Towing with a 5th gen
Discussion in 'Towing' started by MTgirl, May 16, 2016.
  1. Sep 20, 2019 at 1:32 PM
    JBTRD
    Jeremy
    Ohio
    2016 (The Real) Trail Edition
    Nope, my old man has a tundra and tows it with trailer brake, weight distribution, and all the other goodies. Minus the air bags. Holding off on those, he is going to trade his 16 tundra with over 100k miles for a ram diesel (1,000ftlb) and get a larger trailer. I just move the trailer with the 4runner around a camp ground where they have storage and hookup sites.
  2. Sep 20, 2019 at 2:07 PM
    PCRIDE4RUNNER
    PCRIDE4RUNNER New Member
    SUPER DUPER
    I was wondering if your towing that ! I would have like to get a larger trailer but limited with the 4R and storage will only fit a 16' on prem.
    JBTRD[QUOTED] likes this.
  3. Oct 11, 2019 at 7:03 AM
    new to 4runner
    new to 4runner New Member
    2018 4Runner SR5
    I have a Travel Trailer weighing approx 4K lbs I have E2 wd with sway control and brake controllerTrailer is 22ft long and about 10 ft tall
    Your height and wind resistance will be your largest battle.
    I have had no problems to towing this package with 2018 SR5 average Mpg 10
    Typically the runner sticks in 4th gear and doesn’t hunt for 5th.
  4. Oct 18, 2019 at 7:30 AM
    Liberty2019
    Liberty2019 New Member
    2018 4runner
    timbren suspension in back
    I just bought a camper- 3000 dry weight, 21' long. Its flat where I live, but when going over overpasses or a bridge, the 4runner goes to 4000rpm. then drops way back on descent. Is this ok? there is no "tow" button to lock the car in lower gear.
  5. Oct 18, 2019 at 8:21 AM
    If you drop it into sport mode it will show 4 on the indicator, you will have all gears up to 4. If you want 5th just bump it up. Hope this helps.
    Liberty2019[QUOTED] likes this.
  6. Oct 18, 2019 at 10:00 AM
    freealfin
    freealfin New Member
    Looking at the picture I'll say you are in no position to counsel anybody.
  7. Jun 29, 2020 at 12:01 PM
    DaveW
    DaveW New Member
    dave
    2020 Toyota 4Runner TRD Offroad
    I am not yet a 4Runner owner, I have a 2020 4Runner TRD Offroad on order that is supposed to arrive in August. I have towed extensively with my 2010 FJ Cruiser and find the Escape Trailers to be lightweight, high quality, and easy to tow. I have a 2013 Escape 19' that we purchased new and a 2013 Escape 15B that we purchased used a couple years ago. Both trailers are great, but the 15B is definitely a bit easier to tow. I am hoping that the 4Runner will have similar towing capabilities as the FJ. image6.jpg 20170820_070445.jpg
    Oldtoyotaguy, BestGen and mrmike7189 like this.
  8. Jun 29, 2020 at 7:35 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Cool trailers. I've been pleased with the 4Runner's towing. I put $80 firestone airbags in the rear coils and it's honestly easy to do and worth it if you plan to tow a lot, even with WD bars. I tow a teardrop without bars, but it does have brakes, and it's planted and easy.
    alittleoff likes this.
  9. Jul 11, 2020 at 7:31 PM
    Smalllake
    Smalllake New Member
    Rob
    2012 4runner limited
    Non
  10. Jul 11, 2020 at 7:35 PM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Check out the RedArc Tow Pro Elite V2 or V3 or something, it's super clean and has a Toyota specific plug mount for your dash.
  11. Jul 11, 2020 at 7:35 PM
    Smalllake
    Rob
    Non
    I would recommend the Tekonsha P3 has worked great in my 2012 4runner limited pulling a travel trailer loaded to about 3500 lbs, never taken into the mountains tho
    Oldtoyotaguy likes this.
