TRD Pro vs Off road with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by kane22, Jan 15, 2024.
  1. Jan 20, 2024 at 8:33 AM
    #61
    We know that the PRO shocks, wheels, roof rack, etc are installed after they arrive in the US. here's what they look like coming off the boat.
  2. Jan 20, 2024 at 8:46 AM
    #62
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Have this been confirmed? I've always assumed that the shocks were installed at port with the rest of the TRD pro stuff but I've heard conflicted answers on this
  3. Jan 20, 2024 at 8:46 AM
    #63
    I don't agree that shocks would be installed. Swapping tires and adding a roof rack is one thing, and a pretty quick change. But swapping out shocks at the port? That seems like an unnecessary amount of time & labor.
  4. Jan 20, 2024 at 8:57 AM
    #64
    I guess I can't confirm this personally. It's just what I always hear.
    It's just what I read here. Maybe I'm wrong.
    Shocks and coilovers can be swapped pretty quickly if you know what you're doing, though.
    semprenissart[QUOTED] likes this.
  5. Jan 20, 2024 at 8:58 AM
    #65
    I agree. I just saw the video that was posted; so it's very likely they do it all there. I was probably wrong in my assumption. I usually am, but only on Saturday's.
  6. Jan 20, 2024 at 9:01 AM
    #66
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Pro suspension assembled by Bubba on a Friday afternoon
  7. Jan 20, 2024 at 9:02 AM
    #67
    I wonder what they do with all those steel wheels & the tires?
    Thatbassguy[QUOTED] and djwantke like this.
  8. Jan 20, 2024 at 9:30 AM
    #68
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Was the ORP I posted above not fully loaded? I am confused by your assertion that it is somehow not. I fail to see how over $8k is close in price.
  9. Jan 20, 2024 at 9:35 AM
    #69
    Yobruhitsme
    Denver
    Ineos Grenadier
    that’s not good analysis. A “fully loaded” ORP would include crap like the Toyota cooler, sliding tray, and predator steps, etc.
    none of those thousands $ in options bring the ORP closer parity with the pro.
    CalcityRenegade likes this.
  10. Jan 20, 2024 at 9:41 AM
    #70
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    They should send all them PRO roof racks away to the same place :p
  11. Jan 20, 2024 at 9:43 AM
    #71
    True.
    I suppose the wheels & tires make their way back to Japan for the next shipment of Pros.
  12. Jan 20, 2024 at 9:45 AM
    #72
    semprenissart
    semprenissart Mèfi
    no that's the MSRP without any accessories like coolers, predator steps, etc...
  13. Jan 20, 2024 at 9:50 AM
    #73
    semprenissart
    semprenissart Mèfi
    what you posted was the base ORP (without KDSS, moonroof, etc...)
    djwantke likes this.
  14. Jan 20, 2024 at 9:51 AM
    #74
    Yobruhitsme
    Denver
    Ineos Grenadier
    My ‘23 ORP’s factory msrp + dest is $50k with kdss, moonroof , and MTM. Anything additional options would be crap akin to 4Runnerlifestyle stuff. Those gimmicks would be how you get to $52k
    then you factor in much heavier discounts on ORP than pro. Because no one is buying ORP at msrp or with markup
  15. Jan 20, 2024 at 9:56 AM
    #75
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    If you don’t like the droning Pro exhaust and the fugly roof rack those will have to $wapped.
  16. Jan 20, 2024 at 10:05 AM
    #76
    semprenissart
    semprenissart Mèfi
    I edited my previous post from packages to accessories (which is what you were talking about with the cooler)
    From the Toyota website, if you build with the best package but without ANY accessory (i.e. cooler, predator steps, trd wheels, side exhaust, and all that crap) you're looking at almost $52k.
    Do the same for the Pro and you're looking at almost $57k. So if one was to get and ORP and add TRD wheels, tires, fox shocks, etc... they would be looking at the same price at the Pro (or more expensive with better suspensions). And still wouldnt be getting dual zone climate, factory remote start, JBL audio, auto headlights, etc... that come only with the Pro and limited (in the US)
    If you dont care about all the interior tech that the Pro gives over the ORP, then yes better off getting a base OR or ORP and upgrading only with suspensions & tires
    Mtnmonkey likes this.
  17. Jan 20, 2024 at 10:09 AM
    #77
    Yobruhitsme
    Denver
    Ineos Grenadier
    but in the real world there is heavy discount on ORP - $3k to $5k. Zero discount on pro.
  18. Jan 20, 2024 at 10:10 AM
    #78
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Okay so plus $630 for the moon roof. Pro does not have KDSS so would not include this in my comparison. If you're buying a TRD OR to upgrade the suspension why even bother with KDSS?
