Those with the Magnuson Supercharger...
Discussion in '5th Gen 4Runners (2010-2024)' started by hossler1788, Mar 27, 2023.
  1. Jan 8, 2024 at 6:33 AM
    #61
    I don't know for a fact but the experts say that Procharger makes more power the Magnuson unit. There are more tacomas with the procharget than 4R. The thing with Magnuson is that these units seem to run a little colder and that's why they are able to offer 3 yr warranty on the unit and the 4R itself, so something there. I think the asthetic's of the Maggie are better than the procharger. And Magnuson has done more marketing as well and I don't see the other guys going at it either. That's what I see....I could be wrong though.
  2. Jan 8, 2024 at 6:58 AM
    #62
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    The procharger probably makes less low end power and more high end power than the mag due to how those centrifugal blowers work. with procharger you need to relocate the primary battery and it takes up a lot more space in the engine bay.
    The procharger probably has possible pulley upgrades and more potential if you want to drag race or something. Mag seems to be already about maxed out from factory other than optimized tuning.
    If you aren't doing tons of mods like dual battery, winch etc procharger would make more power for fast highway driving. If you want better low end but less top end power and OEM like fit/finish and to maintain engine bay space the mag is better.
  3. Jan 8, 2024 at 12:09 PM
    #63
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    I just wish that someone made a charger like the Magnuson, but without the air-to-water manifold and cooler that requires a pump (easier to install). Just the blower with a typical FMIC that doesn't require a cooler pump would be a good alternative.
  4. Jan 8, 2024 at 12:31 PM
    #64
    Wouldn't that be a poor man's cold air intake?
  5. Jan 8, 2024 at 12:58 PM
    #65
    jdm-v35
    jdm-v35 New Member
    CO
    All of the roots style blowers are integrated into the intake manifold of cars. either they run air to water coolers or no cooler at all. air to air intercoolers only work on external blower units such as procharger, vortech or rotrex.
  6. Jan 8, 2024 at 4:46 PM
    #66
    hossler1788
    hossler1788 [OP] Turtle
    Joshua
    Central Pa
    2020 4runner
    What was the reason you got rid of the explorer st? They had one at the dealer when I was checking out a raptor. I thought it was pretty cool looking, are they problematic like ever other ford?
  7. Jan 8, 2024 at 5:49 PM
    #67
    bronzestar1
    The 5th gen 4R is the end of an era, so I figured I should get one before they're all replaced by the 6th gen. I'll be retiring for good in a couple of years, and I think the 4R will be a better choice as my last new car as opposed to the ST. I didn't have any issues with my ST over 27K miles, changed the oil and rotated the tires every 5K miles, and I didn't drive it like I stole it. I've owned two previous 2.7 Ecoboost Fords (Fusion Sport and an F150), and never had any issues with either one. The 3.0 is a bigger 2.7, as opposed to a smaller 3.5, so that definitely worked in its favor.
  8. Jan 10, 2024 at 1:34 PM
    #68
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  9. Jan 10, 2024 at 1:35 PM
    #69
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
  10. Jan 23, 2024 at 7:55 AM
    #70
    Justkelvin
    Justkelvin New Member
    2023 TRD off road premium
    I've been thinking about getting one and after reading first page of warranty I knew it would be an act of God to get anything warranted. You just have to decide if the outcome is worth the risk. Magnuson is pretty much a solid power source albeit overly priced just know going in you're pretty much on your own. What gets me is the boast about how someone with moderate skills can do it in their garage in a weekend but like you point out void the warranty
  11. Jan 23, 2024 at 8:43 AM
    #71
    flight
    flight New Member
    Trust me, having an air to air is a royal PITA on a 4runner
    Rob41 likes this.
  12. Jan 23, 2024 at 10:39 AM
    #72
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    I did the Magnuson install on my 4Runner. What makes you think not having an air to water system is easier? The installation of the electric pump, hoses and inter-cooler took me maybe 30 minutes. If that aspect is giving you pause, I strongly suggest you consider having a professional install whatever you decide.
  13. Jan 23, 2024 at 11:13 AM
    #73
    bronzestar1
    Because you don't have to remove the intake manifold with a system like the Procharger, or wire up a pump for the air-to-water intercooler...
  14. Jan 23, 2024 at 11:32 AM
    #74
    flight
    flight New Member
    Virtually every maintenance task requires you to pull the intercooler plumbing or the entire head unit with the procharger setup.
    Alternator? Pull the headunit off.
    A broken serpentine belt on the trail turns into a serious struggle. Hope you didn't create any intake/boost leaks. It becomes massively worse if you are running the belt super tight.
    The saving grace with the procharger setup is that you can yank the whole thing off in about 10 minutes for a lot of these tasks.
  15. Jan 23, 2024 at 1:08 PM
    #75
    jdm-v35
    jdm-v35 New Member
    CO
    If designed correctly, air-to-water intercoolers are much more efficient for multiple reasons. The shorter the piping is the less lag there is, and cooling efficiency is better. Water conducts heat 25x faster than air, so it makes the system much more efficient and can be smaller. Also removing the intake manifold is like 8 bolts so it's not that difficult. Centrifugal superchargers are also not ideal for low speed offroad use at low RPM's. They would be nice in a baja type truck, but not in situations with most use below 3k rpm's.
