TRD engine skid v. aftermarket
Discussion in '5th Gen 4Runners (2010-2024)' started by Austin26, Feb 14, 2023.
  1. Mar 24, 2023 at 4:39 PM
    #61
    rmiked
    rmiked New Member
    Fort Mill, SC
    Thanks a bunch. I do not have KDSS so the braces should be able to stay.
  2. Mar 25, 2023 at 3:59 AM
    #62
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    Now that I have seen more installs of other skid plates, those KDSS protector braces seem to be there as reinforcement for the stock skid plate. Other skid plates, including modifying the OEM TRD skid plate requires them to be removed. I guess the idea is that the upgrades skids can take more abuse than the standard one.
  3. Mar 25, 2023 at 10:00 AM
    #63
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    the braces also support the bulkhead/radiator support.
    the necessity of removing the braces depends on the design of skid plate. RCIs engine skid for KDSS 4Rs doesn’t require the removal of the braces.
    djwantke and 5six[QUOTED] like this.
  4. Mar 25, 2023 at 5:10 PM
    #64
    5six
    5six New Member
    55_4Runner
    2022 Black TRD ORP
    I should’ve just gone with the RCI one. So far I have some regrettable expenditure on this build :facepalm:
    djwantke likes this.
  5. Mar 25, 2023 at 7:17 PM
    #65
    Austin26
    Austin26 [OP] New Member
    Austin
    5th gen ORP
    Not that people care but I went with RSG Metalworks front skid. Perfectly beefy for what I want. Sad that it takes some of my ground clearance away, though. Made it work with my RCI tranny skid. Also have a Cali Raised gas tank skid.
  6. Mar 25, 2023 at 7:26 PM
    #66
    rmiked
    rmiked New Member
    Fort Mill, SC
    Does it ride lower than the factory skid? And does the Toyota TRD skid plate ride lower than the factory skid plate? Just wondering what you reference is for losing ground clearance. I put a Toyota TRD skid plate on my Tacoma TRDOR (sold truck) and it looked good but a I got the impression it was lower than the factory skid plate. I never measured it before and after.
  7. Mar 25, 2023 at 7:42 PM
    #67
    Austin26
    Austin
    5th gen ORP
    I never had the TRD Pro skid plate so I can't speak to that.
    It probably didn't take away my minimum ground clearance other than the thickness of the metal, but the profile is different than the factory skid. It kind of bulges out in the front but is flat and hugs the cross member as one would expect. I may not be making sense... Let me try again. Okay on my side profile sketch the black is the factory skid profile and the red is mine and most aftermarket skids. It's probably the same as before (except steel thickness) it just looks more pronounced.
  8. Mar 25, 2023 at 7:47 PM
    #68
    rmiked
    rmiked New Member
    Fort Mill, SC
    I see what you are saying. Doesn’t look like you lost any clearance from minimum.
  9. Mar 26, 2023 at 8:50 PM
    #69
    ZWChen
    ZWChen New Member
    Yes, cartrimhome offers a black style option that no longer requires painting.
  10. Mar 26, 2023 at 8:53 PM
    #70
    ZWChen
    ZWChen New Member
    Mine doesn't have KDSS either, I just removed 4 bolts(A) and installed the SKID PLATE, no need to remove the member braces.QQ截图20230327115225.jpg
  11. Mar 27, 2023 at 5:01 PM
    #71
    Shanky
    Shanky New Member
    If you stop & assess when you hit your front skid your needs may be different than those who plow ahead when they scrape something hard.
  12. Mar 27, 2023 at 6:00 PM
    #72
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Give ARB 4-piece a look
    Got KDSS. Can jack both front wheels from engine skid. No oil access tho. Forces me to check for leaks n grease periodically which is a good thang, enjoy the wrench be one with the wrench
    packetcollision likes this.
