Toyota's take on the difference between 4R and LC250
Discussion in '6th Gen 4Runners (2025+)' started by NoDak, Apr 17, 2024.
  1. Apr 22, 2024 at 5:35 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    So... I had so much fun at offroad driving school this past weekend, I think Im keeping my 5th gen for a while :D:D:D:D:D:D:D:D
    Shredder, kolter45 and Yotaholic like this.
  2. Apr 22, 2024 at 11:27 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    LOL The deal-breaker between the two may also depend on which model will fit in their garage.
  3. Apr 22, 2024 at 9:36 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Your 5th gen is better than the 6th and the new LC offroad.
    BC Hunter likes this.
  4. Apr 23, 2024 at 6:41 AM
    Lost Woods
    Lost Woods New Member
    2024 SR5P
    The LC250 is the worldwide model while the 4Runner is only marketed in the Americas so they're already building both just as before. They're an identical platform underneath so the cost to Toyota to sell both here is an assembly line changeover to US spec with parts they're already making since they ship from the same factory. It's not like they built two totally competing models that will eat each other's sales, it's a different body bolted to the same platform.
    They recognize people will give them more money for a "Land Cruiser" so why stop them?
  5. Apr 24, 2024 at 4:27 AM
    NoDak
    NoDak [OP] New Member
    JR
    North Dakota
    the lc250 is usa only. rest of the world uses the lc prado (aka lc250) or the lc200 series (the true land cruiser, aka heavy duty). think the lc300 is what the lexus models use
    the 4r is called the fortuner outside the usa but is based on the hilux.
  6. Apr 24, 2024 at 2:51 PM
    Lost Woods
    2024 SR5P
    The 4Runner and Fortuner have about as much in common as the Tacoma and Hilux. That is to say, very little. Both Fortuner and Hilux are the same 20 year-old IMV chassis which has never been stateside.
    As for the rest I'm not exactly sure what your point is... LC250 is the Toyota designation for the J250 platform which includes the US Land Cruiser and the forthcoming Prado (and obviously the GX)... they're the same thing minus some localization/compliance items and both referred to as the LC250. It's absolutely a worldwide model.
  7. Apr 29, 2024 at 8:19 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    So Im trying to figure out this ground clearance question on the LC. Definately want to go see one in person when I can. I took images off the build configurator and did some measuring in MS paint, using the known tire diameter as a baseline:
    Unless they are using a completely different axle the rear diff cannot be hanging that low. Maybe something with the suspension up frnot is causing the front skid to hang lower? Or maybe its that plastic front air damn and easily removable.
    And then from the front, its likely part of that air damn can be ripped off and hte aftermarket may make full replacements for hte lower half of hte bumper to improve clearance. Probably good bones to build up on here??
    The more and more I look at the LC the more I like it. Buy the mid trim, swap out the headlights for the rounds, rip off the air dams and swap to bigger AT tires and add some armor and then have fun with it. I could probably get stupid money for trading in my Pro.....
  8. Apr 29, 2024 at 9:07 AM
    NoDak
    JR
    North Dakota
    i probably guess the pumpkin or the shocks are the culprits
    edit: or the lower arms
  9. Apr 29, 2024 at 3:43 PM
    Lost Woods
    2024 SR5P
    All LC get the hybrid engine which means they get the larger rear axle. The 6th gen will probably still get the smaller rear axle on the non-hybrid like the Tacoma so those will have more clearance all else equal.
  10. Apr 30, 2024 at 3:06 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    So if true, and they need the bigger axle to handle the hybrid torque - that implies they 4Runner TRDPro and Traihunter with the hybrid max will also have this limited ground clearance unless they put even bigger tires on them (which didn’t seem to be the case in the launch info)
  11. Apr 30, 2024 at 5:47 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    I did some math. Got out the measuring tape and verified my 2023 is 9 1/2" give or take to the bottom of the diff in back. So with a 31.6" wheel that works out to
    31.6/2 = 15.8 to the center of the hub.
    15.8-9.6 = 6.2" radius of the diff, aka the outer diameter of the housing is 12.4" for the Toyota e-locker axle.
    So if the land cruiser has a 32.6" tire and 8.3" ground clearance:
    32.6/2 = 16.3 to the center of the hub.
    16.3-8.3 = 8" radius of the diff, aka the outer diameter of the housing is 16" for the hybrid max axle. (assuming its symmetrical, and I know it may not be)
    Does this sound right? That's a huge increase, and it would imply that the higher trim 4Runners need it also.
