Tire choice
Discussion in 'Wheels & Tires' started by Durs4runner7, Jun 5, 2023.
  1. Jun 19, 2023 at 4:29 PM
    I have a friend with a Tacoma whose AT3's wore super fast. I wonder if they had a run of bad rubber or something.:notsure:
    Otherwise, I would say 5k rotations help.
    Stoney Ranger likes this.
  2. Jun 19, 2023 at 5:08 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I
  3. Jun 19, 2023 at 5:55 PM
    TrailSpecial22 New Member
    PA
    i rotate mine religiously every 3000 miles and they are SL.
    i take them down pretty far, but not too far to loose traction in the rain
    auspilot[QUOTED] and Thatbassguy like this.
  4. Jun 26, 2023 at 7:13 PM
    Chrispchicken9
    Chrispchicken9 New Member
    Went with Michelin LTX A/T2 tires for my 04 tacoma with currently 90k miles on them and still plenty of tread. The rubber is starting to have little cracks a bit but they're 7 years old, which I think technically is past the life expectancy.
    Been so happy with them there is no question I'll be adding the LTX A/T2 to my '16 4runner when the current set is ready.
    They're not as aggressive as most all terrain tires but they have it where it counts without compromising practical drive-ability.
  5. Jul 8, 2023 at 1:51 PM
    drlngus
    drlngus New Member
    265/70/17 Tires, 1" Daystar Leveling Kit
    How did you like the Nito Grapplers? Are they quite? I am thinking of these for my 06' SR5.
  6. Jul 8, 2023 at 2:32 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    275's, load C. Thailand tires. 40 psi on the road, 25 psi on dirt roads and 18 psi rock crawlin'. Rotate 'em every oil change (5k) I've heard some of the Falkens are wearing very fast. Mine are wearing as expected. I'll get 60,000 out of them easy. I do a 5 tire rotate. I'll probably get the same tire in a 285 when the time comes.
  7. Jul 8, 2023 at 4:49 PM
    To me, a three mpg loss is a pretty big deal. Even if you don't care about the money, that's about a 60 mi loss in range if you fuel up around 20 gallons.
  8. Jul 8, 2023 at 6:19 PM
    PA
    thats why I said 1-3. I may lose 3 heading to upstate Pa on a 3 hr drive for hunting season, loaded up with gear and 3 adults.
    Now driving to cape may nj from my house in Pa last week ( 2 1/2 drive), i averaged 19.3 mpg with 2 adults + kid and loaded for a 2 week vacation.
  9. Jul 18, 2023 at 8:29 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Running stock size Toyo AT3's in a load range E right now. Cannot compare to stock though because I never drove it with the stock tires, these went on before I picked it up. I'm good with the way it handles and drives.
    I dunno either although last set I ran was on my F150...and I won't run them with less than 3/16 tread in the winter (if I would, I could probably have gotten another 10-15k out of every set of tires I've run in the last 20 years. buy in the fall, run them 2 winters, buy new tires right before the 3rd winter, usually 40-42k miles)
  10. Aug 6, 2023 at 4:55 PM
    Fairway2Heaven
    Fairway2Heaven New Member
    Alabama
    '21 SR5P 4WD, Nautical Blue
    Yota Expedition Grille Smoked Amber Raptors Anthracite Grey Wheel Dip Black Emblem Overlays Black Roof Rails (Painted) AuxBeam Amber DRLs Lasfit & Husky Floor Mats Side Window Guards
    These Michelin would make the most sense for my next tires given 95/5 is highway or paved county roads even though I'd like to do more trails in the future. I'd prefer a more aggressive look like BFG or Falken. One would think that given Michelin's status as a premiere tire maker, that their engineers would figure out how to add some sporty, aesthetic tread to the outer edge without jeopardizing that Michelin performance. An aggressive looking Michelin AT with the expected Michelin performance would be a huge hit IMO.
    Accelerator likes this.
  11. Aug 9, 2023 at 9:32 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Just today at my tire place to have my SCS wheels removed from my 21 tundra Pro. He had the new Falken R/T in stock. Real nice tire I may put on my 23 4runner Pro when it comes in. Only downside they only come in E rated tire. Plenty time to decide.
