TRD Hood Scoop Vinyl/Glare Deflector
Discussion in '5th Gen 4Runner Parts Marketplace (2010-2024)' started by MyWyfsRnnr, Apr 14, 2022.
  1. Apr 11, 2023 at 10:04 AM
    #151
    waldo98
    waldo98 New Member
    Walter
    SoCalli
    2023 ORP Nautical Blue Metallic
    in for later since I'm suppose to be driving up to NorCal sometime year..
    MyWyfsRnnr[OP] likes this.
  2. Apr 15, 2023 at 9:21 AM
    #152
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Finally got around to cleaning the 4Runner so that I could take the pictures this deserves. This is one of my favorite comfort modifications. You almost forget how nice it is once you’ve been without the glare long enough.
    Wouldn’t hesitate to do further future business with OP. Great service and product!
  3. Apr 15, 2023 at 9:54 AM
    #153
    MyWyfsRnnr
    MyWyfsRnnr [OP] Have you seen the mall?
    Chris
    Citrus Heights
    2018 4Runner TRD
    Thanks for the endorsement!!! I am glad you are happy with it! That glare can be a bear so may as well customize while also fixing the problem. Have fun out there!
    mb3 likes this.
  4. Apr 15, 2023 at 12:57 PM
    #154
    singalls
    singalls New Member
    Stephen
    Northern California
    2022 TRD Off-Road Premium
    What color would you recommend for a silver 4runner. Prefer something that is more subtle and blends in but want to block the annoying sun glare.
  5. Apr 15, 2023 at 7:04 PM
    #155
    DVS1
    DVS1 New Member
    Ray
    Oahu, HI. to Tampa, FL.
    18 TRD Off Road Premium w/KDSS
    Fuzzy dice
    Post #148
    I have a mat black with silver topo design on a silver 4R.
    If you’d like I can take pictures of my dirty 4R, so you have a better example.
  6. Apr 16, 2023 at 3:40 PM
    #156
    singalls
    singalls New Member
    Stephen
    Northern California
    Thanks Ray. Another picture would be great. Was wondering how black vs grey would compare. Not sure exactly what options are available.
  7. Apr 16, 2023 at 6:55 PM
    #157
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Light Grey for sure... The topo lines match the cilver pretty closely. I will be home tomorrow evening and I will verify stock etc. I am in the middle of a switch between vinyl suppliers.
    I will look at what I have left... I am still trying to transition to a new vinyl supplier. I am out of town but will be back this evening.
    Thanks
  8. Apr 18, 2023 at 6:44 PM
    #158
    DVS1
    DVS1 New Member
    Ray
    Fuzzy dice
  9. Apr 18, 2023 at 6:50 PM
    #159
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Anybody do white on white!?
  10. Apr 18, 2023 at 8:45 PM
    #160
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I think this might be one of the light greys... I will try to track down a pic of white contours on white
  11. Apr 18, 2023 at 9:32 PM
    #161
    So what I mean is, there's straight flat black right, I like that but does straight flat white work for glare or does it have to be black. Is flat white an available color anywhere
  12. Apr 18, 2023 at 10:06 PM
    #162
    Are you asking if the main vinyl sheet can be flat white?
  13. Apr 18, 2023 at 10:31 PM
    #163
  14. Apr 19, 2023 at 7:26 AM
    #164
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    The issue with the glare is primarily the reflection on the clear coat on the hood scoop. A matte finish on the vinyl would help but with white, you will still have a lot of light. Think about white walls vs color walls with a light bulb. I am willing to order a single sheet and cut one if you want to try it. (I've only had this request once before but they changed their mind). PM me if you want to move forward.
    Thanks !
    2Toys likes this.
  15. May 18, 2023 at 11:57 AM
    #165
    I may be about to remove this from my 4R, sorry to say. While it does exactly what is advertised - cut glare from the sun at certain times during the day - this thing is a dirt magnet. If my vehicle is not freshly washed, the vinyl hood scoop cover looks like a dirty rug sitting in the middle of my hood. I don't have the luxury of a garage to park my rig in, just a carport. So every time the wind blows any dust around, it all seems to land directly on this hood scoop decal. The rest of the hood might look dirty, but the cover is 3x as dirty looking.
