Tire research overload
Discussion in 'Wheels & Tires' started by McSpazatron, Jul 6, 2023.
  1. Jul 14, 2023 at 8:01 AM
    #61
    Just sayin.
    djwantke likes this.
  2. Jul 14, 2023 at 9:19 AM
    #62
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Do you guys typically have good experience with Toyos? I bought some highway tires for the Tacoma a few years ago, worst tire I ever experienced (worse than the Dunlop Grandtreks, honestly), and it turned me completely off of the brand.
    Curious if I got unlucky, or if their quality is in fact hit or miss.
  3. Jul 14, 2023 at 9:37 AM
    #63
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    :bowdown:, For a e rated, do you think they ride stiff? I had e rated wildpeak at3w on my old jk and they where soft compared to the cooper at3s I had before. I'm probably going to be ordering the toyo trail rt in size 255 80 17. With the beefy side walls id image they appear wider.
  4. Jul 14, 2023 at 1:06 PM
    #64
    To be honest, I don’t notice it being stiff but everyone is different. They ride a lot better than the Falken M/T’s i took off.
  5. Jul 14, 2023 at 1:16 PM
    #65
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I had the ATx on my F150 and they hydroplaned wicked with about 20k miles on them. Terrible wet traction too (maybe not as bad on a 4runner since it's got way less power and more weight on the rear end but Falken AT3W were light years better on the F150 than the ATx in the rain). They were ok in the snow.
  6. Jul 14, 2023 at 2:09 PM
    #66
    Interesting. I find these are great in the rain on this vehicle, never once had a hydroplaning issue. I'm past 40k.
  7. Jul 14, 2023 at 2:10 PM
    #67
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Big Daddy's!
    SlvrSlug[QUOTED] likes this.
  8. Jul 18, 2023 at 8:21 AM
    #68
    mainerunr
    Maine
    '23 TRD ORP
    Yeah, its odd but maybe difference alignment settings between the two vehicles contributed to the hydroplaning?. I'm sure the wet traction issues (other than the hydroplaning) can easily be explained by the light rear end and extra 100hp the F150 has. curb weight on that truck wasn't much higher than the 4Runner but even as a crew cab, the back end was light.
  9. Jul 26, 2023 at 9:25 AM
    #69
    NEguy
    NEguy Some random dude
    NH
    2018 SR5 Prem
    Well... Seems appropriate I chime in on my Toyos today.
    I have been noticing lately mine are looking pretty worn. Picked up a screw this weekend and brought it in to have it plugged yesterday. They told me I should replace the fronts as they are pretty worn with a little cupping along with some 'dry rot'/cracking (which I noticed as well). The worst part about this is they only have about ~26K on them, not quite two years old and I have been religious about rotating them since new...
    That said, I am guessing this is partially to be expected as maybe the Toyo Open Country AT3 is not meant to be primarily a road tire...? However, I expected more than ~26K out of them for sure. Probably need to be honest with myself about putting on the tires needed for the application. i.e. occasional dirt roads, mtb access, trailhead access and unplowed roads in winter. Or, if I am willing to spend the money on 'cooler tires' and having them wear quicker etc... Old man trying to not totally look like one.
    Researching Generals now as I had very good luck with them on multiple vehicles in the past including a Honda Odyssey which are known for eating tires up and on my kids cars etc.
  10. Jul 26, 2023 at 10:13 AM
    #70
    @NEguy hey that sucks, I actually haven't heard much negative feedback regarding Toyo's. I just like that they're the official tire of the UFC lol. My brother has new Toyo's on his GMC Elevation, time will tell.
    I highly recommend General Grabbers. I almost A/TX's, but went with Mickey Thompson ATZ's. Mickey's have been unreal, load E tread barely worn after two years as my wife and kids local daily, and few offRoad + family trips.
    People are going to recommend KO2's, or the "new" KO2: Falken Wildpeaks. Forget those, break the mold
    Goodluck
    HuskerRunner and NEguy like this.
  11. Jul 26, 2023 at 11:14 AM
    #71
    Try Falkens. Ive never been disappointed with mine and have gone 50k on them before replacing
  12. Jul 26, 2023 at 11:19 AM
    #72
    4R777
    4R777 New Member
    I have Toyo Open Country AT3 currently on my 4th gen.
    Been to 10 National parks, all through the Sierras from WA to Socal, CO, MT, NV and a bunch of other outdoor and overland / offroad spots, lots of snow every winter for snowboarding trips. I am very surprised how durable they are. I am finally about to replace them and have squeezed every last mile out of these. Will be getting same tire again.
    kmeeg[QUOTED] likes this.
  13. Jul 27, 2023 at 12:42 PM
    #73
    NEguy
    NH
    2018 SR5 Prem
    Just curious, how many miles have you gotten out of them?
  14. Jul 27, 2023 at 1:35 PM
    #74
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    After all these years of car tire research and finally finding the best of the best in a car tire, going to the 4Runner is a whole different animal. I needed something good in snow, good in rain and can do some off roading with the chance of mud. So close to buying K02's but they just didn't fit my wide ranging needs and the rest fell short.
    I decided on Duratracs with hesitation since my old Goodyears (Non Duratraces) sucked. The Duratracs came highly rated by all my construction, plow and work friends so I decided to go with them and they have been perfect. Awesome in the snow and mud decent in the rain and are not that noisy for a borderline mud tire. Have then going on 2 years now and very little tread wear.
    djwantke and Stoney Ranger like this.
  15. Jul 27, 2023 at 3:51 PM
    #75
    Nice great to know! 2 years ago I waited months and months for Duratrac Wranglers I purchased to arrive. Only to get a call advising me the tire eta had changed to unknown due to manufacturing and supply chain failures. Had to pull the plug, start all over and ordered Mickey Thompson Baja ATZ's. Sometimes, things happen for a reason, cuz I'm in love with Mickey's now :)
    Trail Runnah likes this.
  16. Jan 6, 2024 at 10:11 AM
    #76
    load E sidewall
    But these are Baja ATZ's superceded by Baja Boss
    Hard to tell the thickness and aggressiveness difference, without tool
  17. Jan 6, 2024 at 12:16 PM
    #77
    Tried playing in the 3” of snow just got, but the Falkens just grip too much in 4wd. I had to go to 2wd and turn the traction control off to have a little fun. Lol!
  18. Jan 7, 2024 at 9:15 AM
    #78
    lyodbraun
    lyodbraun New Member
    Northwest Ohio
    2018 4RUNNER
    New or old Falkens ?
  19. Jan 7, 2024 at 9:24 AM
    #79
    20k on this set
  20. Jan 8, 2024 at 8:57 PM
    #80
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    I just put the Geolander X-AT (stock size, load range C) on my new TRD OR. I've only had them on there for 3 days so I can't exactly give you a review. I really like the tread pattern and the fact that they have 3 ply sidewalls.
    I had the Toyo Open Country AT3's on my Subaru for about three years. They seemed to be ok but for the last year or so they have gotten extremely loud. The main reason I wanted to try a different tire on the 4R.
    mrmike7189 and NEguy like this.
