TRD Pro vs Off road with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by kane22, Jan 15, 2024.
  1. Jan 22, 2024 at 7:49 AM
    #91
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Take a chill pill little man. I was unaware that KDSS was option for the US market. All Off Road's here in Canada come with it and the sunroof and 360 camera.
  2. Jan 22, 2024 at 8:35 AM
    #92
    SolarOctane
    SolarOctane New Member
    Long Island, NY
    2023 4Runner TRD Pro
    Wow, good insult there!! Very impressive.
    So you were unaware of those options differences, but you commented about the sunroof being a $630 option... got it... you're unaware of even what you already said yourself, much less anything useful to add to the discussion.
    digitalvex likes this.
  3. Jan 22, 2024 at 8:46 AM
    #93
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    I found it out after the fact. My point still stands regarding a large price difference between both models regardless of the configuration.
  4. Jan 22, 2024 at 9:30 AM
    #94
    SolarOctane
    Long Island, NY
    It's not the original $12k difference you stated, or the $8k difference you updated yourself to, but rather just under a $5k difference as the ORP is $51,755 with KDSS & Moonroof. That still leaves the ORP in the U.S.A. lacking the following which have cost & value, whether you personally want them or not:
    • Auto headlights
    • Automatic climate control
    • TRD Front skid plate
    • TRD Roof rack
    • Fox Shocks
    • Mutli-terrain monitor
    • JBL sound system
    • Remote start
    • All terrain tires
    • All weather floor liners
    Discounts & negotiation are highly variable and regional so I leave those out.
    Newfy, semprenissart and Mtnmonkey like this.
  5. Jan 22, 2024 at 11:06 AM
    #95
    PrettyGoodSam
    PrettyGoodSam New Member
    Philadelphia
    2012 4Runner Trail
    im interested in this comparison. i am tossing around the idea of trading up from my 2012 to new. lots of good info here.
    djwantke likes this.
  6. Jan 22, 2024 at 11:10 AM
    #96
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I have not heard of the PRO Fox being unreliable no.
    semprenissart likes this.
  7. Jan 22, 2024 at 12:34 PM
    #97
    If you go to Toyota.com, you can compare models, and decide if the price difference is worth it to you.
  8. Jan 22, 2024 at 12:56 PM
    #98
    PrettyGoodSam
    Philadelphia
    2012 4Runner Trail
    ive done that and that is also very helpful!
    good to hear from people that have done specific mods with and without kdss, etc. ill take all the info can get haha
  9. Jan 22, 2024 at 3:40 PM
    #99
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Yes they do mine included with all the high tech stuff. Not saying all the high tech is good. The LDA drives me nuts I shut it off. Because Canada is a much smaller market Toyota only allocates fully optioned 4Runners here. In the USA options tend to vary state/region with many differences. Living in the "North" I look south and say "What's a 2wd 4Runner" let alone Tacoma or Tundra.
  10. Jan 22, 2024 at 4:13 PM
    #100
    @CalcityRenegade
    Because KDSS isn't your springs and struts.
    It's a hydraulic, beefier sway bar system.
    Sounds like you could benefit from a little bit more time researching before yapping - like "little man" @SolarOctane has:p
  11. Jan 22, 2024 at 4:18 PM
    #101
    Great consolidated list there of PRO differences.
    Very helpful.
    You're right I don't personally want a lot of them turds lol but half of those items are quite valuable indeed
  12. Jan 22, 2024 at 4:25 PM
    #102
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    It is the road manners of the KDSS that impressed most buyers including me. Some extra offroad flex is just a bonus, I would buy KDSS without that. Infact, I found out later that KDSS articulates more offroad. The dumb salesman was just saying it helped with cornering and body roll.
    We all know that the most flex comes out totally getting rid of the swaybar. And if absolute craziness offroad is the goal, then the answer is Jeep.
    Thatbassguy and djwantke like this.
  13. Jan 22, 2024 at 4:28 PM
    #103
    Yotaholic
    Olympia, WA
    KDSS is super obvious onroad, don't believe me, drive one. Offroad it is 50/50 whether one notices any difference or not.
  14. Jan 22, 2024 at 4:33 PM
    #104
    Steve Berman
    Steve Berman New Member
    Yotaholic likes this.
  15. Jan 22, 2024 at 4:33 PM
    #105
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    i haven’t heard of it either.
    if that helps, I have just a little over 20k miles and I’ve been abusing my fox shocks with high speed desert fun and so far so good. If they do fail, I hope it’ll be before the warranty expires
    djwantke[QUOTED] likes this.
  16. Jan 22, 2024 at 4:37 PM
    #106
    freak4life
    freak4life New Member
    Rich
    Cañon City Co
    2018 off-road
    Agreed about those two dealers. My wife bought her 21 Rav-4 at Surprise Toyota, no hassles, salesmen are not on commission and no mark up over MSRP, why go anywhere else?
    Also avoid Bell road Toyota.
  17. Jan 22, 2024 at 4:38 PM
    #107
    Yotaholic
    Olympia, WA
    It is legit both onroad and offroad. Here is offroad. And this is baby KDSS, the serious KDSS on 200 series flexes way more
  18. Jan 22, 2024 at 4:45 PM
    #108
    Yotaholic
    Olympia, WA
    Unless you are focusing super closely, you're not going to feel the kdss on our truck off-road. It's not like a solid axle is doing its thing underneath you, you don't get that kind of feeling
  19. Jan 22, 2024 at 4:48 PM
    #109
    Yotaholic
    Olympia, WA
    I got straight out of my 2016 Hemi Grand Cherokee and started driving this truck. The reason I'm alive here without any injuries, it's because KDSS works onroad :D
  20. Jan 22, 2024 at 4:52 PM
    #110
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Keep in mind that if the KDSS system leaks, it's an expensive fix. I'm going through this right now with my 2021 4Runner. The front KDSS piston is leaking and it is being covered under warranty (caught it before it expired by a month and half). But so far I have been waiting a month and half for the dealer to get the special tool in to pressurize the system once they replace the piston. Dealers are not required to have this tool so it gets shipped from dealer to dealer as it's needed so it can take months (like in my case) to get the system repaired.
    djwantke, Mtnmonkey, WilVis and 2 others like this.