  12. Jul 12, 2020 at 6:49 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    The big limitation of a 4 Runner is the short wheel base, when compared to say a Tacoma. Your Escape 15, imho, is perfect. Your Escape 19 is pushing it a bit. When everything is going well, it’s no problem. But when something happens and you need to take control of your vehicle, a trailer that is bigger than your vehicle will tend to make the decisions for you. Can it be done, though? Probably, as long as everything is perfect and predictable. When making decisions about towing, the focus is almost always on “can it do it”. But just because you can do something doesn’t mean you should do it. Insurance companies assess this if something bad happens, and call it contributory negligence.
    importman likes this.
  13. Jul 14, 2020 at 12:32 PM
    DaveW
    DaveW New Member
    dave
    Don't want to be disagreeable, but I have been towing the Escape 19' since 2013 with the FJ Cruiser which has a wheelbase of 105.9" (compared to the 4Runner wheelbase of 109.8") and have had absolutely zero issues with maintaining control of the trailer under a wide range of conditions (wet, wind, sudden braking, etc). I use a WD hitch and have a wireless brake controller installed. The Escape 19 and 15 are wonderfully designed trailers that are well balanced, lightweight, and tow well behind a mid-sized SUV such as the FJ. Given that the 4Runner is very similar (or slightly more favorable) to the FJ in dimensions and towing capabilities, my expectation is that the 4Runner-Escape combination will work out well. If you go onto the Escape Trailers Forum, you will also see that there are many 4Runner owners who are successfully and happily towing their Escape trailers with the 4Runner.
  14. Jul 14, 2020 at 4:51 PM
    Oldtoyotaguy
    Great, DaveW! It’s nice to know both trailers work well with a 4 Runner. You should know, since you’re using them. Escape trailers are well made and very light so they’re obviously a good choice.
    Smalllake likes this.
  15. Aug 18, 2020 at 11:32 AM
    DaveW
    DaveW New Member
    dave
    Pulled our small 15' Escape Trailer on the weekend for the first time with the new 4Runner TRD OR. Handled quite well and easily towed. 20200814_163621.jpg
  16. Aug 19, 2020 at 5:29 AM
    Oldtoyotaguy
    Perfect trailer for a 4 Runner! Your camping spot looks beautiful too.
    mrmike7189 likes this.
  17. Aug 19, 2020 at 7:08 AM
    DaveW
    DaveW New Member
    dave
    This camping spot was not terrible, but was actually in the "Overflow" campground in Jasper National Park in Alberta. There was a great views of the mountains, although much of this campground is like a big gravel parking lot. It is currently tough to get campsites in the National Parks as there are some closed campgrounds and those that are still open are very busy and mostly fully booked. Seems that Covid19 is causing people to go to their local provincial and national parks since it is challenging to travel out of country or even out of province on vacations.
  18. Aug 19, 2020 at 8:06 AM
    Oldtoyotaguy
    At least you have a nice vista of the mountains, DaveW! I’m envious. We had a B.C./Yukon trip planned this year and had to postpone it. A few of Ontario’s parks are open, and some National parks but anything close to population centres is full, just like everywhere. So far, we’ve just been doing day trips, and it’s been un uneventful summer. Which, during a pandemic and seeing the US covid situation is definitely not something to complain about!
  19. Oct 22, 2020 at 5:56 PM
    #49
    Pgh18Gen5
    Pgh18Gen5 New Member
    Chuck
    2018 Limited
    Tacoma trans cooler / Scangauge II monitor
    I"ve been towing my wife"s Rzr atv"s to go riding for about a year, with a 14-ft and then 18-ft utility trailers. Recently upgraded to this 2013 18-ft VRV toy hauler camper that makes the girls' lives in the wild really nice now. If you tow, you absolutely need a transmission cooler and no overdrive, and life is great in any terrain. I've towed for lots of years and just love this machine, and I have a lifetime drivetrain warranty and hope to get to 300k some day since 4Runners are #1 to get there.20200904_172444.jpg
  20. Oct 23, 2020 at 4:12 AM
    #50
    mikeymtbs
    mikeymtbs New Member
    19 TRD ORP
    We pull an InTech Flyer Explore with my 19 TRDORP. I use the RedArc TownPro Elite brake controller and it works excellent while having a factory look, fit and finish. My camper is 1900lbs unloaded and generally loaded it is ~2200-2300lbs - well within the 4Runner’s ability. It tows straight as an arrow at speed and requires no sway control or WDH. Just returned from a 2000 mile road trip to mountain bike in Missouri and NW Arkansas and both performed awesome.
