Towing with the 2024 4Runner V6
Discussion in '5th Gen 4Runners (2010-2024)' started by NeverTooLate71, Jun 17, 2024.
  1. Jun 19, 2024 at 12:44 PM
    mac1usa
    mac1usa New Member
    I think guys something to consider here also is even if you can tow some extra weight and feel comfortable consider that if you are unfortunately involved in an accident while towing there will be an investigation and I think many states you could be held be liable if your trailer and weight exceeds the capacities. Obviously we never want to see anyone hurt but also I would hate to see someone sued or held legally responsible for excess weight. We are responsible for the weight we tow and taking safety precautions
    Thatbassguy and mainerunr like this.
  2. Jun 19, 2024 at 1:23 PM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Tongue weight on a boat is often in the 5-8% range (from what I've read). And yeah, far less cross sectional area.
    The add on to this is your insurance may balk at paying as well...
    mac1usa[QUOTED] and Thatbassguy like this.
  3. Jun 19, 2024 at 2:21 PM
    Shanky
    Shanky New Member
    Everglades 211cc Yamaha F200 3.3L V6, custom Alum trailer. Fiberglass / Alum T-top. Boat Motor Trailer combo on Scales up at 4700 Lbs at Half Fuel. Add more gas / ice and I am at the 5000 lb limit. Boat has a 20 degree dead rise, so it has a lot of Hull for a short boat.
    kolter45[QUOTED] likes this.
  4. Jun 19, 2024 at 2:22 PM
    Shanky
    Shanky New Member
    Agree. Our tongue weight is slightly under 400 Lbs.
  5. Jun 19, 2024 at 4:43 PM
    GrantM64
    GrantM64 New Member
    Yea, Its a 4 season trailer that can take a beating unlike the Coleman Utah popup I had. I'm surprised that it was in one piece when I sold it. The forest service roads rattle the screws out of it.
  6. Jul 2, 2024 at 12:06 PM
    Windplr
    Windplr New Member
    Coos Bay, Oregon
    2022 ORP Lunar Rock
    I'm looking at a small (15ft total length), lightweight camper with a GVW of 2700lbs. Tongue weight at 10-15% (from the manufacturer) would give 270-400 lbs. Seems like the T4R would be ok with this setup. Any thoughts?
  7. Jul 2, 2024 at 2:42 PM
    I think you'd be fine. Use S4 and keep it under 65 mph, and take your time. Get a good brake controller, also, if the trailer has brakes.
    Windplr[QUOTED] likes this.
  8. Jul 2, 2024 at 6:19 PM
    2016Pro
    Easy peasy, 3500 easy
    Thatbassguy and Windplr[QUOTED] like this.
  9. Jul 3, 2024 at 7:07 AM
    mainerunr
    Maine
    '23 TRD ORP
    Get a good hitch with built-in sway control and set it up right.
  10. Jul 3, 2024 at 12:52 PM
    LastRide
    LastRide New Member
    2024 Limited - Classic Silver
    That should be fine. But keep in mind that the 2,700 lbs is completely dry and empty. Once you fill the water tank, add a couple of batteries, a generator and camping gear, it will weigh a lot more than that. Does it have trailer brakes? If not, look for one that does. And, as a prior poster said, keep it at 65mph or less. Better safe than sorry. If you've never had a trailer get out of control on you, let's keep it that way. It's not a fun experience.
    Justkelvin and Thatbassguy like this.
  11. Jul 3, 2024 at 2:42 PM
    Windplr
    Windplr New Member
    Coos Bay, Oregon
    2022 ORP Lunar Rock
    Actually the 2700 is the max GVW, with all add-ons, gear etc. The base unloaded weight is 1650 lbs. Sorry, I may not have stated this correctly. It does have brakes.
  12. Jul 3, 2024 at 2:55 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    I went with the Liberty kit. I didn't need the Elite offroad version. The only difference between a taco & 4runner with this kit is the wiring harness. So make sure its this one. They have a mounting kit too.
    https://www.redarcelectronics.com/us/landcruiser-sequoia-4runner-brake-controller-kit
    I have my dial at "4" right now. We went to 11 mile state park & it was the worse potholes I have ever driven. I did turn it up to 5 for that. When I can feel the braking is too much, I just turn the dial down. I also drive in S4!
  13. Jul 3, 2024 at 3:05 PM
    Windplr
    Windplr New Member
    Coos Bay, Oregon
    2022 ORP Lunar Rock
    I've pretty much decided on this kit. Unfortunately out stock, but I don't need it immediately.
    Anyone using electronic sway control? They mount on the trailer downstream from the brake controller, sense stability and apply braking as needed to get the trailer back in control. They are expensive, but if they really work it would be worth it.
    Thatbassguy and kolter45[QUOTED] like this.
  14. Jul 3, 2024 at 3:07 PM
    kolter45
    Denver
    Its worth it & they come back in stock quickly!
  15. Jul 22, 2024 at 7:19 PM
    Justkelvin
    Justkelvin New Member
    2023 TRD off road premium
  16. Jul 22, 2024 at 7:21 PM
    Justkelvin
    I just bought an off-grid expedition Saturday and pull it from Austin Texas to Oklahoma City it pulled it with no problem in fourth gear except on a couple of the biggest hills it pulled down a little that's searching to do in the shifting department and it got 14 miles to the gallon out of a 1800 lb trailer empty. But I plan on running it 6065 and not going through any big mountain that I know of so it should do just fine. You'll definitely need some Springs or some help in the back because tongue weight squat the s*** out of it
  17. Jul 22, 2024 at 7:40 PM
    Justkelvin
    I need some info on the Sumo spring, I have a 23 ORP with 33S and 2.5 lift in front and 1.5 inch in rear. The rear springs are squatting really bad with a trailer with 275 lbs tongue weight. I'm considering the Sumo Springs but dint know how the affect the ride with a lift on the rear. Did you get the 1400 or 1800 lb springs and how much room do you have without a load
  18. Jul 23, 2024 at 9:59 PM
    NeverTooLate71
    NeverTooLate71 [OP] New Member
    Bob
    2024 4Runner SR5
    "Off Grid Expedition" is the make and model of your Travel Trailer? Have you looked into a Weight Distribution Hitch to take out the "Squat" Also make sure your ball is at the correct height.
