Toyo AT3 is here.
Discussion in 'Wheels & Tires' started by Rngr188, Mar 2, 2020.
  1. Jan 23, 2021 at 5:32 PM
    #151
    OpBalance
    OpBalance New Member
    That seems about right. I think th skinnier tires are supposed to be around 42-44psi.
    The E load “harsh ride” is something that is severely overblown on these forums, mainly spouted off by people who have never had E’s. Glad you like them. I’m still torn between these and the Nittos in 255
  2. Jan 23, 2021 at 5:49 PM
    #152
    Here's what the almighty tire pressure calculator came up with. I'm sure a little extra is fine.
    OpBalance[QUOTED] likes this.
  3. Jan 23, 2021 at 5:55 PM
    #153
    Tuco S.
    Tuco S. New Member
    The Nittos look awesome. They are slightly larger than the Toyo at 33.3" vs 33.1" and 5 lbs heavier. I doubt they would rub on stock suspension, but who knows. I just had a slight rub on the left mudflap while turning onto a side street when I hit a valley gutter at 15 mph. That soft front suspension dipped just enough to briefly make contact. It's weighted down with 90 lb sliders, 200 lb driver and a full tank of gas. Also, it has a 3/16" lean to the left even unloaded in the garage, so....
    But for normal driving on oem Trail wheels, I think this size is good to go.
  4. Jan 23, 2021 at 5:57 PM
    #154
    Tuco S.
    Tuco S. New Member
    Cool thanks man! I was just spitballing the pressure at first, so this is great info.
  5. Jan 23, 2021 at 6:24 PM
    #155
    OpBalance
    Nice!
  6. Jan 23, 2021 at 6:26 PM
    #156
    OpBalance
    Yeah, I’m not concerned with rubbing, I’m lifted and will have Body mount chop and fender trim by then. Just have a hard time deciding between the Toyo At3, Toyo RT, Coopers and Nittos. I wish this size was more popular so we had more options. I’m sick of the 285 popularity haha
  7. Jan 23, 2021 at 6:57 PM
    #157
    Tuco S.
    Tuco S. New Member
    Yeah the selection in this size is definitely limited. I was also considering the Falken Wildpeak and Cooper ST Maxx (heavy!). The Toyos were the lightest and on sale so I rolled the dice. It almost seems like there are more MT than AT choices in this size.
  8. Jan 25, 2021 at 4:56 PM
    #158
    Lab Hiken
    Lab Hiken New Member
    2020 SR5 4x4
    I’ll more than likely will be pulling the trigger on these as well. I have my lift just need to put it on. I’ll be doing a 2”/1.5” hopefully I will kit run into any rubbing issues. I see in a later post you had some. We’re you able to see where it was rubbing?
  9. Jan 25, 2021 at 6:21 PM
    #159
    4runningMan
    4runningMan New Member
    New Mexico
    Do you know what the increase in diameter is over the OEM size?
  10. Jan 25, 2021 at 6:30 PM
    #160
    OpBalance
    Approximately 1.46” depending on brand of tires you’re comparing it to.
  11. Jan 25, 2021 at 9:11 PM
    #161
    4runningMan
    New Mexico
    Can you feel a difference in acceleration or power delivery?
  12. Jan 25, 2021 at 9:50 PM
    #162
    Tuco S.
    Tuco S. New Member
    Yes, there was like a 1 square inch mark on the "knob" that sticks out on the left front mudflap. It has only happened once when the suspension was compressed while turning. If it happens again, I may take off the mudflaps temporarily until the lift is installed.
  13. Jan 25, 2021 at 10:03 PM
    #163
    Tuco S.
    Tuco S. New Member
    The new tires are both taller and heavier (11 lbs heaver than oem), so they do have more rotational mass which makes them a bit harder to move from a stop, and a bit harder to stop while in motion. This has a small effect on acceleration, which is more noticeable going uphill. It also has a small effect on braking. Ironically, my fuel economy is about 0.5 mpg better since the install. I'm losing some fuel economy going uphill, but enjoying a slight gain on level ground and while going downhill. The truck really seems to coast like it's on rails, thanks to reduced rolling resistance (thinner tires) and greater rotational mass of the tires.
