TRD Pro vs Off road with KDSS
Discussion in '5th Gen 4Runners (2010-2024)' started by kane22, Jan 15, 2024.
  1. Jan 19, 2024 at 12:45 PM
    kane22
    kane22 [OP] New Member
    When I say "don't do anything crazy with it" I mean I'm not trying to build a rock crawler, or drive through 6 feet deep mud holes. I do want the most capability I can get with a factory warranty. A foot of snow is not uncommon, some tight, steep, slippery, old logging roads, stuff like that.
    DirtyHairy likes this.
  2. Jan 19, 2024 at 12:45 PM
    kane22
    No rear locker is a deal breaker for me.
  3. Jan 19, 2024 at 1:47 PM
    Can add both front and rear lockers to SR5 from a good shop. Then you can engage or disengage at anytime. From factory you can only do in 4L.
    Thatbassguy and Old Tanker like this.
  4. Jan 19, 2024 at 2:08 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    For what you described above, trd pro offers nothing that is beneficial over ORP + kdss.
    the lack of kdss actually makes driving on those tight logging roads worse, due to body lean
    CalcityRenegade likes this.
  5. Jan 19, 2024 at 2:57 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I do not know about the US, but the Pro is an immediate $12k jump here in Canada. You could use that to build a pretty damn nice 4Runner, and the way you want it with that $12k. TRD Pro wheels are only 7" wide so not ideal if going to larger tires and the stock tires are not that great either. You could likely build a better 4Runner for half the price of going with the Pro.
  6. Jan 19, 2024 at 3:07 PM
    kane22
    I don't disagree. They one local dealer has two on the way with KDSS. The bad thing is they have so much extra crap they're only 3k less than a pro. Add in tires and I'm down to 2k difference.
    Mtnmonkey likes this.
  7. Jan 19, 2024 at 3:10 PM
    kane22
    They won't move off MSRP for a pro, but it's not anywhere close to a 12k jump.
    Newfy and Mtnmonkey like this.
  8. Jan 19, 2024 at 3:22 PM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Much larger price gap up here, but still $8,040 more for the US. That is still a lot of money you could use for upgrades.
    DirtyHairy and kmeeg like this.
  9. Jan 19, 2024 at 3:49 PM
    kane22
    Except you can't find a ORP for $47,130. I've been looking but they're all in the low 50's around here
  10. Jan 19, 2024 at 3:52 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    That's $12k Canadian.
  11. Jan 19, 2024 at 4:25 PM
    Yobruhitsme
    Denver
    Ineos Grenadier
    What market? Buy out of state for $5k off msrp?
  12. Jan 19, 2024 at 4:39 PM
    DrewMan
    DrewMan 2016 4RTP-KDSS
    Middle Tennessee
    2016 Magnetic Grey 4Runner Trail Premium
    Bilstein 5100 Series Shocks, Daystar 1.5" Rear Coil Spacer (Mid Left), Level 8 Tracker Pros 17x9, 275/70/R17 B.F. Goodrich TKO's, N-Fab Nerf Steps
    save yourself some money and do small upgrades that you want, like and do yourself; I still love my 2016-4RTP w/ KDSS along with Bilstein 5100’s all around.
    Just turn 87,000 miles on it!
    Mlbdriver and josean99 like this.
  13. Jan 19, 2024 at 5:39 PM
    Nice wheels!
    DrewMan[QUOTED] likes this.
  14. Jan 19, 2024 at 6:20 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Yes it is price wise. But since our Canadian ORPs (at least my '22) come standard with things like auto headlights and high beams, factory remote start, dual zone climate, heated seats and Kdss I didn't even consider the Pro. Just not worth the extra bucks for a name and argueably superior all round stock performance. Not bashing the Pro crowd but ORPs here are a much better bang for your buck.
  15. Jan 19, 2024 at 6:51 PM
    Jcberb
    Jcberb New Member
    Joel
    New guy here, got an ORP after a while of debating. Once I realized there was not much of a difference between pro and ORP I went with the ORP. The Pros were going for 55+k while a boring white ORP was $47k.
  16. Jan 19, 2024 at 6:58 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Kdss is not good on dirt roads at faster speeds. Too stiff. If anything you would want to disable kdss in these instances (great mod from dr kdss). Pro suspensions are more or less designed for that.
    kdss is great on pavement to reduce body lean like you said. Or at very slow speed off road, it gives ever so slightly more articulation on a stock set up
    Mtnmonkey and djwantke like this.
