TRD Pro vs Off road with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by kane22, Jan 15, 2024.
  1. Jan 27, 2024 at 8:34 PM
    #151
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Not sufficient in the real world when you hit rocks. Keep your A-Trac active folks.
  2. Jan 27, 2024 at 8:36 PM
    #152
    Yotaholic
    Olympia, WA
    If things go well, let us posted. I would want to get rid of the rear sway bar as well.
  3. Jan 28, 2024 at 8:01 AM
    #153
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    My ‘23 ORP stickered at $52k and when I bought it in October the dealer immediately discounted it to $46k without me having to haggle any. It has KDSS as well.
    I was at the PA Auto Show yesterday and Toyota had a burnt orange Pro with a sticker at just shy of $58k.
    The only features of the PRO I’d want are the wheels which I can buy now, the dual climate control, and cooled seats. Not worth the difference though in my opinion.
    PrettyGoodSam, djwantke and Yotaholic like this.
  4. Jan 28, 2024 at 9:40 AM
    #154
    Not sure why you want to downgrade to TRD Pro wheels when you already have TRD ORP wheels?
  5. Jan 28, 2024 at 9:54 AM
    #155
    Exactly!
    I'd never get PRO wheels on purpose. I'd go aftermarket or keep the OR wheels.
  6. Jan 28, 2024 at 10:19 AM
    #156
    Yotaholic
    Olympia, WA
    They carry the 34s perfectly fine. One can spend the $1,000 on something useful off-road.
  7. Jan 28, 2024 at 10:20 AM
    #157
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    I like the ORP wheels. I just like the darker wheels a lot. My wife’s vehicle is an Acadia AT4 and it has the black wheels on it and looks sharp.
  8. Jan 28, 2024 at 10:21 AM
    #158
    Yotaholic
    Olympia, WA
    Paint them black lol
  9. Jan 28, 2024 at 10:25 AM
    #159
    Yotaholic
    Olympia, WA
  10. Jan 28, 2024 at 10:44 AM
    #160
    TRD Pro wheels do not meet the requirements to run bigger tires like TRD ORP wheels.
    TRD Pro wheels do not have valve stem protection. Why I say TRD Pro wheels a downgrade from TRD ORP wheels.
  11. Jan 28, 2024 at 10:56 AM
    #161
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey @ToyotFan
    That makes sense. I wanted black wheels myself. I spent quite a bit on 9" wide aftermarket wheels of my dreams in '21, completely black + black PROCOMP lugs.
    This was before I knew about 4Rs. com, and before I knew the value and demand for ORP wheels especially near mint condition. Still kicking myself for selling them too cheap on FB marketplace. They sold in seconds..
    Good luck
    ToyotFan[QUOTED] likes this.
  12. Jan 28, 2024 at 12:06 PM
    #162
    Yotaholic
    Olympia, WA
    Watch this and decide if you want KDSS or Pro. Not mad flex to drive over boulders or something, but enough to keep you stable and comfortable on this kind of terrain. Speed way below the limit of KDSS which is 12 mph. And unlike Jeep's swaybar, KDSS works in 2WD too.
    You will see mostly trail queen Jeeps here. I turned back from a crazy trail.
    https://youtu.be/jljxI8MU3vc?feature=shared
    PrettyGoodSam likes this.
  13. Jan 28, 2024 at 1:23 PM
    #163
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    The pro has heated seats only. Ventilated seats are on the limited
  14. Jan 28, 2024 at 3:57 PM
    #164
    Forget the heat and cooling, give me the position memory seats. I'm so sick of my wife and I going back and fourth adjusting drivers seat!
  15. Jan 28, 2024 at 4:59 PM
    #165
    kane22
    kane22 [OP] New Member
    $6K off would be a good deal. That would make me lean ORP for sure, $2600 is the best I've found. The Pro you saw at the auto show is the one I'm looking at. They had to hold it till after the show. Guess I'll find out tomorrow if it's still available or not.
