Thatbassguy's financially irresponsible build and record of where all of my money went
Discussion in '5th Gen Builds (2010-2024)' started by Thatbassguy, Mar 22, 2020.
  1. Mar 23, 2020 at 1:39 PM
    Ajmogen
    Ajmogen Staying Stock
    Aaron
    Wisconsin
    Liscence Plate Surround
    Lame
    Just kidding:boink:
    Nice work Assman!
  2. Mar 23, 2020 at 5:00 PM
    Thanks! I'm pretty psyched to put the new goodies to use.
    I wonder how the current regulations would affect a T.W.A.T run,,aside from not being able to go to Potosi Brewery. We can definitely maintain our distance! We'll just talk on the CB:cool:
    Ajmogen[QUOTED] likes this.
  3. Mar 23, 2020 at 6:20 PM
    4R777
    4R777 New Member
    100 points for the hilariously truthful thread title. :oldglory:
    7385 and Thatbassguy[OP] like this.
  4. Mar 23, 2020 at 7:08 PM
    I've been looking at the different molle panels for the rear windows. I'm starting to think about building my own version. Could be a good Sunday project once the weather improves.
    SlvrSlug and Chris In Milwaukee like this.
  5. Mar 24, 2020 at 4:01 AM
    Ajmogen
    Aaron
    Wisconsin
    I'm still planning on going...on the bike weather permitting.
  6. Mar 24, 2020 at 4:11 AM
    No handshakes, no hugs, and no slumber parties:D
  7. Mar 24, 2020 at 7:13 AM
    That's it, I'm out.
  8. Mar 25, 2020 at 4:19 PM
    In preparation for bigger tires (eventually), I had the shop I'm working with do a BMC while they're altering the skid plate. It's also getting an alignment. I'm looking forward to driving it with the lift and a proper alignment. It was driving fine, but the UCA's and lift affect the caster, so I'm getting it put back in spec.
  9. Mar 25, 2020 at 4:36 PM
    freak4life
    freak4life New Member
    Rich
    Cañon City Co
    2018 off-road
    Enjoyed reading about your build, well done.
    4runGirl88 and Thatbassguy[OP] like this.
  10. Mar 25, 2020 at 4:51 PM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Thatbassguy[OP] likes this.
  11. Mar 28, 2020 at 6:54 AM
    Yesterday, I got the 4runner back from Performance Off Road, where I was having the front skid altered. I accidentally bought a skid that wasn't compatible with KDSS, so we had to make it work.
    My friend had cut some of the skid off to get it to clear, but it didn't have room to flex. So, I decided to have the skid altered to make it work.
    The shop cut off the front section of the skid, and made a new front section. They kept it flat further forward, thrn angled it upward towards the bumper, and flattened it out under the bumper. They drill mounting holes and put weld-nuts in the original SOS engine skid.
    I put in 2 bolts yesterday to look at it, and to double check for clearance. It looks fantastic! I still need to paint it, though.
    Here's our makeshift clearance test. We put ramps under the front passenger and rear driver tires, and drove up to droop the front driver tire as much as possible. I believe we maxxed out the KDSS piston, and had clearance to spare.
    I have to say that I'm very happy with Both @SOS CONCEPTS and Performance Off Road.
    The original skid was excellent quality, just not the right skid for my truck.
    And, if anyone is looking for fabrication in the southeastern Wisconsin area, I highly recommend Performance Off Road in Sussex, WI. They did exactly what I asked, and it turned out better than I expected. It was a good experience all around!
    Cheers!
  12. Mar 28, 2020 at 7:10 AM
    LORDxGORDO
    LORDxGORDO New Member
    Luis
    2016 SR5 midnight black tforce
    TRD Skid Plate Nfab tforce rockslides/sidesteps BDcustomz lower grille Aiden James drl led fog bezels Phillips led fog lights Xenondepot HID low beams Springtail Solutions pet barrier - modified Ellis precision shifter knob
    Do you have a write up for installing the switch or one you followed? I kind of want to do ditch lights on my runner now too! I have some switch I bought for my previous fj I never installed
  13. Mar 28, 2020 at 7:33 AM
    Unfortunately, no. It was very simple. We cut a small slit in the wiring harness boot in the driver's side firewall, and fished the wires through.
    I cut the connectors off the Rigid wiring harness, and soldered and heat shrink wrapped the wires to the Caliraised switch leads. Make the connections temporarily with wirenuts first, and test it out before doing the soldering.
    I didn't figure out how to get the backlight to come on with the dash lights, but I might look into it later this spring when it's nice out and id feel like messing with it again. I believe @WanderlostOverland has a video or write up explaining how they were able to tap into the dash light circuit.
