Tire Rotation - Easiest Method for DIY?
Discussion in '5th Gen 4Runners (2010-2024)' started by legend1011, Jun 10, 2024.
  1. Jun 12, 2024 at 5:29 AM
    #61
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    I do it the same way as Bassguy. Getting an electric impact is a luxury but makes it so much easier, my Dewalt electric even has a "bolt removal" mode that automatically slows down once they start spinning so you don't spin them clear off and send a lug flying. Other benefit of the impact (besides saving your shoulder) is that you don't have to worry about breaking them loose with the tire still on the ground, the impact action will take them off without even spinning the wheel.
    When you put the wheels back on, you can use the impact carefully but makes sure to first hand thread on each lug and then as noted just gently spin them snug with the impact. Lower the truck until hte tires just touch (not full weight on them) and use your torque wrench and torque them down in a star pattern.
    done.
    BTW, since I do this during hte regular 5k service the truck up on jack stands is a great time to change the oil and grease all the zerks.
  2. Jun 12, 2024 at 6:51 AM
    #62
    That sounds like someone trying to justify not owning an impact wrench. :D
    Thatbassguy and jharkin like this.
  3. Jun 12, 2024 at 6:59 AM
    #63
    Valid point. I generally loosen lug nuts with a breaker bar for that reason, then use the impact wrench to take them the rest of the way off.
    djwantke likes this.
  4. Jun 12, 2024 at 7:22 AM
    #64
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    You don’t have spend a small fortune to have some nut busting grunt. I was helping my son change out a steering box on his Dodge 1T and his nearly new 1/2” DeWalt pneumatic impact couldn’t bust loose a super tight pitman arm/steering box nut but as a last ditch effort my +25yr old thrashed 1/2” HF Earthquake wrench had no problem zinging it off, my son(mechanic) was blown away as was myself. The air compressor is the expensive part, but IMO every DIY guy should have one for many reasons.
  5. Jun 12, 2024 at 7:56 AM
    #65
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Yeah, I had the same questions when it came to adding extensions, but ultimately it had to be done. Almost works without the extension, minus your hand rubbing against the tire. However, I don’t need the extension with the breaker bar for loosening.
    Looking forward to seeing your fancy new black lugs
  6. Jun 12, 2024 at 8:28 AM
    #66
    That seems like unnecessary work.
  7. Jun 12, 2024 at 11:14 AM
    #67
    jgalt
    jgalt New Member
    An extension, coaxial w/ the socket won't alter your applied torque. But in this and all cases one should try to support the cantilever load this creates. Just lift the head of the torque wrench an equal amount to the down force applied to the handle. This way only torque is applied to the nut, w/o unwanted bending loads.
    backpacker likes this.
  8. Jun 12, 2024 at 11:45 AM
    #68
    Some of you guys are treating changing/rotating tires like brain surgery. It doesn’t need to be so hard and you don’t need to treat your truck like a delicate flower.
  9. Jun 12, 2024 at 12:21 PM
    #69
    Eubeenhadd
    Eubeenhadd Bit of a derp
    Indianapolis
    2005 T4R 4.7 AWD
    Spartan Locker, OME 885/895w/stiff Nitrochargers, 265/70R17 Encounter AT
    Spare to passenger rear
    Passenger rear to passenger front
    Passenger front to driver rear
    Driver rear to driver front
    Driver front to spare.
    This can be done with a single jack one corner at a time or with all 4 corners in the air. Lift the corner, break everything lose with a bar, zip things off with an electric, put the new wheel on, snug with electric, torque to spec with a torque wrench, drop that corner, move to the next. Not the fastest method, but all 5 tires wear evenly, you get more miles out of the set of 5, and you never end up with a 16 year old spare that doesn't hold air anymore because you thought it was best left fresh.
  10. Jun 13, 2024 at 5:13 AM
    #70
    jgalt
    jgalt New Member
    Also, it is good practice to clean rust off of all surfaces which mate w/ the rim to minimize runout.
  11. Jun 13, 2024 at 7:51 AM
    #71
    HuskyMike
    HuskyMike New Member
    Good point. I started doing that after watching a brake job video where they recommended the same thing.
  12. Jun 13, 2024 at 10:00 AM
    #72
    jgalt
    jgalt New Member
    Yep, the rotor to hub interface. It all makes sense. Sometimes the little things can make a difference. Like turning a threaded fastener the opposite direction first to allow it to "drop" into the first thread. This is especially important on self tapping screws in plastic upon reassembly.
