Thatbassguy's financially irresponsible build and record of where all of my money went
Discussion in '5th Gen Builds (2010-2024)' started by Thatbassguy, Mar 22, 2020.
  1. Jun 26, 2023 at 7:45 PM
    #661
    I made some more progress on the sliders since Saturday.
    Yesterday morning, I coated them with rust converter primer, and today after work I sprayed them with a few coats of rustoleum spray on bed-liner.
    Picture from yesterday:
    And, today, after applying the bed-liner. I went with this because it has a bit of a texture that I figured will provide some grip for standing on them. But, should also be reasonably easy to touch up.
    They look decent from a distance. Hopefully I can get a year or two out of them before I need to do all of this again! :rolleyes:
    djwantke, Thacrow, SlvrSlug and 5 others like this.
  2. Jun 27, 2023 at 3:54 AM
    #662
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    25-foot paint jobs are the best! I hope to do the same in my front bumper. Might have to wait until next summer, though.
    shellshock and Thatbassguy[OP] like this.
  3. Jun 27, 2023 at 3:57 AM
    #663
    My front bumper is going to need some love pretty soon, as well. At this point, I'm thinking I'll pull it off sometime this winter, unless I get ambitious sooner.
  4. Jul 30, 2023 at 7:50 AM
    #664
    Spa day is underway. Front and rear diffs are done, oil change is in progress. Next is the transfer case, and grease!
  5. Jul 30, 2023 at 8:10 AM
    #665
    Henry J
    Sacramento Ca
    You are earning your beer today!
  6. Jul 30, 2023 at 10:11 AM
    #666
    I thought it was mandatory to have a cooler close at hand:rolleyes:
  7. Jul 30, 2023 at 10:39 AM
    #667
    I mean, I had five coolers within 25 ft. Of the 4Runner. But, I overserved myself a little bit on Friday night and decided to take a few days off, lol!
    That said, I might have something later while I'm making dinner. :notsure:
    Ironguy[QUOTED] likes this.
  8. Jul 30, 2023 at 10:41 AM
    #668
    Transfer case done.
    Grease done... I think. I greased two fittings at the front of the drive shaft and one at the rear. Not sure if that is correct. Also greased the ball joints on the UCAs. Not having a very impressive experience with this generic grease gun. Could be something I'm doing wrong, but I keep getting air bubbles and having to reprime the gun.
  9. Aug 20, 2023 at 9:46 AM
    #669
    I did something I should have done a long time ago on Friday. Unfortunately, I waited until after it was a problem.
    I highly recommend chopping the tailpipe if anyone is going to be doing serious wheeling with these things.
    Last weekend, I was trying to climb a fairly steep rock, but I started slipping sideways and decided to back out. When I did that, the tailpipe got plugged, and bent.
    Fortunately, I was with a group of excellent people, including @McSpazatron and @Stoney Ranger . A few of them dug out the mud around the tailpipe and dug the dirt out of the tailpipe. When it finally spit out a clump of dirt, I heard Carlos say "it's a boy!" and everyone laughed! :rofl:
    To add insult to injury, I decided to "redeem myself" by going through a nasty mud pit right after this fiasco, and couldn't get up the steep bank at the end. Then, when I tried backing up to make another attempt, the side of the mud pit caught my front bumper cover and just about tore it clean off.
    Fortunately, it looked much worse than it really was, and it popped back into place pretty good.
    I strapped the tailpipe up to the frame as good as I could with a cam buckle strap, as the tailpipe is now pushed in so far that the hanger on the exhaust is a few inches ahead of the hanger on the frame. o_O
    So, now I have the last 10 inches or so cut off, but I might need to replace the tailpipe anyway because it is rattling. Maybe I will look for a takeoff exhaust from somebody who installs a cat back. :notsure:
  10. Aug 20, 2023 at 10:13 AM
    #670
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    I was crimping my tailpipe on the rocks, too. I solved the issue by cutting off the underside. Looked like a snake when I was done so...16925514908583695202996636279458.jpg
    captrussia253, Thacrow, nimby and 3 others like this.
  11. Aug 20, 2023 at 1:20 PM
    #671
    I can’t visualize how the exhaust got pushed in. Where did things bend?
  12. Aug 20, 2023 at 1:38 PM
    #672
    I think it bent where it goes over the rear axle/panhard bar. It comes off the muffler and bends up and over and then back down and towards the rear. The pipe is actually caved in a bit where it must have gotten mashed into the bracket for the pan hard bar. I didn't take any good pictures while I was under there, unfortunately.
