORP KDSS. I actually went to buy a 24' TRD ORP non-KDSS but my dealer who I've worked with for a LONG time gave me a deal on 23' with 1400 miles by taking $8k off MSRP($51k). This is our 5th 4Runner but 1st KDSS and I really like the onroad manners of it, especially in the mountains on I70. As for the wheels my wife likes the PRO's so as some of you have said I downgraded but it's a looks thing for her and we only upgraded to 275/70/17's so no issue on 7 in wide wheels.
    One thing I missed in looking at both of these 4Runners was the auto lights, we have auto high's but why would Toyota not put auto lights on every 4Runner. Oh well...
    Slopemaster, ToyotFan and djwantke like this.
  5. Jan 29, 2024 at 9:49 AM
    #185
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Prolly LT275/70/R17
    search it, I've seen many of threads recently with similar question
    Goodluck
  6. Jan 29, 2024 at 9:53 AM
    #186
    285/70/R17 (just under 33" diameter)
    285/75/R17 are actually much larger diameter, almost 34" (75 is the diameter)
    And Duratrac line up is nice, good in rain and snow too, I almost bought them in '21
  7. Jan 29, 2024 at 9:59 AM
    #187
    Congrats! Great choice on that ORP. And even greater choice listening to your wife on the wheels :p
    As for the auto headlights, you gotta check out this thread if you haven't already (it is full of info and answers on this subject, plus a lot of heated and hilarious debate)
    https://www.4runners.com/threads/no-auto-lights.33762/
    COL4Runner[QUOTED] likes this.
  8. Jan 29, 2024 at 10:06 AM
    #188
    COL4Runner
    Kinda ridiculous that it doesn't have auto lights, my sons $32k Bronco and our 22' Tacoma TRD ORP have them!
    djwantke[QUOTED] likes this.
  9. Jan 29, 2024 at 10:08 AM
    #189
  10. Jan 29, 2024 at 10:13 AM
    #190
    COL4Runner
  11. Jan 29, 2024 at 10:40 AM
    #191
    285/70/R17 fan boy coming in hot to prove that wrong :p:p:p
    mickey-thompson-baja-mtz-p3
    mickey-thompson-baja-legend-mtz
    pro-comp-xtreme-mt2
    mickey-thompson-baja-boss-m-t
    toyo-tire-m-55
    nitto-trail-grappler-m-t
    yokohama-geolandar-x-at
    cooper-discoverer-stt-pro
    goodyear-wrangler-duratrac
    mickey-thompson-baja-legend-exp
    cooper-discoverer-rugged-trek
    falken-wildpeak-r-t
    goodyear-wrangler-mt-r
    goodyear-wrangler-workhorse-at
    falken-wildpeak-a-t4w
    goodyear-wrangler-ultraterrain-at
    milestar-patagonia-m-t-02
    milestar-patagonia-x-t
    goodyear-wrangler-trailrunner-at
    Winter tires?
    cooper-discoverer-snow-claw-studdable
    :drunk:
    Thatbassguy and djwantke[QUOTED] like this.
  12. Jan 29, 2024 at 10:46 AM
    #192
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Many manufacturers are just over 33" but some are under. Cooper Discoverer's are 32.76" in both P and LT.
  13. Jan 29, 2024 at 10:50 AM
    #193
    just giving djwantke a hard time :p
  14. Jan 29, 2024 at 10:53 AM
    #194
    Well smack my ass and call me Susan!
    Butter my back and call me a biscuit
    Thatbassguy and kmeeg[QUOTED] like this.
  15. Jan 29, 2024 at 10:55 AM
    #195
    LoL :p
    :cheers:
  16. Jan 29, 2024 at 11:04 AM
    #196
    @kmeeg
    holy, I may have been wrong about my own tire specs for a while. They're true 33's. And I thought they were 55lbs, might be 59/lbs.
    That makes each wheel :eek: 88lbs
    kmeeg likes this.
  17. Jan 29, 2024 at 11:07 AM
    #197
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Getting my butt Trimmed and strengthened
  18. Jan 29, 2024 at 11:09 AM
    #198
    He's doin it!
    Yotaholic likes this.
  19. Jan 29, 2024 at 11:11 AM
    #199
    Yotaholic
    Olympia, WA
    Body shop friends, wink wink
  20. Jan 29, 2024 at 4:05 PM
    #200
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Since we’re on the topic of correcting @djwantke , 75 is technically not the diameter but the aspect ratio of the width of the tire (here 285 mm) to determine the height of the side wall. In other words 285/75 have a sidewall height of 213.75 mm (285x0.75) and 285/70 have a sidewall height of 199.5 mm (285x0.70) which is the only difference that makes the latter shorter (assuming same wheel diameter of 17in) at roughly 33in per @kmeeg
    djwantke[QUOTED] and Yotaholic like this.
  21. Jan 29, 2024 at 4:58 PM
    #201
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
  22. Jan 29, 2024 at 5:12 PM
    #202
    Oh god you're right, what the hell was I writing. 70 or 75 clearly pertains to the side wall
    semprenissart[QUOTED] likes this.
  23. Jan 29, 2024 at 5:15 PM
    #203
    You should tell him that tier-one shade tree mechanics flatten the cardboard first before lying in it.
  24. Jan 29, 2024 at 5:42 PM
    #204
    Yotaholic
    Olympia, WA
    We needed it :D
    semprenissart and djwantke like this.
  25. Jan 29, 2024 at 5:52 PM
    #205
    Yotaholic
    Olympia, WA
    4Runner "TRD Pro"
  26. Jan 29, 2024 at 6:20 PM
    #206
    @semprenissart
    Borracho Loco and semprenissart like this.
  27. Jan 29, 2024 at 8:16 PM
    #207
    Pro rims are not a downgrade. Toyota wouldn’t have designed them for the Pro if they sucked.
    BC Hunter likes this.
  28. Jan 29, 2024 at 8:58 PM
    #208
    True, you're not wrong
    Folks aren't saying they suck. They're saying they are 1/2" narrower, which larger tire specs don't list as safe for use. They're saying they don't come with valve stem protection. Making them an inferior choice for larger tires. But, many ppl run 285s on 7" wheels and claim not to have probs
  29. Jan 29, 2024 at 9:03 PM
    #209
    Just chatted with a chick on FB comments today on the BC 5th Gen 4Runner group. Had a dude plastidip her OR wheels to look like SCS F5's. I mean heck I think they did a good job looks good, from someone who ran same OR wheels for 5 yrs.
  30. Jan 29, 2024 at 9:04 PM
    #210
    Yotaholic
    Olympia, WA
    I have scratched them real bad. I might do this in near future
