Throttle Response Units…. Thoughts?
Discussion in '5th Gen 4Runners (2010-2024)' started by MisterFlabby, Jun 12, 2024.
  1. Jun 13, 2024 at 12:55 PM
    #91
    2016Pro
    Incorrect
  2. Jun 13, 2024 at 12:56 PM
    #92
    Lost Woods
    Lost Woods New Member
    Would you like to elaborate? I've got some CE PhD friends that would love to hear your dissertation on the topic.
  3. Jun 13, 2024 at 12:57 PM
    #93
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    I have a sprint boosted but would love to do a tune. Last time I checked I would have to drive across border to USA to get it tuned. So if there is any tuner for a 4 Runner in Toronto area please let me know, I will crawl through the ridiculous traffic to get it done.
  4. Jun 13, 2024 at 12:58 PM
    #94
    2016Pro
    Throttle controllers do reduce the lag time, that is one of their biggest benefits. They do not increase hp, anyone who says otherwise is incorrect
    2Toys and RUNNER4DAN like this.
  5. Jun 13, 2024 at 12:58 PM
    #95
    Lost Woods
    How? Spare me no technical details.
  6. Jun 13, 2024 at 1:00 PM
    #96
    2016Pro
    There is Lots of information out there on how they accomplish the reduction of throttle lag.
  7. Jun 13, 2024 at 1:06 PM
    #97
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Dude the whole reason throttle response units exist for sale is because they do a thing. You seem to be arguing they don’t do that thing. There’s no placebo. There is misconception by owners about what the unit is actually doing and not doing, yea.
    2016Pro likes this.
  8. Jun 13, 2024 at 1:08 PM
    #98
    2016Pro
    It's ridiculous isn't it? Too many internet posters that don't have a ......... clue. Smh
  9. Jun 13, 2024 at 1:16 PM
    #99
    Lost Woods
    [citation needed]
    It's funny, all I can find is marketing sheets did you have something better?
    They do a thing, but it's not what people think it is. Vague marketing claims are a hell of a drug.
    "Throttle response" does not mean it makes the ECU respond faster, it means that for every degree you push the pedal, you get a greater value forwarded to the ECU. Instead of sending the signal for 25% at quarter throttle, you instead get 40% or 50% or whatever it's programmed to send. It's "increased response" means you are getting more power at the same pedal angle, but there is zero difference between that and moving your foot to send that throttle angle manually.
  10. Jun 13, 2024 at 1:17 PM
    #100
    @2016Pro That is true, but I will day the whippersnapper isn’t some kinda poser at all - we just may have small disagreements on particular things sometimes.
    2016Pro likes this.
  11. Jun 13, 2024 at 1:19 PM
    #101
    2016Pro
    He's a hopeless dolt this one lol. Smh
  12. Jun 13, 2024 at 1:20 PM
    #102
    2016Pro
    Yes, not him the other...... well you know
  13. Jun 13, 2024 at 1:23 PM
    #103
    2021venture
    2021venture New Member
    Todd
    2021 Venture
  14. Jun 13, 2024 at 1:23 PM
    #104
    Lost Woods
    Don't you have an unattended bridge somewhere or have you finally rubbed enough brain cells together to contribute to the conversation?
  15. Jun 13, 2024 at 1:24 PM
    #105
    Derek:
    Throttle response units exist for sale is because they do a thing
    Lost Woods: They do a thing, but it's not what people think it is.
    right.
    2016Pro likes this.
  16. Jun 13, 2024 at 1:26 PM
    #106
    2016Pro
    At this point it's entertainment lol. What a happless dolt lol
  17. Jun 13, 2024 at 1:26 PM
    #107
    Lost Woods
    I'm confused are you saying that I'm right or wrong?
  18. Jun 13, 2024 at 1:27 PM
    #108
    Haha
    reminds me of Ben Shapiro’s funny use of the term “dolt”, and phrase “that is correct”
    2016Pro[QUOTED] likes this.
  19. Jun 13, 2024 at 1:27 PM
    #109
    Lost Woods
    Yeah fuck me for trying to stop the piss poor information that radiates from these threads.
  20. Jun 13, 2024 at 1:28 PM
    #110
    Right, in that you’re agreeing with essentially exactly what I just said.
    Wrong, in my opinion, in how much of an expert you and your genius friends are.
    2016Pro likes this.
  21. Jun 13, 2024 at 1:30 PM
    #111
    2016Pro
    Yes, what's that saying? You can't fix stupid.
  22. Jun 13, 2024 at 2:11 PM
    #112
    backpacker
    backpacker New Member
    2023 TRD ORP
    The problem is that people are talking about two different lags.
    1. Lag between pedal push and message to throttle
    2. Lag between pedal push and some acceleration threshold of interest.
    Any controller in a causal system (i.e. one that can be implemented without time travel) has non-zero processing time, so a controller can not get a message to the throttle any sooner than the system did without it. **
    However, the characteristics of the engine are such that despite the throttle getting the message a hair later, a well-designed controller can enable reaching the acceleration threshold of interest sooner for the same pedal input across a wide range of pedal inputs.
    ** Note - a tricky controller could allow the unfiltered pedal message to reach the throttle undelayed and send an adjustment instants later. Under that circumstance tricky controller could tie the unmodified system for first message and for an instant system performance of the modified and unmodified systems could be the same. This version of controller would also just result in behaving like a regular gas pedal if it failed.
  23. Jun 13, 2024 at 6:38 PM
    #113
    Squatting Pigeon
    Holden
    North Texas
    I’ve ran the Ultimate9 throttle controller on my last two tundras and loved it. Ordered one for the 4R last week and will be installing it this weekend :thumbsup:
    2016Pro likes this.
  24. Jun 14, 2024 at 7:00 AM
    #114
    STrooper
    STrooper Let’s Go Places!
    How much was it? That literally looks like the one in Amazon for $45-$50.
  25. Jun 14, 2024 at 7:09 AM
    #115
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
    2016Pro likes this.
  26. Jun 14, 2024 at 7:35 AM
    #116
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    I recently got to drive a fifth gen with this gizmo on it. It was a 2021 model. I didn’t see what the big deal was. I’m not interested in getting one. I think it’s all smoke and mirrors. My 2022 SR5 Premium 4WD has plenty of zip for me the way I drive, old man (68) that I am. LOL.
    RUNNER4DAN and whippersnapper02 like this.
  27. Jun 14, 2024 at 8:20 AM
    #117
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    Two questions:
    1. Does the ECU factor in the rate of change of pedal position in determining how far/fast to open the throttle?
    2. Is the speed that the throttlebody opens controllable (and a sub-question, is it is capable of opening faster than if you slam your right foot to the floor)?
    If the answer to either of those is no, then the difference CANNOT be any more than the time it takes for you to plant your right foot to the floor.
    The ECU looks at a lot of factors, if it sees 0-90% throttle in 0.1s vs 0.2s and behaves differently then maybe these do something, otherwise, you get that signal there 0.1s faster and from there it is exactly the same.
  28. Jun 14, 2024 at 8:34 AM
    #118
  29. Jun 14, 2024 at 9:27 AM
    #119
    2016Pro
  30. Jun 14, 2024 at 9:28 AM
    #120
    I thought it had been debunked that these things can eliminate throttle lag?
    The only thing they can do is make the ECU think you're pushing the throttle down faster than you actually are, giving the impression of reduced lag. The same thing can be accomplished by slamming the gas to the floor
    RUNNER4DAN and djwantke like this.