  17. Jan 19, 2024 at 7:07 PM
    semprenissart
    semprenissart Mèfi
    Fully loaded ORP with kdss is near $52k. That’s very close to the price of the pro. If you add better tires, wheels, and suspensions you’re essentially there if not more assuming that you pay a shop for the install.
    if you want to stay stock I say the pro is a better deal. If you want a fully loaded truck and put better suspensions, tires, etc… then ORP is the way to go
  18. Jan 19, 2024 at 7:08 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  19. Jan 19, 2024 at 7:18 PM
    #49
    hey don't be callin' ORP's cheap and dumb LOL they're glorious.
    jk
    quite the conundrum on your hands.
    I actually would choose SR5 Premium
  20. Jan 19, 2024 at 7:20 PM
    #50
    I have Trail w/ Dr. KDSS swaybar kill switch.
    If you don't like a lot of fluff and tech, it's a better setup than PRO imo
  21. Jan 20, 2024 at 2:38 AM
    #51
    kane22
    some real numbers for you guys
    the cheapest ORP with KDSS is $51,639
    the PRO is $57,128
    now I'll have to figure out the cost of upgrades I would want on the OPR. the PRO would stay stock
  22. Jan 20, 2024 at 6:36 AM
    #52
    Yobruhitsme
    Denver
    Ineos Grenadier
    Do you know that trd pro specific parts are also installed at the u.s. port? So they don’t even come out of the tahara factory like that.. don’t want some hack job conducted the u.s port.
    “ the Pro Model - the suspension, wheels, and roof rack are port installed. All other models are put together in Japan.”
    kmeeg likes this.
  23. Jan 20, 2024 at 6:44 AM
    #53
    semprenissart
    semprenissart Mèfi
    the engine is what's important, and that's built in Japan. The rest doesnt matter, it's not rocket science and whether it's done at port or at discount tires. If you get new suspensions, wheels, and tires on an ORP it's also done in the US, not in Japan. If anything, with the Pro you still get all the work under warranty.
    Also toyota techs that install these at port are still better than the ones at the dealership that will do the oil change
    Han4Run, Newfy and Mtnmonkey like this.
  24. Jan 20, 2024 at 6:51 AM
    #54
    Yobruhitsme
    Denver
    Ineos Grenadier
    Well obviously the other stuff are still built in japan. I am talking about relative to an ORP. All the bits you are paying for are just us installed stuff.. no built in japan premium even. So what are we even doing? May as well just buy the wheel from discount tire
  25. Jan 20, 2024 at 7:09 AM
    #55
    Yobruhitsme
    Denver
    Ineos Grenadier
    What market?
    1 mo ago, got my $50k ORP for $46k. No additional dealer add on extras. Pros were being sold at msrp or with additional dealer add ons. So yeah $10k premium
  26. Jan 20, 2024 at 7:55 AM
    #56
    I'd be interested to know if fox shocks, TRD Pro roof rack, TRD skid, TRD Pro wheels, etc made in Japan? I'm thinking it's USA. Especially the shocks since Fox making for Tacoma and Tundra as well? I'm thinking same story for wheels. Not sure..
    With my personal experience I know TRD Pro specific parts are not quality as Japan made TRD ORP. Again, just my experience. Maybe just my TRD Pro is off quality on things like wheel balance, alignment, roof rack crossbar tightness,.....
    djwantke likes this.
  27. Jan 20, 2024 at 8:21 AM
    #57
    semprenissart
    semprenissart Mèfi
    what I meant was that the "not built in Japan, so it's shit quality" is really meant for the engine and the DNA of the truck.
    Not for aftermarket parts whether you buy them from Toyota or another store in the US.
    If you're leaving the truck stock whether its a limited, ORP, or SR5, then sure you could argue that everything comes from Japan but it doesnt really make any difference in terms of quality as these parts are not known to fail just because they were installed at port in the US. If anything, how many suspensions from the TRD Pro have failed compared to XREAS or insanely expensive repairs for KDSS if not properly maintained? And for anyone that is getting aftermarket suspensions in the US, then they are in the same boat as the TRD Pro in terms of "made in Japan" but dont get the factory warranty backed up by Toyota
  28. Jan 20, 2024 at 8:25 AM
    #58
    I'm willing to bet that those products are made in America, then shipped to Japan to be INSTALLED on the factory floor during assembly.
  29. Jan 20, 2024 at 8:30 AM
    #59
    semprenissart
    semprenissart Mèfi
    no they are installed in the US
    https://www.youtube.com/watch?v=pitTQ-ye24A
    edit: not sure about the shocks
  30. Jan 20, 2024 at 8:32 AM
    #60
    At US port-
    Screenshot_20221216_093934.jpg upload_2022-12-16_9-23-56.jpg upload_2022-12-16_9-36-7.jpg upload_2022-12-16_9-36-8.jpg