    I did install Firestone air bags which helped immensely with the soft rear springs when loaded.
    I used 4th gear on long pulls but otherwise left it in Drive to do its thing. We averaged about 70mph and 12mpg.
    DRobs, Thatbassguy and Smalllake like this.
  21. Oct 23, 2020 at 7:09 AM
    #51
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    @mikeymtbs That RedArc TowPro Elite and the clean mounted knob are sweet, am I right? One of my favorite mods for pulling the teardrop.
  22. Oct 23, 2020 at 12:31 PM
    #52
    mikeymtbs
    19 TRD ORP
    Sweet for sure. It works great and now that RedArc has a 4Runner specific harness, it only takes 20-30 min to install.
    great mod!
  23. Oct 23, 2020 at 12:36 PM
    #53
    JediMasterYota
    JediMasterYota UnsettleDown
    Rob
    Richmond, VA
    2020 Super White SR5 Premium
    I’m gonna tow a Forrest River No•Boundaries 10.6 this weekend on a camping trip.
    I think it’s small enough (13’) and light enough (under 3k fully loaded).
    It seems like a great Overlander and I’m excited to test it out. We’re renting one for a trial.
    I’ll report back with pics and any news about how my 2020 did pilling it.
    Smalllake and fajitas21 like this.
  24. Oct 23, 2020 at 2:58 PM
    #54
    Pgh18Gen5
    Chuck
    2018 Limited
    A friend of mine pulls a NoBo 16.7 (dealer plan only) off road with her Gen5 and they absolutely love it.20191108_092639.jpg
  25. Oct 24, 2020 at 5:34 AM
    #55
    mikeymtbs
    19 TRD ORP
    We almost bought a NoBo 10.6 but the build quality on the one locally available was so bad that I couldn’t bring myself to spend the money. The ramp door wouldn’t line up and close, the switch was falling off, one corner of the roof rack had collapsed. The dealer was embarrassed and should have been.
    We ultimately came across, and bought, the Intech Flyer Explore. Similar style and size as the 10.6. Hugely better build quality, aluminum frame, etc. check them out.
  26. Oct 24, 2020 at 11:22 AM
    #56
    Smalllake
    Rob
    Non
    How much does that nobo weight?
  27. Oct 24, 2020 at 11:48 AM
    #57
    Pgh18Gen5
    Chuck
    2018 Limited
    It is just under 3500 empty and i think the single axle is rated for 5000 loaded
    I regularly tow between 2400 and 4900 depending on which trailer each trip, with no weight distributing hitch or sway, but i do own a tongue scale and check it every trip. My VRV gvw is 7000 but 3000 empty and i know my gear and keep it under 5000, and check on CAT scales every so often as a double heck of my math. I have firestone air bags but never installed them since loading right keeps my rear body drop under 1 inch almost every trip, which i also check every hookup
    The 4R does great but you need a trans cooler even on that low end. I monitor trans temps and can quote by load and ambient temp the peak trans temps ill hit. A Tacoma cooler from same year is almost a perfect boltup match except a bit of plastic trimming driver side air guide. Worked with toyota parts guy who is a good friend now to get set upbefore second time i toweed.
    A tricky note is T4Rs require brakes with trailer above 1655 lbms buried in owners manual, regardless that PA only requires them at 3000. If you get into an accident without running within T4R specs, insurance companies have a reason not to cover you, ive read on forums.
    Also as mentioned above, there have been River Forest and other brand complaints with build quality of individual units so check what you end up buying closely and dont take delivery if not fixed before you pick it up.
  28. Oct 24, 2020 at 11:56 AM
    #58
    Pgh18Gen5
    Chuck
    2018 Limited
    Forgot to paste this in.
    Best feature she loves is rear kitchen to keep floors clean to grab a bite or something she needs. I'm the same from my previous trailers.Screenshot_20201024-142840_Chrome.jpg
