Towing a 3,275lb camper?
Discussion in 'Towing' started by Maisie, Jan 30, 2021.
  1. Jul 3, 2023 at 2:20 PM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    Good to know. I hope to tow something other than a U-Haul trailer at some point.
  2. Jul 3, 2023 at 4:53 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Sounds like the 93 out of No. Vegas. Plenty of places to pass and get passed.
  3. Jul 3, 2023 at 5:02 PM
    alittleoff
    Steve
    406
    '16 TP
    That is absolutely true going through any big city. When I was slowly moving our stuff from SoCal to MT using the I 15, the worst parts were the 30 miles driving through Vegas and the 100 miles driving through the greater Salt Lake area. The best time for me driving through SLC was between mid-night and 3AM. I'm glad all that is over with.
  4. Jul 3, 2023 at 5:42 PM
    Danno
    Danno New Member
    Sierra Vista, AZ
    Yeah, that 95. The two-lane part I think, is 44 and 89 in CA and then more of the same going to the coast in Oregon.
    alittleoff[QUOTED] likes this.
  5. Jul 3, 2023 at 6:23 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Is the 3275# a dry or loaded wet weight?
    Do you know what the tongue weight is?
  6. Jul 4, 2023 at 8:10 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  7. Jul 4, 2023 at 9:37 PM
    BGH2023
    BGH2023 Luvs his 4Runner
    Front Range of Komarado
    Mentioning mirrors, what do folks use for extended mirrors for towing with the 4Runners? Pics, brands, etc...
  8. Jul 5, 2023 at 8:25 AM
    alittleoff
    Steve
    406
    '16 TP
    I made my own for my old '93 HiLux (now called Tacoma's) out of 1" sq. tube and 1/4"x 1" flat stock. Sorry no pics... pre flip phone days. lol
    They were hard mounted to the doors and could be removed in a couple of minutes with a 1/2" box wrench.
    Drivers side was a 12" extension and the passenger side was a 15" extension to see around the awning legs.
    Big ears yes, but I could see very well behind me. Back then I held a CDL, so it was a must for me.
  9. Jul 5, 2023 at 1:35 PM
    2016Pro
    I tow a 3k lb camper and don't even need a wdh hitch. It tows perfectly fine, level with no sway. The hitch company looked at it and wouldn't even install a wdh as it was complete unnecessary. It does have electric brakes so I do have a brake controller installed.
    Diverman62 likes this.
  10. Mar 4, 2025 at 5:11 PM
    Mathew 4R/rv
    Mathew 4R/rv New Member
    Stephen
    2022 TRD ORP
  11. Mar 4, 2025 at 5:29 PM
    Mathew 4R/rv
    Stephen
    2022 TRD ORP
    I have a 2022 4R TRD ORP and I tow a 2022 Sonic Lite SL 169 VRK 22ft RV.
    My Sonic has a UVW of 3,550lbs and GVW rating of 4,330lbs. I drive with empty tanks and try to keep loaded weight on or under 4,000lbs. I have a break controller and weight distribution hitch/bars. I drive in D but will use S mode on inclines or declines if needed.
    My 4R has absolutely no problems towing this rv trailer.
  12. Mar 10, 2025 at 9:11 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Unless it's a diesel, a pickup isn't going to get much better mpg (reasons in response to the next guy)
    From a pulling standpoint, weight is a bigger factor at lower speeds, at highway speeds, frontal area becomes a bigger problem...weight is still a factor but wind resistance and drag catch up fast.
    Properly set up trailer brake controller. That is all.
    Everything gets shitty mpg while towing (unless you're towing a popup). F150 pulling a 5600lb TT was about 11mpg...towing a 2000lb popup was about 18 (regular mpg with that truck was 19-20).
  13. Mar 10, 2025 at 7:44 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Do not overlook the hitch. Some swear by anti sway designed hitches. Others use simple hitches with great success. Double check tires & brakes (runner & trailer) , trailer wheel bearing and most importantly weight distribution inside the trailer. A handy DIY tongue weight measure scale set up is in attached screenshot. It uses a bathroom scale. One pound on scale is 4 pounds of trailer tongue weight - 4:1. Look it up on web.