  14. Jan 26, 2021 at 7:42 AM
    #164
    Clayman14
    Clayman14 New Member
    Clay
    USA
    MGM TRD Pro
    Loving my new AT3
    gunsnob and travelinscout like this.
  15. Jan 26, 2021 at 8:30 AM
    #165
    travelinscout
    travelinscout New Member
    2020 TRD ORP MGM
  16. Jan 26, 2021 at 9:34 AM
    #166
    Lab Hiken
    2020 SR5 4x4
    265/70
  17. Jan 29, 2021 at 8:46 AM
    #167
    Lab Hiken
    2020 SR5 4x4
    Do you have any other pics from the side. Trying to see how much the wheel well gap is in the front and back.
  18. Jan 29, 2021 at 2:28 PM
    #168
    Lab Hiken
    2020 SR5 4x4
    What size tires? Any lift?
  19. Jan 29, 2021 at 2:43 PM
    #169
    285/70/17. 2.4"/1.5" lift.
  20. Feb 3, 2021 at 3:00 PM
    #170
    Lab Hiken
    2020 SR5 4x4
    Just ordered my Toyo Open County AT3. 255/80/17. After discounts, Price matching and Discount Tire buying my old stock tires out of pocket cost was 780. Mount, Balance and 3 year Certs. Installing lift next Wednesday Tire on Thursday.
    Tuco S. and Thatbassguy like this.
  21. Feb 3, 2021 at 3:45 PM
    #171
    Nice!! Post pictures! :)
    Tuco S. and Lab Hiken[QUOTED] like this.
  22. Feb 4, 2021 at 11:50 PM
    #172
    Tuco S.
    Tuco S. New Member
    Sorry, I just saw this post. I see you already pulled the trigger on a set for yourself. Methinks you'll love them! I haven't had any rubbing since the first and only time.
    I'll try to snap a few close-up pics of the front with the wheels turned and upload this weekend. Hopefully it will be good info for others.
    Lab Hiken[QUOTED] likes this.
  23. Feb 5, 2021 at 3:50 AM
    #173
    Lab Hiken
    2020 SR5 4x4
    What pressures are you running?
  24. Feb 6, 2021 at 5:55 PM
    #174
    Tuco S.
    Tuco S. New Member
    Finally got around to doing a chalk test. Mine is pretty close to oem loads for now. I have sliders installed, but those are only 45 lbs per side.
    A good starting range for the rear is 40-42. I wouldn't go over 42 in the rear unless you're loaded down.
    For the front I would say start between 41-43. Thatbassguy's calculator is pretty spot on.
    I'm now at 41 rear, 42 front.
  25. Feb 6, 2021 at 6:15 PM
    #175
    Tuco S.
    Tuco S. New Member
    Some close ups of the rear wheel well:[​IMG]
    Lab Hiken and Thatbassguy like this.
  26. Feb 6, 2021 at 6:21 PM
    #176
    Lab Hiken
    2020 SR5 4x4
    Do you have any of the front?
  27. Feb 6, 2021 at 6:22 PM
    #177
    Tuco S.
    Tuco S. New Member
    Front wheel well with wheel centered:
    Lab Hiken likes this.
  28. Feb 6, 2021 at 6:29 PM
    #178
    Tuco S.
    Tuco S. New Member
    Right front wheel well with full turn to the left:
  29. Feb 6, 2021 at 6:33 PM
    #179
    Tuco S.
    Tuco S. New Member
    Left front wheel well with full turn to the left:
  30. Feb 6, 2021 at 6:40 PM
    #180
    Tuco S.
    Tuco S. New Member
    Left front wheel well with @ 50-60% turn to the left. This is pretty close to where you are most likely to get rubbing on the mud flap if the front suspension is compressed. It's hard to tell in the photo but there is about a 1/2 inch gap between the tire's shoulder blocks and the mud flap:
