TRD Pro Exhaust
Discussion in 'Performance' started by Gossamer, Feb 1, 2021.
  1. Apr 3, 2021 at 10:22 AM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    You need the whole exhaust from cat back the Trd Pro has 3 bolts at the bend over at the resantor in your picture #18 that attaches it together where as the OEM has only 2, you can't mix and match unless welding
    N6WRV likes this.
  2. Apr 3, 2021 at 3:10 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I have a oem exhaust I removed the other day. Let me know if your interested. It’s from a ‘16 Limited. But they are all the same.
    DVS1 and N6WRV like this.
  3. Apr 3, 2021 at 4:07 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    It looks like that's probably the stock stuff, so you'd need 11 and 16 for sure. Just in case, grab an extra 12 just in case. I put my TRD exhaust on my SR5 about half a year after getting it though with reduced mileage due to covid, and I was able to reuse the gasket that is 12, but better safe than sorry. You may also need to pick up a 17 and a few 18s depending on what you're getting. My TRD exhaust was a kit and came with the equivalents of those parts, but you might not get that 17 gasket and the 18 bolts. It looks like the nuts are welded to the pipe in that diagram, so you'll probably not have to worry about nuts. I know reusing the welded on nuts for 13 and 14 is how it goes, and you'll be reusing 13 and 14 anyway since you already have them. Just make sure you get them tight enough when you put them on or you'll end up losing them like me and my first time exhaust change newbie self last summer.
  4. Apr 3, 2021 at 4:12 PM
    Gamma Ray
    I don't think I posted in this topic before the one right above, but I've had my TRD exhaust installed since last August, and it's been fine. The sound isn't bad, and it's silent most of the time. I'm not getting a drone that bugs me all the time. If I'm getting up to speed or going uphill, then it makes more noise, but it's fine. It also alerts morons who aren't looking both ways before crossing the road that you're coming since they can hear it before they see you.
    DirtyHairy, N6WRV and Crossfit4Runner like this.
  5. Apr 5, 2021 at 11:22 AM
    jigbobby
    jigbobby New Member
    Scott
    2021TRD Pro
    Thank you everyone for the replies, exactly what I needed to know.
  6. May 27, 2021 at 9:57 AM
    Dalez40
    Dalez40 New Member
    Dale
    '21 Black TRD Pro
    Spidertrax Spacers, 67 Designs Mount,
    I have a '21 TRD exhaust for sale with 200 miles on it. $400.00 Pittsburgh, PA area.
  7. May 27, 2021 at 1:22 PM
    N6WRV
    N6WRV New Member
    Paso Robles, CA
    2015 4Runner Limited 4WD with X-REAS
    37qt ARB fridge wired directly to battery with ARB Wiring Kit.
    Piston engines are basically air pumps. The point of a tuned performance cat-back exhaust system is less restriction to the exhaust flow, not the sound. Does the huge OEM muffler restrict the exhaust flow?
  8. Jun 14, 2021 at 10:35 AM
    jlh4480
    jlh4480 New Member
    Justin
    2021 4Runner TRD Pro
    Has anyone worked with a dealer to make this swap? I have a 2021 TRD Pro and I contacted my dealer today regarding installation of an OEM non-TRD Pro exhaust and they indicated it would be several thousand dollars due to the price of the parts. I'm curious if anyone has done this and what they paid/were quoted?
    Thanks,
    JustATallDude and Daytonaviolet like this.
  9. Jun 14, 2021 at 11:04 AM
    JustATallDude
    JustATallDude New Member+
    2019 Toyota 4Runner TRD Pro
    Gibson Single Exit Exhaust - Magnuson Supercharger - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Big Red's Turn Signal Mod and AMD Mod - R4T Blackout Turn Signals - BlackVue DR590 Dashcam and more to come...
    Lmao they're trying to fuck you. All 5th gen exhausts are the same so any stock exhaust will fit perfectly with no extra parts needed.
  10. Jun 14, 2021 at 11:08 AM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    Save thousands and do it yourself.
    https://youtu.be/C1tYozOszgw
    Jindodog likes this.
  11. Jun 14, 2021 at 11:14 AM
    jlh4480
    jlh4480 New Member
    Justin
    Thanks, but has anyone actually purchased the OEM exhaust? I have the TRD Pro exhaust already that I want to remove, but would need to purchase a stock exhaust. That's where the quote is coming in high; for the parts.
  12. Jun 14, 2021 at 11:25 AM
    jigbobby
    jigbobby New Member
    Scott
    2021TRD Pro
  13. Jun 14, 2021 at 11:51 AM
    Daytonaviolet
    Bay Area, CA
    Best solution is swap with a non pro locally. If your in the Bay Area .. I’ll give you my stock exhaust
  14. Jun 14, 2021 at 12:35 PM
    Dalez40
    Dalez40 New Member
    Dale
    '21 Black TRD Pro
    jigbobby likes this.
  15. Jun 14, 2021 at 12:43 PM
    Red_5
    Red_5 New Member
  16. Jun 14, 2021 at 1:31 PM
    jlh4480
    jlh4480 New Member
    Justin
    Thanks everyone for your help thus far. To get rid of the drone sound, do you just need to replace the muffler and tailpipe and not the entire exhaust?
    Dalez40, did you do your own install or have the dealer do it?
    Thanks,
    Daytonaviolet likes this.
  17. Jun 14, 2021 at 1:33 PM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    Yup, you don’t need the entire exhaust. Where are you located? I’m sure there is someone out there that might want to swap exhausts with you.