    I gave it a good shot. I just don't think the amount of times I got the advantage of the glare protection is worth the look when dirty. I don't want to discourage anyone from getting one of these; it may just be the black color on an MGM vehicle that looks this way. @MyWyfsRnnr is a stand-up guy with a great product, it's just not working for me after all.
  16. May 18, 2023 at 12:10 PM
    #166
    broken-giver
    broken-giver BFD
    I was just about to ready to purchase this within first week of owning ORP. However, after I got the ppf installed its a non-issue for me. It looks cool however! Especially the lettering makes it quite unique.
  17. May 18, 2023 at 12:15 PM
    #167
    No question - it's a quality product, and the ones with lettering look great; plus, the installation is a breeze, if you follow the directions. The only way it wouldn't show more dirt is if it was the same finish as the rest of the hood, which would totally negate the reason it exists and the reason for getting it in the first place.
    2Toys likes this.
  18. May 18, 2023 at 12:15 PM
    #168
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Bummer! Ours is MGM also and I can see what you mean. Right now the pollen is going nuts in our area and the matte uniform shows it pretty well.
    When you remove it, be sure to use a good amount of heat and go slowly, I suggest going from one front corner and heating it up to soften the adhesive. Then pull it backwards onto itself so the decal pulls backwards from the paint, not up. Work it an inch or so at a time with heating and pulling to get it off and not leave any adhesive. If any adhesive stays, a little bit of Bug and Tar remover will take it right off then give the area a wash and wax.
    2Toys likes this.
  19. May 18, 2023 at 12:21 PM
    #169
    I really appreciate the removal tips, thanks!
  20. May 28, 2023 at 5:45 AM
    #170
    povertyrunner
    povertyrunner New Member
    Finally got around to getting the vinyl put on. Perfect fit and can definitely say it cuts glare a lot. Not sure how I feel about the letters but they should be easily removed.
    MyWyfsRnnr[OP] and HuskyMike like this.
  21. May 29, 2023 at 4:59 PM
    #171
    jtvs
    jtvs New Member
    Jay
    2023 4Runner
    Just installed the vinyl. Really like the look, and after parking in the sun for a few min, did notice one tiny bubble that I missed while in the garage. Will have to see whether a pinprick will help. Otherwise, went on pretty easy. And definitely cuts the glare!
  22. May 29, 2023 at 5:15 PM
    #172
    OverRunner
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Personally, I would wait a few days before trying to fix it with a pin or anything. I had a small imperfection in mine as well, but before I had a chance to fix it, the Texas sun had done the job for me. I imagine that like with tint, given enough time and heat, any trapped moisture will evaporate and the vinyl will settle itself into place. At least it did for me. Good luck!
  23. May 30, 2023 at 3:48 PM
    #173
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    Sent you a private message. Please check it out when you can. Thanks
  24. May 30, 2023 at 10:37 PM
    #174
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    A little heat will get them easily detached. I just put those letters in there to give something extra in an area that would otherwise be waste. Looks good!
    @OverRunner is correct. This vinyl breaths so give it a couple days in the sun etc and it will probably lay flat on its own. This stuff is pretty forgiving. Looks good on there!
  25. May 31, 2023 at 7:35 PM
    #175
    jtvs
    jtvs New Member
    Jay
    2023 4Runner
    Thanks Overrunner & MyWyfsRnnr, I checked on it today and the tiny bubble is gone. I did let it sit in the sun for a while on day of install and has since been in the garage.
    Really happy with the end result!
    Tks!
    MyWyfsRnnr[OP] and OverRunner like this.
  26. Jun 21, 2023 at 4:41 PM
    #176
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Hey all!
    Cleaning up my office today and found enough of the flat black with dark grey contours for 3 hood scoop decals. I know a lot of people were interested in them last time I ran out. I'm offering them here first before I put them in my store on Friday. PM me if you are interested.
    Thanks
    Chris
  27. Jun 23, 2023 at 9:03 AM
    #177
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
  28. Jun 23, 2023 at 1:36 PM
    #178
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Have you tried making any pillar mountain designs but for the lower part of the back hatch? Mine is scratched up from low garage door. Would like something to hide the scratches. Only have seen 2 on Etsy/Ebay and didn't like either of them.
  29. Jun 23, 2023 at 1:54 PM
    #179
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    PM ed
  30. Jul 11, 2023 at 9:15 AM
    #180
    samba93
    samba93 New Member
    Interested in purchasing this. ... how do i do this. .
