TRD Pro grille
Discussion in '5th Gen 4Runners (2010-2024)' started by jemnoriega, Feb 9, 2016.
  1. Jul 8, 2017 at 8:59 PM
    #61
    wrongrobot
    wrongrobot New Member
    thom
    Haz parts, waiting for a free morning to do the install. Planning on plastidipping instead of doing the valence add on.
  2. Jul 9, 2017 at 12:17 PM
    #62
    chamberman1979
    chamberman1979 2016 TRD PRO
    Hefty Fabworks Bumper, Skid Plate and Rock Sliders. Icon Suspension, Winch, Spare Tire Mount, RIgid LED Fof Lights, HID Headlights, Ladder, Trail Grapplers
  3. Jul 10, 2017 at 7:32 AM
    #63
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    Got mine in, waiting on the lights so i can do it in one go.
    arnette64 likes this.
  4. Jul 10, 2017 at 7:34 AM
    #64
    JBTRD
    Jeremy
    Ohio
    I dont know, i think they come on as the truck is on. But i will let you know as i should be installing them this week. And for extra parts it costs about $50
  5. Jul 14, 2017 at 1:36 PM
    #65
    wrongrobot
    thom
    FWIW, I also did the TRD Pro upgrade on my SR5 and it's pretty easy. My frame of reference is the MINI world (I've had 4) where I did a fair amount of overhaul on the body plastic across different models, and all were more laborious than this was. That said, I will also note that I couldn't for the life of me salvage a single clip in the process. Unlike the MINI clips, I couldnt' get to these with enough leverage to compress the 'tree' of the clip such that it could be extracted without damage. Even when I managed to compress one, it never retained the full spread needed for reuse. I'm heading to a general auto parts store to see if I can source similar ones first, before committing to OEM replacements. Regardless, the process is simple enough and well worth it, if you don't mind paying several bills for a few pieces of plastic.
    This is a simplified version of events, which I think would have helped me in retrospect had I understood the process better (even after reading other posts and watching a video, it wasn't as obvious until I did it myself: )
    1. You remove the top plastic shroud covering the front 15% of the engine compartment, via 13 clips.
    2. You remove the T-shaped bracket, and the top grille cover (body colored trim piece) as one unit, by releasing the clips and unscrewing the T bracket from the chassis. Note you will be tempted to release 4 or 5 clips or screws below the T bracket as they appear to be holding the trim piece to the grille assembly. FALSE. The trim piece and T bracket come OUTWARD with a pull. Second note: the install instructions will advise covering the surrounding edges of body color plastic on the front end with masking tape. I did this, but I didn't cover the facing edges of the trim piece itself being removed. Mistake! I scraped the edge of one corner as I pulled it out, and will be paint-penning to correct it.
    3. Pull the stock upper grille off of that trim piece after removing the T bracket, swap out with the new grille piece, put back together. All that's happening here is replacing the grille because the stock grille has the Toyota emblem's oval base in it, which you no longer need.
    4. Put it all back together. Now you have the horizontal body color bar of plastic with the oval cutout for the Toyota emblem that no longer exists. The T O Y O T A garnish piece is overlaid onto this with adhesive.
    5. Go replace all those broken clips, ha
    My next step is to plastidip from here down. We'll see how that goes!
  6. Jul 16, 2017 at 6:02 PM
    #66
    JBTRD
    Jeremy
    Ohio
    Finished mine the other day forgot to post it on this thread.
  7. Jul 27, 2017 at 9:35 AM
    #67
    RatherBbirdHunting
    RatherBbirdHunting New Member
    I have a silver 14 SR5, anyone have similar with mod pics?
  8. Jul 27, 2017 at 3:57 PM
    #68
    Rage
    Rage New Member
    Roger
    Silver 2016 4Runner SR5
    One page back has a silver 5th gen with it done.
  9. Jul 29, 2017 at 8:18 AM
    #69
    kihun
    kihun New Member
    kihun
    2016 4runner SR5
    Took me about 30 mins and no.. no cutting, just taking out bunch of tabs and take the top grill out and put the grill on. Do a search on google man you should be able to find couple DIY.
  10. Aug 1, 2017 at 9:21 AM
    #70
    Desert Dan
    Desert Dan New Member
    2017 4R Off Road
    Do they sell a kit with all the parts including the lower bumper cover or is there a parts list ?
    Thanks
  11. Aug 1, 2017 at 9:32 AM
    #71
    Rage
    Rage New Member
    Roger
    @Desert Dan
  12. Aug 1, 2017 at 10:25 AM
    #72
    Desert Dan
    2017 4R Off Road
    Thanks Rage.
    What about the bottom piece?
  13. Aug 1, 2017 at 10:31 AM
    #73
    Rage
    Rage New Member
    Roger
    You don't need to replace the bottom grill, it never comes off during the process.
  14. Aug 2, 2017 at 10:43 PM
    #74
    tommy596302
    tommy596302 New Member
    tommy596302
    2015 4runner
    Firefly21 and hbarraza1983 like this.
  15. Mar 29, 2018 at 6:17 AM
    #75
    cricket1977
    cricket1977 New Member
    2016 4Runner
    So I’m obviously very new here (1st post) and even still waiting on my SR5 delivery. I absolutely love this look, but looking at the instructions and this write up, in the end Toyota is making us pay THAT much for an overlay?! Am I understanding the write-up correctly?