  18. Jun 14, 2021 at 1:50 PM
    jlh4480
    jlh4480 New Member
    Justin
    I'm located in Malvern, PA.
  19. Jun 14, 2021 at 4:06 PM
    #49
    Daytonaviolet
    Bay Area, CA
    The Trd muffler is only two pieces, muffler and tail pipe.
    so yes you need to replace these parts if you want to get rid of the loud exhaust
  20. Jun 15, 2021 at 4:53 PM
    #50
    edgesalon
    Te
    18 FunRunner :-)
    just put a add up that you want to exchange your Pro exhaust for non Pro you will find someone that is willing to swap and pay you for your exhaust at max its 1/2 hour to an hour job and any mechanic shop can do it I did mine the other way around it helps to have lifts good luck
  21. Jun 23, 2021 at 8:26 AM
    #51
    jlh4480
    jlh4480 New Member
    Justin
    Hi all,
    I wanted to share an update in hopes that it will save others time in the future. I went to two local Toyota dealers (dealer I purchased from is ~400 miles away) and neither would install the the standard (non TRD) muffler and tailpipe on my 21 TRDPRO. They agreed that logically it made sense and that the non-TRD parts would fit, but that they would not perform the work because when my VIN is entered it pulls up replacement/repair parts for the truck which would be TRD exhaust as opposed to stock exhaust and that “Toyota” would not approve putting “non-factory” repair or replacement parts on the vehicle.
    I drove 2 miles down the road to an auto body shop that will buy the non-TRD muffler, tailpipe, gaskets and exhaust tip from Toyota and perform the install…...
  22. Jul 8, 2021 at 8:00 PM
    #52
    jlh4480
    jlh4480 New Member
    Justin
    All,
    Yesterday I had the Pro exhaust swapped to the standard exhaust and I couldn’t be happier. The total cost was roughly $1100, but worth every penny to me.
    Thank you to the previous posters that helped me figure this out.
    2Toys likes this.
  23. Jul 9, 2021 at 2:16 PM
    #53
    Gamma Ray
    Don't they like money?
    Also, $1,100 to swap to the standard exhaust? Holy shit. My TRD exhaust cost $620 for the parts alone. I can't imagine the standard exhaust costing much more, if any more at all. $500 labor to do a catback? I'm in the wrong line of work.
  24. Jul 9, 2021 at 4:09 PM
    #54
    jlh4480
    jlh4480 New Member
    Justin
    Hey Gamma Ray,
    The breakdown on the parts was:
    Muffler 540
    Tail pipe 283
    Gasket 18.60
    Bolt 2.76
    Blk tip 79.0
    I purchased the parts from Toyota dealer. The labor charge was 1 hour at $125.00. Curious the discrepancy on price in mine and yours.
  25. Jul 10, 2021 at 8:31 AM
    #55
    edgesalon
    Te
    18 FunRunner :-)
    well good for you all that matters that your happy put the TRD Pro exhaust up in the market place and you will recover 1/2 what you spend good luck
  26. Jul 10, 2021 at 1:28 PM
    #56
    bomtest
    bomtest New Member
    2021 Lunar Rock TRD Pro
    I happen to love the exhaust sound on my 2021 TRD Pro...
    BC Hunter and Jindodog like this.
  27. Jul 12, 2021 at 6:57 AM
    #57
    jlh4480
    jlh4480 New Member
    Justin
    Morning Bomtest,
    Curious the type of elevation you live in? On a flat road I didn’t mind the sound so much, but in the area I live in there are frequent elevation changes and the truck would drop a gear and that’s when it bothered me more.
    I ask because when I first switched from my old 4Runner to the Pro and started reading online, it seemed there was a correlation in how people felt about the exhaust and the area of the country they live in.
    Thx,
  28. Jul 12, 2021 at 5:51 PM
    #58
    bomtest
    bomtest New Member
    I live at sea level right now, in Southern California... but I bought my Pro in Minot, North Dakota. I then went on a road trip through North Dakota, South Dakota, Wyoming, Colorado, Utah, Nevada and California. I loved the exhaust sound through that whole trip and all those different elevations, and I love it every time I step on the gas. We are moving to Steamboat Springs CO next year and I bought the Pro in anticipation of that move...
    I have to admit that my previous car was an Audi RS3, which is known for it's throaty exhaust sounds and pops and cracks on deceleration... The first time I heard the Audi start up, I knew I had to have it. I didn't buy the Pro for the exhaust sound, but I'd be disappointed if it wasn't there.
  29. Jul 20, 2021 at 9:46 AM
    #59
    MTB Chris
    MTB Chris New Member
    San Diego, Ca
    Sick! I got rid of my B7 S4 but boy did I love the sound of that thing especially at start up. The sound of the TRD exhaust is music to my ears, but I love the throttle response that came with it.
  30. Aug 26, 2021 at 12:03 PM
    #60
    Ken in KC
    Ken in KC New Member
    Ken
    '21 MGM 4Runner ORP
    I'm in a similar boat. '21 ORP came spec'd with the Pro exhaust. I spend a lot of time on the highway and on the phone. I've already committed to installing sound proofing. I like the side exit of the exhaust. I hate the drone. Is there an aftermarket cat-back that will allow me to keep the Pro exhaust routing but won't add additional noise? Or at least minimize the noise compared to the OEM Pro? Magnaflow? Other?
