This has to be a needle bearing right?
Discussion in '5th Gen 4Runners (2010-2024)' started by TroutMan, Aug 25, 2024.
  1. Aug 27, 2024 at 5:11 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    It is very similar to an engine bearing. Installation video is still loading
    Toy4X4 likes this.
  2. Aug 27, 2024 at 6:34 PM
    TroutMan
    TroutMan [OP] New Member
    No, it doesn't. I read that after I took it in. So, they are probably correct. Now I have to figure out why my Falken Wildpeaks are messed up after 25,000 miles when I've done 3 alignments, rotated them every 5k, check the pressure once a month ... the internet is full of people complaining about them too.
  3. Aug 27, 2024 at 7:15 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    McSpazatron, Guppy1301 and Toy4X4 like this.
  4. Aug 27, 2024 at 7:34 PM
    If it helps any I still felt a rumble when slowing down even in 4WD. Rumble is gone too when I did the bearing. I know everyone says to check in 4WD but I don't think its 100% accurate.
  5. Aug 27, 2024 at 8:04 PM
    GalacticCyclist
    GalacticCyclist New Member
    TJ
    NW Georgia
    2019 4Runner TRD Offroad
    [EDIT] - Nevermind, I found it. I'm new to 4Runners and the forum, so I've been absorbing a ton of info as fast as I can.
    Do you mind posting the link? After watching the video, this is definitely something I can do on my own. I'm considering doing this anyway just for peace of mind after reading through this thread.
  6. Aug 27, 2024 at 8:40 PM
    Thank you! I know a lot of people will appreciate knowing it can be done without removing the axle from the hub. Sorry that you had to fight a stubborn bump stop...
    Oh for a lift...standing up looks a lot more pleasant than lying on the ground.
    Thanks again; I'll be looking for your new thread.
    MyWyfsRnnr[QUOTED] likes this.
  7. Aug 28, 2024 at 2:57 AM
    It probably can, the tools they offer with the bushing are going to be under $200, and they are designed to do a specific job. The resident expert here on the ECGS bushing install is MyWyfsRnnr, he has done several.
    MyWyfsRnnr likes this.
  8. Aug 28, 2024 at 5:01 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    @MyWyfsRnnr great video!! Very well done. A lift looks like it definitely makes it easier. You look like one of my friends from AZ. Everyone has a doppelganger. Lol!
  9. Aug 28, 2024 at 5:32 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Thank you sir!
    does your process in that video apply for a kdss equipped vehicle?
  10. Aug 28, 2024 at 5:59 AM
    Startrek
    Startrek New Member
    To you it is strange, that you never rebuild Yamaha outboard.
  11. Aug 28, 2024 at 6:02 AM
    3JOH22A Toyota Gigolo
    Some tread patterns are more prone to uneven wear by simple geometry - the leading edges of tread blocks get rounded. Not much you can do aside from playing with tire pressures. What pressures are you running? Have you gotten them rebalanced? (Balance can change as tread wears)
  12. Aug 28, 2024 at 6:03 AM
    Yobruhitsme
    Denver
    Then you have other issues. Bruh your single anecdote doesn’t change the facts
  13. Aug 28, 2024 at 6:06 AM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Yep. Same. If it doesn't have kdss you have to pull the sway bar end link
  14. Aug 28, 2024 at 6:14 AM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I did the video only using hand tools, I usually use a few other tools to make it go faster but they are more specialized (like an air hammer etc)
    Nice! I should meet them! Haha! A lift actually makes it a little harder to line up the two lower ball joints bolts. Factory height with kdss is the easiest. I will link a follow up video when I get another one and show a couple more tricks. It will be a short one for sure though
  15. Aug 28, 2024 at 9:57 AM
    Never heard of the exhaust corrosion issues?
  16. Aug 28, 2024 at 9:58 AM
    What issues? The ones that completely went away after replacing the bearing?
  17. Aug 28, 2024 at 4:14 PM
    The bronze/PTFE material is porous at the microscopic level, allowing diff oil to saturate it. The bushing should not be run dry.
    It probably costs 0.1 mpg in fuel consumption and therefore Toyota doesn't adopt it, even in next year's 6th gen.
  18. Sep 1, 2024 at 5:13 AM
    TroutMan
    I keep them at 32 PSI, generally checking once/month. I have the alignment checked every 10k. I didn’t have them re-balanced, no … I never noticed anything suggesting they were out of balance. All 4 have the same wear pattern, FWIW.
