Toyota oil is legit
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Mar 4, 2024.
  1. Mar 5, 2024 at 11:11 AM
    #61
    backpacker
    backpacker New Member
    2023 TRD ORP
    Covered by manufacturer warranty? Not likely.
  2. Mar 5, 2024 at 11:14 AM
    #62
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    You know, technically, Toyota could reject your warranty if you didn't use TGMO or Mobil 1. Because they don't recommend anything else.
  3. Mar 5, 2024 at 11:23 AM
    #63
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Which is ironic considering most dealerships use neither of those brands getting their oil in bulk out of a drum when they service your vehicle. I was told I could request the Toyota branded oil but there would be a cost involved.
    I let them do one free service but I'll never let them touch anything again. A few thousand miles later I wanted to change it myself rather than getting their "free" service. What I found was the filter housing and drain plug were insanely tightened to the point of having to use a long breaker bar. They torqued nothing and only overtightened with an impact gun.
    Yotaholic[QUOTED][OP] likes this.
  4. Mar 5, 2024 at 11:30 AM
    #64
    backpacker
    2023 TRD ORP
    From p527 of the 2023 Owners manual: "Toyota Genuine Motor Oil" is used in your Toyota vehicle. Use Toyota Genuine Motor Oil" or equivalent to satisfy the following grade and viscosity. Oil Grade: ILSAC GF-6A multigrade engine oil. Recommended viscosity SAE 0W-20.
    Go Birds, 5thToy and Rob41 like this.
  5. Mar 5, 2024 at 11:30 AM
    #65
    Yotaholic
    Olympia, WA
    There are some non OEM things that they can get way with. Like Wipers, fluids, air filter, engine oil etc. I mean Toyota even makes Washer fluid if I am not wrong lol
    Rob41[QUOTED] likes this.
  6. Mar 5, 2024 at 11:47 AM
    #66
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    True. Pretty sure I've let them off the hook on most things when I installed the Maggie ;). Frequent fluid/filter and other maintenance in my future, lol.
  7. Mar 5, 2024 at 11:53 AM
    #67
    backpacker
    2023 TRD ORP
    Some excerpts from "What is Not Covered" on p. 14 of the 2023 Warranty and Maintenance Guide:
    • Alteration or tampering, including installation of non-Genuine Toyota Accessories
    • Lack of or improper maintenance, including use of fluids and fuel other than specified in the Owner's Manual
    • Installation of parts that are not Toyota Genuine Parts
  8. Mar 5, 2024 at 11:55 AM
    #68
    Yotaholic
    Olympia, WA
    Accesspries won't toast your motor and tranny lol.
  9. Mar 5, 2024 at 1:08 PM
    #69
    I think any heavy lifted 4runner on 34in tires at 85mph is close to full power.
    SlvrSlug and Yotaholic[OP] like this.
  10. Mar 5, 2024 at 1:10 PM
    #70
    Yotaholic
    Olympia, WA
    And now I am getting 67 lb KM3s lol
    djwantke likes this.
  11. Mar 5, 2024 at 1:16 PM
    #71
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Some say that helps keep the center of gravity down low ;)
  12. Mar 5, 2024 at 1:34 PM
    #72
    Just starting the engine requires full power. But who drives 85 in these? At least here it’s 65 so you get 70-75 max from me.
    LCJ77 likes this.
  13. Mar 5, 2024 at 1:36 PM
    #73
    Agreed.
    I abused and neglected my '03 (V8) and it was running strong at 257K miles. Most of Toyota's engines seem pretty bulletproof, including the 1GR.
    Ksny15, catbrown357[QUOTED] and LCJ77 like this.
  14. Mar 5, 2024 at 1:40 PM
    #74
    I'm always in favor of a low center of gravity. I even try to load heavy things as low as possible and ahead of the rear axle when possible.
    I'm about to drive 1400 miles in a few days. You can bet I'll be doing 80+ for a lot of it.
  15. Mar 5, 2024 at 1:42 PM
    #75
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Enjoy your trip!
    Yotaholic[OP] and Thatbassguy like this.
  16. Mar 5, 2024 at 1:51 PM
    #76
    70-75 for me. Highest limit we have in CA is 70. Either way, keep an eye on your moly counter.
