Toyo AT3 is here.
Discussion in 'Wheels & Tires' started by Rngr188, Mar 2, 2020.
  1. Oct 22, 2021 at 1:22 AM
    #211
    Acefaaace
    Acefaaace New Member
    Ariel
    2020 SR5 Premium
    Have my Toyo’s in a 285/70/17.
  2. Nov 1, 2021 at 9:46 AM
    #212
    EvilBeagle
    EvilBeagle New Member
    Nice! Are those the P-rated or the LT version of the 285?
  3. Nov 1, 2021 at 10:01 AM
    #213
    Acefaaace
    Ariel
    2020 SR5 Premium
    They’re P rated. I don’t tow and I don’t climb rocks. Easily able to handle trails and cleghorn in So Cal. When I eventually get new tires I’ll probably get these again in a LT C load, currently didn’t want heavy tires.
  4. Nov 1, 2021 at 12:18 PM
    #214
    EvilBeagle
    Totally agree! I was looking at these in both SL and LT C myself - will likely go with the C just for the extra peace of mind on the varied terrain down here in the Southeast, and I'll be (hopefully) making a trip or two out west next spring/summer.
    Rocksurfer and Acefaaace[QUOTED] like this.
  5. Nov 1, 2021 at 8:23 PM
    #215
    Acefaaace
    Ariel
    2020 SR5 Premium
    I love them, they're not as loud as KO2's and they're snow rated so I'll test them out with snowboard season rolling around.
    Rocksurfer likes this.
  6. Nov 14, 2021 at 4:50 AM
    #216
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    What load rating please.
    Thanks
    Acefaaace likes this.
  7. Nov 14, 2021 at 5:06 AM
    #217
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Doesn't look like he's been around for a while.
    'P' load.......easy to miss;)
  8. Nov 14, 2021 at 5:09 AM
    #218
    Burnt Taco
    Tucson, AZ
    Duh. Still half asleep... ZZzz
    Moon Landing[QUOTED] likes this.
  9. Nov 14, 2021 at 5:13 AM
    #219
    Burnt Taco
    Tucson, AZ
    Ideas on best load rating as compromise for lowest weight and maximum off road protection?
    Thanks
  10. Nov 14, 2021 at 5:31 AM
    #220
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Honestly, after purchasing and running 'E' load 285 TOYO's I think a persons driving habits running 'E' loads(or any heavy tire) has more to do with their fuel mileage than the weight of the tire. If you're a pedal masher, weight will matter. If you spare the whip at launch, you'll be fine. That said, if a specific tire you're looking at comes in a 'C' load, compare its weight difference to the 'E'. My opinion only.....others thoughts and mpg may vary;)
  11. Nov 14, 2021 at 5:34 AM
    #221
    Acefaaace
    Ariel
    2020 SR5 Premium
    SL load, will eventually get C load since I plan on getting these again, currently don’t need a heavier load for the stuff I currently do.
  12. Nov 14, 2021 at 5:54 PM
    #222
    E load tires are kind of like insurance, and many other things. You don’t think you need it until you need it. ✌️
    Moon Landing likes this.
  13. Nov 15, 2021 at 3:25 AM
    #223
    4R21
    4R21 New Member
    AK
    Land of Cheese
    My first set of TOYOs OC AT3. stock size tire.
    I am impressed so far. :hattip:
    I used to run Nokians ROTIVA AT on 17Rav4 before.
  14. Jan 1, 2024 at 6:16 PM
    #224
    4runnerboxer
    4runnerboxer New Member
    2023 trd off road premium
    How have they performed on wet pavement?
    (285s-70r17 117t rated)
  15. Jan 1, 2024 at 8:28 PM
    #225
    Mine have performed fine for an all terrain. Mine are load range C. It looks like you're looking at the SL's, which appear to have more siping than the LT's, so they should actually be better in rain and snow.
  16. Jan 3, 2024 at 3:08 PM
    #226
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Those are what I'm currently running on, 34 psi. We got some snow last winter, and my wife had to go into the hospital. I had to make several trips to/from to get her "stuff" she forgot to bring. Right in the middle of the worst snowfall. Those tires gripped like crazy. It's a 20 mile trip each way, but I had no problem. Oh the streets that weren't scraped, I just put it into 4WD HI, and they gripped even better, if possible!
    Those are my tires from now on, at least until a new version comes out. When I need new tires, the new version is for me!
    Pat☺
    4runnerboxer likes this.
  17. Jan 4, 2024 at 7:23 AM
    #227
    corncob444
    corncob444 New Member
    Does anyone have insight into why the C rated LT265/70R17s are heavier than the same size E rated tires? I was leaning toward the C rated option, even though they are a little harder to find in stock. However, with the C's having 2lbs more weight, the E's would theoretically be better for rotational weight and mpg but maybe a tad stiffer. Are the C's an older version/model that is made differently or in a different plant, maybe? Seems really strange that the higher load rating and likely thicker tire would be lower weight.
  18. Jan 28, 2025 at 10:12 AM
    #228
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Nice 4R
    I’m also looking to switch from 285/70 to 35x11.5. I can’t believe it fits underneath that’d be nice
  19. Jan 28, 2025 at 10:24 AM
    #229
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    No insight on the AT3 specifically but I did reach out to Nitto about the same question regarding their Ridge Grapplers.
    They told me it was due to the way the plies/ are laid out. Aka the construction of the tire. They wouldn't get more specific after I pressed.
  20. Feb 11, 2025 at 8:10 PM
    #230
    johnnyg182
    johnnyg182 New Member
    2019 TRD Pro
    2” lift - SPC UCA - 285s - RCI skids - C4 Gas Skid - C4 Sliders
    Anyone ever have sidewall damage from rock crawling in the AT3s? I was going to get the new Wildpeak AT4W in 285/75/17 C load but I’m getting nervous about them being 67lb. The AT3 C Load in the same size is 59lb. Thought the sidewalls were too tame looking on the Toyo but the weight savings may sway me. My KO2s have deep gouges in the sidewalls from rocks but never leaked or blew out. I usually air down to 13-14psi. Hoping someone has some experience to share. Thanks!
  21. Feb 11, 2025 at 9:18 PM
    #231
    I put a gouge in one of mine in 2020. It held air, so I moved it to spare duty. It's still holding air.
    LuLu likes this.
  22. Feb 13, 2025 at 1:22 PM
    #232
    johnnyg182
    2019 TRD Pro
    IMG_9794.jpg This is the type of damage I have on each of my KO2s. Pretty deep cuts but didn’t hit the cord. Wheels have taken a beating on the rocks too.IMG_9797.jpg