    Don’t get me wrong I’m still doing it lol, but that just pisses me off. I’m on the wrong side of this business.
    And that amber light setup looks good with the TRD grille!
  16. Mar 29, 2018 at 8:41 AM
    #76
    rsimi72
    rsimi72 New Member
    2017 SR5 Premium - Gray
    Yep. I did the PRO grille update on my Tacoma, but I can't seem to pull the trigger for my 4Runner. I know it looks great, but the cost is crazy. Welcome to the forum!
  17. Mar 30, 2018 at 6:17 PM
    #77
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Well, if it makes you feel any better, you are not really paying $600-$700 for plastic. You are paying for the tens of thousands of dollars in R&D and tooling. I wouldn't be surprised if it was over $100,000 to make the molds and tools required to inject the plastic into those molds, not to mention the lettering. Plus packaging and shipping from Japan. So yes there is about $40 worth of plastic but it cost thousands to get it onto the shape you see and to your door.
    Still too much for me though.
    cricket1977 likes this.
  18. Mar 31, 2018 at 6:10 AM
    #78
    cricket1977
    2016 4Runner
    Very valid point!
    Being that I work in R&D, I should have thought about it in those terms and totally thought about it from consumer view only...doh. I spent several million on just developing a molded durable case to house micro vacuum system for wound suction in the field.
  19. Apr 9, 2018 at 5:32 PM
    #79
    browndirtcowboy
    browndirtcowboy New Member
    king 3" lift kit, fuel vectors, 285 toyo mt's, oem audio 500q, morimoto hid headlights, morimoto led fogs,
    The TRD pro grill is cool looking and I was a sucker like everyone else and did mine. The install was easier than anyone can imagine a phillips screwdriver and 25 minutes its done. The sad part is we are all paying 560 bucks plus for cheap 10 bucks worth of plastic. This is the biggest racket ever. Some fat cat is sitting back and laughing his as off. If anyone is smart enough to create a cheaper knock off you would be able to quit your job and sit back laughing as well as the money comes rolling in.
  20. Apr 9, 2018 at 5:34 PM
    #80
    browndirtcowboy
    A large 3d printer and your a millionaire....
  21. Apr 27, 2018 at 9:54 AM
    #81
    ckon
    ckon New Member
    Chuck
    SE Michigan
    2018 Silver TRD ORP w/KDSS
    Tinted front windows | Hard-wired radar detecter | Heritage grille | Bumper, wheelwell and mudflap mod | 285/70 Nitto Grapplers | Plasti-Dipped valances, rack rails and logos | Replace all interior lamps w/LEDs | XenonDepot HIDs | Salex console and glove box organizers | RCI aluminum skid plate | Sprint Booster | Bilstein 5100 Shocks - Leveled @ .85 |
    $550, or so, two pieces, thirty minutes and a bit of PlastiDip:
    arnette64, SKT_07 and rsimi72 like this.
  22. Sep 4, 2018 at 12:25 PM
    #82
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    Noticed in the instructions it calls for 3M GPAC or 3M Prep Solvent-70. Not easy to find. Wondering what others have used to clean the area the garnish sticks to. Thanks
  23. Sep 4, 2018 at 2:57 PM
    #83
    ckon
    ckon New Member
    Chuck
    SE Michigan
    Just alcohol wipes of any kind should do the job.
  24. Sep 4, 2018 at 3:00 PM
    #84
    Daohaus
    Daohaus New Member
    Duan
    Eastvale CA
    2018 Black ORP 4Runner
    Rotiform SIX-OR | Toyo Open Country RT 285/70/17
    I wouldn't don't it if Toyota artificially sets a higher price to limit the amount of people buying them. The TRD pro grille for the tacos is a lot laterl and it's not this expensive
  25. Sep 4, 2018 at 3:31 PM
    #85
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    TLCA #25089
    I can't comment on the quality, but https://trailstandardoffroad.com/ has knock off upper grilles and PRO valances for $330 no lettering and $410 with lettering.
  26. Sep 10, 2018 at 6:23 PM
    #86
    4Runner_Patrick
    2023 TRD PRO Black
    Does the Pro grill clip in to the bumper. Wondering if there is anything else holding it other than the 3M tape. Thanks
  27. Sep 10, 2018 at 6:30 PM
    #87
    MeefZah
    Lexington, Ohio
    GX460
    TLCA #25089
    The fascia cover is held on by tape alone.
  28. Sep 11, 2018 at 6:47 AM
    #88
    4Runner_Patrick
    2023 TRD PRO Black
    How are these holding up in the weather since they are only held together with tape? Thanks
  29. Sep 11, 2018 at 7:26 AM
    #89
    MeefZah
    Lexington, Ohio
    GX460
    TLCA #25089
    I don't have one so I have no firsthand experience. That's the way the "from the factory (port)" TRDP fascia is installed also and I've never seen a post about one falling off.
  30. Sep 11, 2018 at 8:48 AM
    #90
    4Runner_Patrick
    2023 TRD PRO Black
    Thanks - The Tacoma and Tundra Pro grill use clips. Hopefully, someone who owns one will comment.