  17. Mar 5, 2024 at 2:09 PM
    #77
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Why do I want to baby a vehicle with a shitty front diff bearing, by feeding it caviar? If anything, the 4r needs a beatin’
    3JOH22A likes this.
  18. Mar 5, 2024 at 2:16 PM
    #78
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 265K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    "Oil is oil." - Blackstone Labs FAQ page
    In other words, there is little to no significant difference in performance or longevity as long as the oil used meets the manufacturer's specs and is changed at the appropriate interval. Spending more makes you feel better but the engine couldn't care less. Always willing to listen if someone has non-anecdotal evidence to the contrary.
    Stoney Ranger likes this.
  19. Mar 5, 2024 at 2:20 PM
    #79
    Thanks!
    I just added a moly gauge, so I can make more informed decisions about oil change intervals. :D
    LCJ77, Yotaholic[OP] and 5thToy like this.
  20. Mar 5, 2024 at 2:21 PM
    #80
    Also safe trip.
  21. Mar 5, 2024 at 2:39 PM
    #81
    Toyota doesn’t make oil so the engineers wouldn’t have much say. Also do you have or want a metal oil filter housing cap?
    clonebuilder likes this.
  22. Mar 5, 2024 at 2:44 PM
    #82
    Yotaholic
    Olympia, WA
    This is getting silly now. Engineers give the requirements, and oil is made accordingly. Toyota doesn't make everything. Your transmission is not made by Toyota. Not sure about 5 speed, but 8 speed Aisins are in non Toyota vehicles too
  23. Mar 5, 2024 at 2:51 PM
    #83
    Yotaholic
    Olympia, WA
    If Toyota can approach Aisin and asks them to build them a transmission according to their requirements, why will you be surprised if Toyota approaches ExxonMobil and asks them to make a better oil? Toyota is a monster of a company, they can dictate.
    Ripper238 and LCJ77 like this.
  24. Mar 5, 2024 at 3:03 PM
    #84
    Engineering sends an email to purchasing saying they need 0/20 viscosity. Purchasing calls their oil brand contacts to get pricing and they shoot in the middle. There’s no dudes in lab coats brutally arguing about how much moly should be used in the engine.
    5thToy and clonebuilder like this.
  25. Mar 5, 2024 at 3:07 PM
    #85
    Yotaholic
    Olympia, WA
    SMH
  26. Mar 5, 2024 at 3:13 PM
    #86
    Yotaholic
    Olympia, WA
    This discussion reached the point of absurdity when folks say that things just happen randomly and there's no planning involved, and that Bob the oil guy knows more than the engineer who designed the motor.
    The software engineer writes the software, tells you what precautions you need to take so that your system remains safe. You're going to listen to that software engineer, or you're going to listen to Bob the IT guy lol
  27. Mar 5, 2024 at 3:30 PM
    #87
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Dam, I posted that Exxon/Mobil mfg Toyota Motor Oil. For years from 2008 (Toyota's 2 FJ's 1 Tacoma & 4Runner TRD OR) through now(my 2023 only has 1925 miles on it) I've only used Pennzoil 0-20w Fully Synthetic recommended by Toyota. I trade @ 90k or less ,SO I can't get into all this oil debate except , I feel if it's a repatriatable Oil mfg. & meets the std, you can't be wrong. Just my opinion. Yeah I have a little back ground on eng's. mainly turbine's.:cheers:
    Not sure what I'll use on this vehicle. ( my buddy has a fit that I go by mfg recommended time frame, i.e. 10k, I promised him I'd do R&R Oil @ 5k only because I hardly drive now)Like I always had posted If Pennzoil is good enough R. Penske Racing I'm good W/it. Also saw a comparison yrs ago W/Mobil 1 vs other oils in NYC Taxi's. Because of al the additives there wasn't ANY significant differences.? I
  28. Mar 5, 2024 at 3:39 PM
    #88
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Where is the Oil is Oil guy when you need him.
    Yotaholic[OP] and clonebuilder like this.
  29. Mar 5, 2024 at 3:58 PM
    #89
  30. Mar 5, 2024 at 4:05 PM
    #90
    Fishhead74
    Fishhead74 At Least I'm Enjoying the Ride
    Montana
    2020 Venture Nautical Blue/2023 TRD MGM
    dude. You’re a rude mofo.
