Traction control operation
Discussion in '5th Gen 4Runners (2010-2024)' started by Tmiesowicz, Mar 27, 2022.
  1. Sep 7, 2023 at 10:25 AM
    #61
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Fake news!
  2. Sep 7, 2023 at 10:38 AM
    #62
    Correct. But those are all marketed as electric gadgets, which they are. The brochure says limited slip differential, which it really isn't.
  3. Sep 7, 2023 at 10:41 AM
    #63
    It shows "automatic limited slip" in the 23 brochure but most people wouldn't know the difference.
    Thacrow likes this.
  4. Sep 7, 2023 at 10:45 AM
    #64
    Most ppl aren't the wise whipper snapper !
  5. Sep 7, 2023 at 10:47 AM
    #65
    It says "automatic limited slip differential."
  6. Sep 7, 2023 at 10:53 AM
    #66
    Exactly. Most owners will never know, or care. But, it shouldn't be referring to as a limited slip differential when the differential has nothing to do with the feature.
  7. Sep 7, 2023 at 10:59 AM
    #67
    Yeah but what oil should I used people read that. :D
  8. Sep 7, 2023 at 11:15 AM
    #68
    Olive, extra virgin ;)
  9. Sep 7, 2023 at 1:15 PM
    #69
    Bastards eh. All part of the big machine, with the Double Speak and Group Think lol
  10. Sep 7, 2023 at 1:18 PM
    #70
  11. Sep 8, 2023 at 10:27 AM
    #71
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Why does vsc off illuminate in 2wds with 1 press but not on 4wds? Why does it say LSD on the dash and not trac off? Why would it be different from 2H?
    The only explanation is that lsd means lsd. I am going to find videos of 2wds with their wheels in the air now.
    By the way, are the other forums any good? (tw runner forum, t4r org) Am surprised to not be hearing about the wheels by now. That's a chill vibe I like it.
    edit of course there are no great videos at first glance. I did find these though.
    https://m.youtube.com/shorts/uE73H6I09r0
    https://m.youtube.com/shorts/q1GqTGatzh4
  12. Nov 24, 2023 at 10:57 AM
    #72
    GunniLuv
    GunniLuv New Member
    Mac
    CO Front Range & Gunnison
    '23 TRD OffRoad Premium
    none
    First post. Just picked up our new '23 TRDOR and today is the first snow. Went out to see how the OEM Dunlops handled and started messing around with the VSC, ATRAC, and Diff Locker buttons. Googled it and found this forum and thread. Previously went through all the trials and errors the previous posters encountered, and it's been really helpful. Button holding vs simply pushing, etc. So, thanks!
    I've had LSD vehicles in the past as well as an '06 Sienna AWD, with the traction control. Curious why my 4runner diff locker only works in 4L? Unless T is protecting us from ourselves if we are driving too fast on slippery roads?