    The battery connections are temporarily attached to the same bolts as the main battery cables. I intend to get some expandable battery terminal lugs eventually, to make it easier to add accessories
    LORDxGORDO[QUOTED] likes this.
  14. Mar 28, 2020 at 7:36 AM
    Also, I'm quite satisfied with the quality of the Rigid lights, if you're having a hard time deciding. The Caliraised switch and brackets are excellent as well.
  15. Mar 28, 2020 at 8:28 AM
    Johnny 4th Gen.
    Johnny 4th Gen. New Member
    Floriduh!
    My first 4 Runner SR5 Sport
    W.I.P.
    Great thread Sir!
    Got lots of new ideas I will checking into for mine!
  16. Mar 29, 2020 at 2:33 PM
    Thank you!
  17. Mar 29, 2020 at 2:45 PM
    I got the custom front skid painted and bolted it on today. I'm still impressed by how good it turned out. Here's a few pictures of the final product.
  18. Mar 30, 2020 at 1:53 PM
    jake long15
    jake long15 Cali Raised LED
    Thank you for choosing us! :)
  19. Mar 30, 2020 at 2:52 PM
    #49
    jack bauer1
    jack bauer1 New Member
    Hey Jake,
    Have you seen anyone mount the new Rigid 4 inch 360 lights to your Caliraised ditch brakets yet on the 5th Gen 4Runner?
  20. Mar 31, 2020 at 1:53 PM
    #50
    jake long15
    Attach the link to the product and I can check it out.
  21. Mar 31, 2020 at 2:24 PM
    #51
    jack bauer1
  22. Mar 31, 2020 at 5:19 PM
    #52
    In January, I decided to upgrade the front door speakers before I drove to Florida.
    I chose the JL C1-690 component system, because it had a high efficiency rating and good low frequency extension. I don't plan on adding a subwoofer, so I wanted to get the most out of the existing locations possible.
    I looked into mounting plates for the tweeters, but I decided that I would just fashion something myself. I had this weird idea to use the original dash speakers as brackets. I removed the cone and voice-coil and glued the JL tweeter to the basket, and it worked perfectly!
    They sound great!
    Eventually, I'd like to do the rest of the speakers, and replace the head unit with something a little nicer.
  23. Mar 31, 2020 at 11:22 PM
    #53
    WallyT4R
    WallyT4R New Member
    I heard they have checkpoints going into Florida, I wonder if that is true? Crazy times but for a good reason I suppose, lots of elderly in Florida
  24. Apr 1, 2020 at 3:33 AM
    #54
    It's like National Lampoons Vacation-
    "..They don't close Florida"
    https://getyarn.io/yarn-clip/64073995-7e59-4def-9950-8720e450f56b
    I read that they weren't allowing anyone into the Keys. I don't know about the whole state, though.
    My Mom and her Boyfriend are still down there. They usually come back in April or May. I wonder if this is going to make it difficult for them to leave.
    WallyT4R[QUOTED] likes this.
  25. Apr 1, 2020 at 10:33 AM
    #55
    jake long15
  26. Apr 1, 2020 at 11:27 AM
    #56
    Rngr188
    Rngr188 New Member
    Chad
    Harrison, AR
    Silver 20 TRD ORP
    Nice build, unless I missed it what size tires are you running?
  27. Apr 1, 2020 at 11:36 AM
    #57
    jack bauer1
    Thank you Jake (From State Farm)...I had to say it)!
    OP-sorry for the derail.
  28. Apr 1, 2020 at 11:59 AM
    #58
    Stock size.. 265/70/17... For now:D
    No problem! Post pictures of the lights when you get them installed. ;)
  29. Apr 1, 2020 at 9:05 PM
    #59
    HankL818
    HankL818 New Member
    2020 ORP w/KDSS
    Great read! Especially the 80s-90s models named. Brings back memories of simpler time! We had a used 84(?) Corolla SR5 coupe auto as our first car.
  30. Apr 2, 2020 at 8:35 PM
    #60
    Agent_Outside
    Built 2011 T4R Limited
    Have you done the TWAT before? Is it destination worthy? I’ve considered driving out from Colorado and running it with buddy in Portage. I’ve read it’s basically a 3 day trip to do it end to end. The thought of midwest mosquitos and humidity isn’t real appealing, buy honestly I’d really like to get back to the single track at the Southern Unit of Kettle Moraine. It’s been 10 years since I’ve mountain bikes there, I loved it but that was prior to moving to and riding in Colorado, I’m wondering if good memories are causing me to give it more credit than it’s worth.