    Rob41 likes this.
  16. Jan 23, 2024 at 2:06 PM
    #76
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Meh, there's a YouTube video of a long term review where after many miles the belt pulley failed while way out on the trail. His 4Runner still drove just fine till he got to a local parts store.
    The saving grace with the Magnuson is it develops power far lower where you actually need/want it. The procharger is great if you always maintain much higher RPM than the Maggie. There are many high mileage, long term reviews of the 4Runner with a magnuson. I haven't seen any long term reviews of a 4Runner with a Pro-charger. YMMV ;)
    If you think you'll like a Pro-charger more than a Maggie, please do it and give us your first hand thoughts on your 4Runner.
    jdm-v35 likes this.
  17. Jan 23, 2024 at 3:18 PM
    #77
    flight
    flight New Member
    I have experience installing both the Procharger and the mag on 4runners
    My post was pointing out how much of a pain the air to air ic is to deal with on the procharger.
    No ones getting off the trail with a broken serpentine belt
    jdm-v35 likes this.
  18. Jan 23, 2024 at 9:45 PM
    #78
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    You are incorrect. The Magnuson supercharger for the 4Runner uses an independent serpentine belt completely separate from the OEM belt.
    Skip to 1:31 in this video: https://www.youtube.com/watch?v=jB2BjK_iSmo
  19. Jan 24, 2024 at 6:07 AM
    #79
    flight
    flight New Member
    I was referring to the oem serpentine belt, I've installed both a procharger and a Magnuson on a 4runner and am unfortunately too familiar with their belt setups.
    The Magnuson has the better package for an off-road vehicle all around, there's too much flopping around with the pc air to air intercooler was my original point.
    Arguably the Magnuson is also easier to install.
  20. Apr 9, 2024 at 10:24 PM
    #80
    MIA2DFWRunner
    MIA2DFWRunner New Member
    2020 4Runner Venture
    I called Toyota recently and they said they would not install this for me and never heard of it. Which one did you go to?
  21. Apr 9, 2024 at 11:13 PM
    #81
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Regear to 4.88 instead, it is less expensive and does the job. My truck with 4.88 tears through mountain passes
    runnerjimmy likes this.
  22. Apr 9, 2024 at 11:29 PM
    #82
    Don’t go to the dealer for aftermarket parts. They don’t even know factory parts.
    CalcityRenegade, Justkelvin and Rob41 like this.
  23. Apr 10, 2024 at 6:07 AM
    #83
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    Where can one learn more about this re-gear thing. Does it give you more torque, is it ok to do with stock size tires, etc...
  24. Apr 10, 2024 at 6:12 AM
    #84
    Yotaholic
    Olympia, WA
    4Runner is a heavy truck and 3.73 gear ratio from factory is pretty pathetic. I wouldn't mind regearing a stock 4Runner. Look into 4.56. I went 4.88 because I have armor and large tires
    sympley76[QUOTED] likes this.
  25. Apr 10, 2024 at 6:16 AM
    #85
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Yotaholic and sympley76[QUOTED] like this.
  26. Apr 10, 2024 at 6:46 AM
    #86
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    It's not that heavy. Based on when I installed mine I'd guess about 75 lbs.
    brodeyo likes this.
  27. Apr 10, 2024 at 6:58 AM
    #87
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Regearing does not give you more torque or HP. However it is an excellent solution if you've added significant weight to your rig i.e. serious overlanding etc. Many people do this and are happy with the outcome. Just keep in mind, whatever your 5th gear RPM is on the highway/road, the RPM is going to be higher. Regearing isn't cheap by any means but it is much less than a supercharger.
    If you want more torque and HP, then a supercharger is the way to go. For me (I'm not loaded down with a lot of extra weight) the supercharger was the way to go. Much reduced gear hunting and much more actual power.
    brodeyo likes this.
  28. Apr 10, 2024 at 8:50 AM
    #88
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    ChessGuy, bigshmoop and Yotaholic like this.
  29. Apr 10, 2024 at 9:56 AM
    #89
    Yotaholic
    Olympia, WA
    To do it properly, you need both supercharger and regear. 4Runner is undergeared. So do the less expensive regear first. You will be surprised how it changes this truck. I paid $2300 for the regear
    Rob41 likes this.
  30. Apr 10, 2024 at 10:04 AM
    #90
    bigshmoop
    bigshmoop New Member
    Joe
    Schaumburg, IL
    '23 Lime Rush ORP
    LT255/80R17 ATW3's, Westcott Designs DOM/TIG sliders, low profile roof rack, ladder, preload collar lift, Baja Designs 40" S8 lightbar
    Regearing has it's own benefits and is a great mod, but it's not really the same thing.
    This is like a person ordering a steak at a restaurant and the waiter bringing out a burger patty. Sure they're kinda the same, but they aren't substitutes for one another.