  12. Apr 30, 2024 at 7:41 AM
    BlueBabySound
    BlueBabySound New Member
    I read for the TH
    "33-inch Toyo Open Country all-terrain tires wrap unique bronze-painted wheels, and in combination with the suspension, raise the front ride height by 2 inches and the rear by 1.5 inches. "
    https://www.autoblog.com/2024/04/09/2025-toyota-4runner-trailhunter-trim-breakdown/
    EDIT: Not sure if you're saying bigger than a 33"...???
  13. Apr 30, 2024 at 8:01 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Some of the youtuber first look videos said the 6th gen is on 265/70-18s same as LC... which are roughly a 33. Maybe it is an even bigger tire?
  14. Apr 30, 2024 at 8:05 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Found the image online... It is a 265/70-18... so the "33" is a 32.6.
    So my theory stands - if the LC minimum ground clearance of 8.3 is to the rear pumpkin, and the rear pumpkin is lower because of a bigger,stronger axle to take the iForce max torque, and the 4Runner has the same iForce max... it must have the same rear axle and the same clearance limitation.
    We need guys at Dealers with a tape measure and camera when these hit lots....
    COTacoPro and BlueBabySound like this.
  15. Apr 30, 2024 at 9:08 AM
    BlueBabySound
    All assuming the pumpkin is the measuring point, and not a control arm or shock mount. Correct?
  16. Apr 30, 2024 at 9:13 AM
    BlueBabySound
  17. Apr 30, 2024 at 9:21 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    Yes, shock mounts are always low. Even on the current 5th gen the rear shock mounts only clear by 6" or so per my tape measure... I don't think that is what they are counting.
  18. Apr 30, 2024 at 9:30 AM
    BlueBabySound
    **supposed to be the lowest point on the chassis/suspension.
    But a lot of manf fudge their numbers and measure from somewhere else. *cough SUBARU *cough
  19. May 4, 2024 at 6:40 PM
    #49
    GunRunner
    GunRunner New Member
    2018 4Runner OffRoad
    The GX is not in the same category. It starts at 66K where as the 4Runner will be Mid 40s.
  20. May 4, 2024 at 7:07 PM
    #50
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Wait till they release the prices for the 6th Gen. The GX would start looking like a bargain.
    Shredder likes this.
  21. May 6, 2024 at 4:47 AM
    #51
    NoDak
    JR
    North Dakota
    i suspect the 4R will top out maybe 68k fully loaded, a mid line gx decently loaded is around 69-70k and top of the line is pushing 80k.
    edit : i wasnt even close
  22. May 6, 2024 at 5:27 AM
    #52
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    My wife really likes the look of the GX (she likes the look of Land Rovers even more but I put my foot down on that one ;) ) so maybe we may end up with both that and the 5th gen he he he ;)
    But she absolutely wants to have a 3 row for toting the kids and their friends around to sports and bringing the grandparents on road trips so it looks like the Lux version for her. I guess I could swap the huge wheels for 18s with ATs ?
    She seems to really like the white with tan leather...
  23. May 6, 2024 at 6:12 AM
    #53
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I believe the LC 250 has been available in Australia for years. They are all still Japanese built in the Lexus plant. Joys of platform sharing. It streamlines production and parts acquisition. I wish the 4runner had no 3rd row. One pointless platform share.
  24. May 6, 2024 at 8:32 AM
    #54
    HighSierraGuy
    HighSierraGuy New Member
    That's hard to believe as the 5th gen is so cramped already for me and the land cruiser looks larger inside on all the review videos. Where are you finding the official interior specs at?
  25. May 6, 2024 at 9:17 AM
    #55
    backpacker
    backpacker New Member
    2023 TRD ORP
    LC is too tall for my garage. Case closed.
    billum v2.0 likes this.
  26. May 6, 2024 at 10:51 AM
    #56
    nonuniform
    nonuniform New Member
    2021 TRD OR
    Toyota website.
  27. May 6, 2024 at 4:57 PM
    #57
    Here's some pics at the dealership near me..
    20240506_171601.jpg 20240506_171625.jpg 20240506_171644.jpg 20240506_171713.jpg 20240506_171805.jpg 20240506_171824.jpg 20240506_171911.jpg 20240506_171945.jpg 20240506_172019.jpg 20240506_172025.jpg 20240506_172045.jpg 20240506_174017.jpg 20240506_174029.jpg
  28. May 6, 2024 at 8:48 PM
    #58
    4R777
    4R777 New Member
    LC center console switches look super clean. Nice design.
  29. May 7, 2024 at 6:36 AM
    #59
    NoDak
    JR
    North Dakota
    definitely need some armor around those rear shocks lower mount points on the lc
  30. May 7, 2024 at 9:46 PM
    #60
    4R777
    4R777 New Member
    here?