  21. Jan 22, 2024 at 11:33 PM
    #111
    TheGreekFreak
    TheGreekFreak New Member
    Can’t go wrong with either but if you plan to leave it alone, I’d go with the Pro. I wanted all the Pro bits, the special color for my model year, and had zero desire to tinker with aftermarket suspension.
    Also didn’t want the added complication of KDSS. For how I drive the truck, stock for stock, the ride comfort of the Fox shocks outweighed any benefit of KDSS.
    I knew I wanted a Pro when I’d be in the market, love everything about it. If it’s anywhere near as reliable as my 3rd gen, I plan to maintain/keep it for decades so price difference wasn’t as big a concern.
  22. Jan 23, 2024 at 3:23 AM
    #112
    SolarOctane
    Long Island, NY
    I think that’s an important point about KDSS. How exactly are people driving their 4Runner that body roll is such a significant factor to them? It’s an almost 5000lb. Body on frame SUV with high ground clearance. Does it really need to be driven like it’s a sports car? I slow down a bit more for say a tight off ramp, but other than that body roll is not something I notice or think about in my Pro. I also have owned many sports sedans, hot hatches and sports cars, and done HPDE & track days. I think maybe KDSS helps more for those who don’t understand or manage mass and weight transfer in their vehicle with their normal driving technique.
    KDSS can help balance front to rear articulation off road, but it also stops flow of fluid below certain speeds and that can be better or worse depending on the situation at all 4 corners. The one front wheel ramp test, or equivalent off road pics are only one situation. If people watch the full videos posted, there are examples shown where it performs worse, but the proponents never mention those cases. It’s a good system for what it is, but it’s not exactly the magic elixir to all things that the Pro-haters here proclaim it to be. If it was offered on the Pro, I’d have had a hard time deciding one way or the other.
  23. Jan 23, 2024 at 5:13 AM
    #113
    jkirkpatrick
    jkirkpatrick New Member
    It's more fun driving a siow car/suv/truck fast than a fast car/suv/truck slow. KDSS all the way IMO.
  24. Jan 23, 2024 at 5:19 AM
    #114
    kane22
    kane22 [OP] New Member
    I'd like to thank everyone that responded. I keep reading more, and watching more reviews...still undecided.
    The pros for the Pro, are for me it's ready to go off the lot. This might be the biggest for thing for me. I don't mind working on vehicles, but tearing apart a new 50K car isn't something I feel great about. The tires aren't the greatest, but I can live with them till they need replaced. The cons are the cost, and I'm not crazy about the roof rack. That's about it.
    The biggest thing I don't like about the ORP is the stance. I wish it didn't bother me but it does. I'd probably go with Bilstein 6112 up front to level it out a bit. I'd also need tires for sure. Still on the fence about KDSS. Part of me likes the added simplicity of not having it, but others seem to really like it.
    I think I'm down to a TRD PRO, ORP with KDSS, or without, or just keep my junk American made Tacoma TRD and forget about it. The last option makes the most sense...damn it.
  25. Jan 23, 2024 at 6:10 AM
    #115
    jkirkpatrick
    Even with the KDSS, the shocks are too softly valued, so it rides like a boat, but not as much as a boat as the trims without KDSS. It'll still nose dive on braking and tilt to the sky on hard acceleration. if you're considering replacing the shocks on the Pro, you'll likely want to do the same on the Off Road model. The KDSS really comes into play on side to side lean in corners (i.e. city traffic).
  26. Jan 23, 2024 at 6:51 AM
    #116
    @kane22 - after 4 pages of responses, it's obvious that those with a Pro recommend a Pro and discourage buying an Off Road with KDSS. Those with an OR with KDSS will recommend it and discourage buying a Pro.
    You may as well flip a coin. Or keep your Tacoma, as you say.
    BC Hunter and djwantke like this.
  27. Jan 23, 2024 at 7:52 AM
    #117
    kane22
    It seems that way. I'm sure they're all good. I think I'll hold out for a PRO a little while longer. Maybe the urge to buy something will pass:)
  28. Jan 23, 2024 at 8:11 AM
    #118
    Newfy
    Newfy New Member
    Point Pleasant Beach, NJ
    2023 White TRD Pro
    I was getting a Pro no matter what, I like the looks on the outside and all the additional features that come standard on the inside. I got one for MSRP and they gave me 3k more on my trade than the highest Kelley Blue book was going to give me. No brainer for me. I live near the beach and use it during fishing season on the beach, construction sites at work when I don't take my ram 3500, and my pleasure vehicle. That's all I ask of it. Trade time you'll always get more for a Pro than an off-road with all the add-ons because it is a Pro, and there is a limited supply of Pros.
  29. Jan 23, 2024 at 8:14 AM
    #119
    I’d say if you can swing a Pro, then by all means, go for it.
    I haven’t heard of any unhappy Pro owners on this forum.
  30. Jan 23, 2024 at 8:20 AM
    #120
    scon36
    scon36 New Member
    Steve
    Can't wait to see what you get! I've been shopping for almost a year! I'll pull the trigger eventually.