  19. Jan 20, 2024 at 10:21 AM
    #79
    semprenissart
    semprenissart Mèfi
    there are other things, like MTM, etc...
    Point is there is not a $8k difference like you posted just from wheels and fox shocks. If you want to match the interior of the Pro with an ORP (which is not possible but you can get close) then the difference is a lot less so it might not be worth it for someone. If someone doesnt care about the tech like @djwantke was saying then yes get a base ORP or even SR5 and save the money to do upgrades that you want
    Plenty of folks here do that. Combine KDSS with a mild lift
  20. Jan 20, 2024 at 10:30 AM
    #80
    semprenissart
    semprenissart Mèfi
    we're only talking about MSRP here
    Too many factors based on what you can get depending on the dealership, your negotiation skills, etc...
    I got my Pro for 54k when some people got their ORP for 53k. Some people got a Pro for 70k while others got an ORP for 47k.
    We cant really speculate of what one could get wihtout knowing more about their credit history, etc... that's why we're going off of MSRP. But yes if you can get a fully loaded ORP for 48k or a Pro for 65k, the choice is obvious
    Newfy and Mtnmonkey like this.
  21. Jan 20, 2024 at 10:43 AM
    #81
    Yes sir. Less sensors the better
    "If you're buying a TRD OR to upgrade the suspension why even bother with KDSS?"
    Valid point. But I think the answer is, because KDSS isn't your springs and struts. Research the trims
  22. Jan 20, 2024 at 4:07 PM
    #82
    Why not? KDSS benefits in ways that no aftermarket suspension can.
    If you're referring to folks who plan on going to long travel, or full rock crawler build, I would agree. But, in either of those cases, I'd start with an Off-Road or SR5. That is, unless I really wanted dual climate control or a special color.
    Old Tanker and semprenissart like this.
  23. Jan 20, 2024 at 4:31 PM
    #83
    JakeTheSnak3
    JakeTheSnak3 Custom Title
    Jacob
    Concord, CA
    2023 4runner Trd Pro
    Daily driver and some off roading within the capabilities of the truck with the plan of upgrading it in the future (lift, shocks, etc) - Get the ORP
    Extra vehicle for camping, light off roading with no intention of modifying suspension in the nearest future and use something else as a daily driver - get the TRD PRO. I like the sound system too.
    That was approach anyway. Everyone is different.
    As far I know, TRD ORP has the KDSS and it makes a better drive on the pavement than the TRD PRO.
  24. Jan 20, 2024 at 7:20 PM
    #84
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    I have KDSs on my 4R and love it. KDSS greatly reduces body roll when cornering. I have also lifted mine with an old man emt lift. Check out my build page for details.
  25. Jan 21, 2024 at 2:33 AM
    #85
    kane22
    kane22 [OP] New Member
    I'm in PA and there's no 5k discount that I've found. Most I've seen was $2200, and I was told any that are on the way will be full price. That may have just been BS to get me to buy one on the lot. Dealers want a 5k deposit just to hold one that's on the way. Is there still a vehicle shortage that I don't know about? I thought we were past all that stuff. I think they're going to get stuck with these sitting on the lot when we get closer to the 6th gen being released. I bet most people will want the latest and greatest.
  26. Jan 21, 2024 at 4:55 AM
    #86
    SolarOctane
    SolarOctane New Member
    Long Island, NY
    2023 4Runner TRD Pro
    How about because that’s the exact comparison this thread is about. Check the title….
  27. Jan 21, 2024 at 9:51 AM
    #87
    DirtyHairy
    DirtyHairy Card-holding Member
    Central NY
    2014 FJ Cruiser; 1978 FJ40; 2023 ORP MGM with KDSS
    That’s interesting about the large deposit where you’re at. In central New York State I gave a $500 deposit last fall.
  28. Jan 21, 2024 at 10:04 AM
    #88
    Same story here in CO. But now its changed, there's plenty in stock even KDSS. I think couples of months back I posted plenty of KDSS in dealership lot.
  29. Jan 21, 2024 at 11:04 AM
    #89
    semprenissart
    semprenissart Mèfi
    When I bought my truck in 22 it was a $500 refundable deposit. When I helped my mother in law get her rav4 a couple months ago, the dealership I went to said they changed it to a non refundable $500 deposit without any guarantee on agreeing with the OTD price beforehand. Needless to say I told them politely (or not) to go find another customer and I went to another dealership further away that had one in stock.
    to all the people in AZ, you should AVOID Camelback Toyota and Tempe autonation Toyota like the plague.
  30. Jan 21, 2024 at 8:30 PM
    #90
    HBJ32
    HBJ32 New Member
    Is the Pro Fox suspension unreliable? Been watching videos and reading posts and some people mention they were shot at 20k miles and others who think they are the best suspension ever.
