TRD Off Road model for towing a lite travel trailer on the road??
Discussion in '5th Gen 4Runners (2010-2024)' started by Nemo, Jan 22, 2024.
  1. Jan 24, 2024 at 12:56 PM
    2016Pro
    Tows perfect with just the brake controller. My camper is only 3k lbs. Zero sway and it's perfectly level. I did have a pro model if that makes any difference.
    Op just make sure you get your set up checked out for safety.
  2. Jan 24, 2024 at 12:57 PM
    2016Pro
    Didn't need it in my application with my camper. I went to a reputable tow shop to make sure everything was good. Thanks
    Every situation is different, I always recommend getting your set up checked by professionals.
  3. Jan 24, 2024 at 1:03 PM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    @2016Pro -- if the weight distribution hitch was free, would you take it? Do you think it adds anything of value while towing?
    catbrown357 likes this.
  4. Jan 24, 2024 at 5:53 PM
    2016Pro
    I actually bought one brought it to the tow shop and they said return it you are fine
  5. Jan 24, 2024 at 8:01 PM
    HandofBoB
    HandofBoB New Member
    Pensacola
    2023 Lunar Rock TRD ORP
    We tow our OP Lite with ease. Redarc brake controller made life so easy.
    like2lean and Thatbassguy like this.
  6. Jan 24, 2024 at 8:31 PM
    coryanderson
    Cory
    Interesting. Care to share the tow shop?
    Ultimately, fine and good are different than prepared and ready.
  7. Jan 25, 2024 at 3:15 AM
    Jeez, give it a rest. Not every situation necessitates a weight distribution hitch.
    2016Pro and PointmanUSMC like this.
  8. Jan 25, 2024 at 4:44 AM
    Getuponit
    Getuponit New Member
    Jimmy
    2013 4Runner
    Towed an Opus OP4, (similiar to rig above) 4200# gross. I have air bags and trailer brake. No weight distribution hitch. Trailer was level, no issues. S4 & S5 are your friends.
    2016Pro, PointmanUSMC and Thatbassguy like this.
  9. Jan 25, 2024 at 6:56 AM
    coryanderson
    Cory
    Cool
  10. Jan 25, 2024 at 10:39 AM
    2016Pro
    EXACTLY
    icebear and Getuponit like this.
  11. Jan 25, 2024 at 10:40 AM
    2016Pro
    Yes, the same for my setup
  12. Jan 27, 2024 at 2:09 PM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    Looking forward to getting my little trailer out this spring with the 4Runner, ignore the Ford thing. Livin Lite 6', pops out a single queen bed. ~1500lbs with gear. PXL_20220514_190840640.jpg
    DadOperator, icebear and Thatbassguy like this.
  13. Feb 3, 2024 at 7:34 AM
    like2lean
    like2lean New Member
    Nice set up, is that a 16 or 20? I was thinking about a 16 but got scared off of towing with the 4R, after reading this great thread I'm rethinking it all. How much do the WDH or anti sway trash departure angles? Do you use airbags also?
  14. Feb 3, 2024 at 8:07 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    This is the Basecamp 20X. I can't really speak for departure angles. I pulled across some fairly steep sided washes and had no problems. Let's be clear, common sense when towing anything is a must. I did not use airbags, I opted for OME medium duty springs on the rear. With the WDH and proper loading, I was able to achieve a level ride height. Had to do all over again, I would probably install airbags as well. Do yourself a favor and get a REDARC trailer brake controller. They are amazing and unobtrusive. https://www.redarcelectronics.com/us/landcruiser-sequoia-4runner-brake-controller-kit
