Thatbassguy's financially irresponsible build and record of where all of my money went
Discussion in '5th Gen Builds (2010-2024)' started by Thatbassguy, Mar 22, 2020.
  1. Aug 2, 2020 at 9:41 AM
    #151
    :woot:
    I should have the stuff this week. Are you free for a few hours next weekend or the following at all?
    brownersd likes this.
  2. Aug 2, 2020 at 10:50 AM
    #152
    Ajmogen
    Ajmogen Staying Stock
    Aaron
    Wisconsin
    Liscence Plate Surround
    Likely next weekend. I should probably check mine while we're at it
  3. Aug 2, 2020 at 10:52 AM
    #153
    Sweet! I want to do a day trip Friday or Saturday up to the Pipeline to see what's open/closed. I could probably make any day work, though.
    Ajmogen[QUOTED] likes this.
  4. Aug 2, 2020 at 11:49 AM
    #154
    Ajmogen
    Aaron
    Wisconsin
    Cool, I'll be in touch this week to dial in the timing
  5. Aug 30, 2020 at 6:19 PM
    #155
    Nice addition to my toolbox. Viair 300p. I got to try it on a recent outing, and I'm pretty happy with it. It's a huge improvement over my Slime inflator!
    It came with a nice soft case, hose, and some adapters. It will be nice to be able to air down further than I have been and not dread spending an hour airing back up.
  6. Aug 30, 2020 at 6:37 PM
    #156
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I have the same one and use it all the time.
    I bought a cheap Amazon deflator tool. Finally used it for the 1st time and realized it was a POS. The arm in gauge more or less spun.
    Used my Viair 300P to deflate the tires without connecting it.
  7. Aug 30, 2020 at 6:45 PM
    #157
    Nice! I saw that it could be used as a deflator. I have been using an ARB deflator and I'm pretty happy with it.
    DRobs[QUOTED] likes this.
  8. Aug 30, 2020 at 7:05 PM
    #158
    Slightly better picture..
  9. Aug 31, 2020 at 9:45 AM
    #159
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    Note that this guy gets hot! My son was helping air up with this pump out there on the trail. Burned his delicate little computer science student fingers on the heat sink. Poor fella. :sadviolin:
  10. Aug 31, 2020 at 9:53 AM
    #160
    Lol! It does. It's not nearly as bad as my little slime inflator was, though. I also found that the hose reaches the rear passenger tire with the inflator sitting in the front of the engine bay, so no need to hold it while airing up.
  11. Aug 31, 2020 at 10:26 AM
    #161
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    New member here.
    I can't wait to dive in to the 4runner. Just got it last week. I like the stock a lot, but what mod made the biggest improvement to your use? I'm a 90/10 driver. So far I've heard coils, shock/strut, tires, wheels, and spacers.
    Thanks in advance.
  12. Aug 31, 2020 at 10:44 AM
    #162
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    This topic might be better in a new thread -- you could also use it to introduce yourself. Folks here tend to be very welcoming.
    But to give you an answer right away, I think most people agree that tires are the first best step. The stock tires are poor, and good tires always make a big difference regardless of what else you do or don't do. Some people find it enough to put good AT tires on, perhaps in a bit larger size. You can do that without adding a lift.
    If you do want a lift, there are tons of suggestions from folks who have done them. For suspension upgrades with or without a lift, there's a lot of love for Bilsteins.
    For wheels, there's a lot of love for the OEM TRD Pros as well as FN wheels.
    Thatbassguy[OP] likes this.
  13. Aug 31, 2020 at 10:48 AM
    #163
    icyhotahs
    Samuel
    Sacramento, CA
    Thanks for the quick look! I
    introduced myself here and there, have been lurking around other threads, but I'm having a hard time telling actual use from vendor love. You have enough mixed parts I figured you were unbiased! Thanks again.
  14. Aug 31, 2020 at 10:52 AM
    #164
    It depends what kind of trails you're going to be riding.
    I'm about the same as you, especially since the trails I run are all 3+ hours from home.
    For me, the stock tires were a first priority.
    As mentioned above, this could be asked in the forum as a new thread if you want to get more input.
    Yeah, it's kind of a mutt build. :D I went with what I liked and wasn't really dedicated to having everything match.