  13. Aug 20, 2023 at 4:29 PM
    #673
    It's about time you took a bit of shiny off that rig :rolleyes::hattip:
  14. Aug 20, 2023 at 4:47 PM
    #674
    :rofl:
  15. Aug 20, 2023 at 4:56 PM
    #675
    @McSpazatron , I believe it bent more at the existing bend here:
    Here's as close as I can get the mount to line up by pulling it back with a ratchet strap.
    This also seems to be pulling it apart at the spring fitting by the catalytic converter.
    captrussia253 and Thacrow like this.
  16. Aug 20, 2023 at 5:33 PM
    #676
    Ah, ok I get it now. That’s actually good, in the sense that the bend was contained to the muffler section of pipe, and not the section of pipe that is less flexible further forward.
    Time for a Pro muffler? Now I kinda see a possible advantage of those with the side exit. Maybe you can mash the tips easier, but the pipe probably has enough flex in the hangars and spring connection to avoid a permanent bend. It would also be harder to push forward when reversing into mother earth lol
  17. Aug 20, 2023 at 6:07 PM
    #677
    I hear the PRO exhaust is droney, so probably not. I thought about just replacing the tailpipe section, but the bolts in the flange behind the muffler look pretty rough. I suppose I could just take it to a muffler shop and have them replace that section. But, I wouldn't want some crappy aftermarket tailpipe that's going to rust out in 2 years.
  18. Aug 22, 2023 at 6:35 PM
    #678
    Netloop
    Netloop New Member
    ‘23 trd or pre
    Kings w/adj, ome 2” rear, kdss spacer, botck, slim bumper
    Cut it and be done. I want to cut my tail pipe. Just haven’t decide where. And side exit, I want roll the back window down. Lol
  19. Aug 22, 2023 at 6:39 PM
    #679
    I already did. Just not soon enough. Even if I replace the tailpipe, I'll cut it in the same spot.
    I'd recommend cutting it just behind the last hanger like I did. I roll the back window down regularly. No problem, unless you're sitting still.
  20. Sep 9, 2023 at 5:58 PM
    #680
    I got sick of listening to what was left of the exhaust rattling against the bottom of the bumper cover, so I hacked off more of it yesterday. It's nice to have a quiet ride again!
  21. Sep 9, 2023 at 6:06 PM
    #681
    I also rotated the tires 2 weeks ago and wound up with a bad wobble in the steering wheel. I set up an appointment at Big Bear tire, near Lac LaBelle for a rebalance.
    After I got there, a few minutes into the job, the tech popped in and talked to the service advisor, and I could tell I was about to get some awesome news. :rolleyes:
    Turns out I have a bent rim. They said they could probably balance it, but that I should replace it or get it repaired eventually. Sure enough, they got it to ride properly.
    But, I ended up swapping out for the "winter" tires this week. Between that, the exhaust, and pulling the roof rack off, it's like an entirely different vehicle.
    shellshock, SlvrSlug and POOLGUY like this.
  22. Sep 9, 2023 at 6:16 PM
    #682
    backpacker
    backpacker New Member
    2023 TRD ORP
    Was it the standard ORP rim?
  23. Sep 9, 2023 at 6:19 PM
    #683
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Are your toyo atIII, your yoko MTs, and the KO2 before E loads?
  24. Sep 9, 2023 at 6:19 PM
    #684
    No, Black Rhino Stadium.
  25. Sep 9, 2023 at 6:20 PM
    #685
    No. The KO2's were C's, and so are the Toyos. The Yokohama's are E's, but I think all MT 's are.
  26. Sep 10, 2023 at 8:22 AM
    #686
    Well no wonder its bent, look at that rock you hit. :anonymous::crapstorm::p
  27. Sep 11, 2023 at 9:32 AM
    #687
    pastoreater
    There are load c MTs in 255/75r17, jeep tires I guess (lower weight rating i believe). There is an E load mt hankook in that size too
  28. Sep 11, 2023 at 10:00 AM
    #688
    Sounds like something that was probably manufactured specifically for Jeep. But, I just looked out of curiosity, and there are actually 4 MT's available in load range C in a 285/70/17. I didn't notice that when I was shopping for them. Although, I'd never bother with an MT that wasn't an E anyway.
  29. Sep 28, 2023 at 6:55 AM
    #689
    pastoreater
    SO
    You fit 295/70r17 on your BRS wheels with no rear clearance issue and no trimming on the rear, stock?
  30. Sep 28, 2023 at 7:23 AM
    #690
    Correct. It seems like the problems are always up front. They're tight back there, but I've never noticed any rubbing.
    SlvrSlug and pastoreater[QUOTED] like this.