  16. Jan 28, 2024 at 5:18 PM
    #166
    semprenissart
    semprenissart Mèfi
    I hear you! My wife doesn’t often drive my truck but on long distances I’ll have her drive so I can rest. Theres such a big difference between her seat position and mine that it’s a whole ordeal for me to set it back. I really don’t understand why none of the premium trims other than the limited have this feature (SR5P, ORP, and Pro).
    My wife has it on her car and it’s so effortless to switch seats.
    djwantke[QUOTED] likes this.
  17. Jan 28, 2024 at 5:28 PM
    #167
    IVRunner
    IVRunner New Member
    2023 ORP Lunar Rock
    Sounds interesting. Got pics?
  18. Jan 28, 2024 at 6:19 PM
    #168
    That's what I did, but heck now I'd do SR5 Premium.
    But I think your right.
    It's always gunna be circumstantial for folks tho. There's ppl who don't have the time and interest to research, purchase and deal with installation of add on's. Maybe no garage. PRO is alluring, the FOX susp. is real smooth. I heard new ones can have center console safe and front/rear dash cams. They have the better sound system, many of us have modified our ORP audio.
    Yotaholic[QUOTED] likes this.
  19. Jan 28, 2024 at 7:27 PM
    #169
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    Good luck! That one is a very sharp looking vehicle for sure. Which dealer was displaying it?
  20. Jan 28, 2024 at 8:31 PM
    #170
    Here in Denver CO there's a sticker saying $4000 off MSRP. Didn't check for details. Just took this pic.
    Yotaholic likes this.
  21. Jan 28, 2024 at 8:34 PM
    #171
    Is that the "Sport" on the left?
  22. Jan 28, 2024 at 8:37 PM
    #172
    Yes, I believe so. Didn't take anymore pics of that or check what accessories it has.
  23. Jan 29, 2024 at 12:01 AM
    #173
    Yotaholic
    Olympia, WA
    Awful approach angle. The Limit makes sense, but Sport?
    kmeeg[QUOTED] likes this.
  24. Jan 29, 2024 at 3:26 AM
    #174
    SolarOctane
    SolarOctane New Member
    Long Island, NY
    2023 4Runner TRD Pro
    They do build vehicles for the 90% of owners who spend 95+% of their time on the road. Even buyers of 4WD body on frame vehicles mostly fall into that same category. It’s great that many here use their vehicles in places that require serious off road angles, articulation, clearance, etc. but that’s a very, very small portion of owners. Hence why Toyota offers a trim like the Sport, for those not wanting or willing to pay for a Limited, and not planning to do any serious off roading. There are other use cases besides yours.
  25. Jan 29, 2024 at 5:43 AM
    #175
    If people are buying Lexus GX460 with Highlander like ground clearance, no standard full fuel tank skid, etc Toyota would have thought why not have a cheaper trim with onroad manners. Not every one buys for off pavement needs. I do see few TRD Sports in the dealership lot, so maybe there's a demand.
  26. Jan 29, 2024 at 6:31 AM
    #176
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    For the ORP wheels, what is the largest tire you can put on them without rubbing and without needing to modify the wheel wells?
  27. Jan 29, 2024 at 6:55 AM
    #177
    It's not a matter of rubbing, although the PRO wheels' offset is more likely to rub with a given tire than the other wheels.
    The biggest issue is that they're only 7" wide, which is below spec for most 285's. A lot of people do run 285's on them, though, so you're probably not going to have issues. If planning to go even wider than 285, I'd definitely avoid them.
  28. Jan 29, 2024 at 7:08 AM
    #178
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    I watched a video this morning on YouTube of a guy who painted his ORP wheels matte black with black center cap and red Toyota emblem and I really like how that looked. Would the 285's work just fine on the ORP wheels? Would I need to do anything to account for the speedometer if I go with a larger tire?
  29. Jan 29, 2024 at 7:25 AM
    #179
    285's are generally rated for 7.5-9.5" IIRC, so you'd be fine. The speedometer reads around 2-3% high with stock tires, and 285/70/17's usually cause it to read more accurately. Mine matches GPS with 285's.
  30. Jan 29, 2024 at 7:33 AM
    #180
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    Dumb question, what's the exact size for the 285 tires? 285/?/R17 ?
    I've been looking at Goodyear Duratrac RT tires.