    Singleminded likes this.
  15. Aug 31, 2020 at 7:31 PM
    #165
    Awhile back, I became interested in the molle panels that some vendors are selling. I wasn't sure I'd use them, but I liked the idea. So, I decided to attempt to build my own. I put together a rough version for the passenger side, and it sat empty for a month or two.
    Eventually, I hung a few things on it. As it turns out, it's actually pretty handy!
    I believe I will finish it off this winter, and make one for the driver's side. I plan on putting hooks or loops on some of the bolts that hold it together for attaching things.
    I used aluminum flat stock from Home Depot, and 1/4-20 hardware for the panel, and metric hardware to attach it to the truck. I still need to shorten the stud that attaches the rear of the panel, also.
  16. Aug 31, 2020 at 7:45 PM
    #166
    Chris In Milwaukee
    Chris
    If you want to try something a little more low profile sometime, I have aircraft rivets. These are the driven kind, not the pull type (pop rivets). Won’t skin up your knuckles on them while putting thing on/off. Could be a fun project!
  17. Aug 31, 2020 at 7:50 PM
    #167
    Thanks! I'm thinking of replacing the nuts with threaded couplings so I can attach hooks, loops, or whatever I need. I'll probably be messing with it for the next couple of months.
  18. Aug 31, 2020 at 7:55 PM
    #168
    The way you built it looks more tucked into the window well better than the productions available? And it’s tied into the rod holders, very professional!!
    nimby and Thatbassguy[OP] like this.
  19. Aug 31, 2020 at 8:03 PM
    #169
    Thank you! Yes, the rod holder is bolted in where the cargo hooks were attached. I didn't really have anywhere else to go, but it worked out perfectly!
  20. Aug 31, 2020 at 10:01 PM
    #170
    shellshock
    shellshock Lost guy from tacomaworld
    Iowa
    This is pretty sweet. Nice work! :thumbsup:
  21. Sep 1, 2020 at 4:56 AM
    #171
    Chris In Milwaukee
    Chris
    That’s a good idea. Looking forward to seeing it in action!
  22. Sep 3, 2020 at 3:42 PM
    #172
    Ordered a light bar for the bumper..
    :bananadance:
    I decided not to buy a new roof rack right away. I might try to build one.
  23. Sep 3, 2020 at 5:07 PM
    #173
    Ajmogen
    Aaron
    Wisconsin
    Prinsu has 10% off right now. But at least you've got a nice light bar ordered
  24. Sep 3, 2020 at 5:12 PM
    #174
    I'm really thinking about making a rack. I would like to pick your brain about it. I was thinking about using aluminum tubing, and/or square tubing to keep it light. Do you think aluminum is strong enough? I'll be keeping traction boards, sometimes the spare tire (maybe) and the kayak up there mostly.
    And any thoughts on round VS square for attaching things?
  25. Sep 3, 2020 at 5:31 PM
    #175
    By the way, @Ajmogen , I need to get rid of the magnet mount and get a real antenna mount. Just like you predicted, the paint on my roof is trashed from the antenna getting knocked around by trees. Otherwise, I'm very happy with it.
    Ajmogen likes this.
  26. Sep 3, 2020 at 6:10 PM
    #176
    Ajmogen
    Aaron
    Wisconsin
    80/20
    https://8020.net/framing-options/t-slotted-profiles.html
    7385 and shellshock like this.
  27. Sep 3, 2020 at 6:13 PM
    #177
    icyhotahs
    Samuel
    Sacramento, CA
    I just checked out the site, how did could you tell it was 10%? Is full rack usually 1k?
  28. Sep 3, 2020 at 6:16 PM
    #178
    Ajmogen
    Aaron
    Wisconsin
    Not sure what the normal price is, I just got this email yesterday
  29. Sep 3, 2020 at 6:23 PM
    #179
    icyhotahs
    Samuel
    Sacramento, CA
    weird. not seeing it. maybe I should log in
  30. Sep 3, 2020 at 6:33 PM
    #180
    I was all over that idea at first. That stuff is awesome!
    But, I'll probably just ratchet strap things down for the most part. I decided to keep it simple (although I don't have a concrete plan yet).
