terrible tire shake after wheel rotation
Discussion in '5th Gen 4Runners (2010-2024)' started by Dohc97, Apr 3, 2022.
  1. Apr 3, 2022 at 12:08 PM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    What problems was that causing?
  2. Apr 3, 2022 at 12:12 PM
    I'm not sure why. As far as I've heard TRD Pro does not come directly from factory in Japan so it is not in 100% Japan quality. I could be wrong. This is bone stock, no lift, no after market wheels & tires, nothing.
    Yoytota[QUOTED] likes this.
  3. Apr 3, 2022 at 12:15 PM
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    After mines back from dealer body shop for paint after they did my oil change I am making a appointment at my local independent shop for a alignment check
    Yoytota likes this.
  4. Apr 3, 2022 at 12:16 PM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    The Hunter RFB machine is only as good as the tech operating it. They need to find the high and low weight spot and run-out on the wheel first, and then match those to the tire's red and yellow spots. You get a better result with fewer weights used. My local DT used 12 weights, some stacked on top of others, to balance my Wrangler's tires and they still wobbled. I ripped everyone of them off (because it looked like crap) and it ran much smoother. They kept compounding their errors. My 4R had to go back twice to get balanced and they gouged the rims, so I took the replacements to an independent shop who took the time to do it right. Two wheels have ZERO weights on them, 1 wheel has a single small weight and the other has two small weights. Even after rotating them, there is no vibration.
    Yoytota likes this.
  5. Apr 3, 2022 at 12:21 PM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    You can always throw some good old balance beads in there for good measure just make sure they dump the bags in the tires and don't throw the whole bags in there like it says to on some of them
  6. Apr 3, 2022 at 7:49 PM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    No.
  7. Apr 4, 2022 at 3:38 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    They've been around for years. Not very accurate, but better than Bubba with an air impact.
    Yoytota and Thatbassguy like this.
  8. Apr 5, 2022 at 4:01 PM
    Dohc97
    Dohc97 [OP] New Member
    So I gave the dealer a one star rating on my review. Today I got a call from the dealer and they wanted to see the truck on Saturday, I already made an appointment with a big, local tire shop with a road force balancer on Saturday as well. Dealer said that they also have a road force balancer. So I cancelled my appointment with the tire shop. Let's see what happens on Saturday.
    nimby, Thatbassguy, 7385 and 3 others like this.
  9. Apr 5, 2022 at 4:08 PM
    Tmiesowicz
    Keep us in the loop...my shimmy is random and still trying to figure it out...I am thinking if anything maybe wrong with these rack and pinions.
  10. Apr 5, 2022 at 6:34 PM
    Amazing what a one-star review can accomplish.
    Thatbassguy and 7385 like this.
  11. Apr 9, 2022 at 8:12 AM
    Dohc97
    UPDATE: I just got back from the dealer. They did a 4 wheel road balancing job and the truck now drives wonderful. I drove it up to 72 mph and it was smooth. The tech said two of the wheels were out of balance and when they were moved up front, that caused the terrible wobble. The dealer charged me $160 labor cost, which is the same if I would have brought it to an independent shop I originally had an appointment with. I emailed Tire Rack and they are reimbursing me $100. I am happy with the outcome.
  12. Apr 9, 2022 at 8:33 AM
    Tmiesowicz
    Very nice, sounds like tire rack has good customer service as well. I was browsing there site and I was surprised that the stock Dunlop AT 20’s were more expensive vs the bf good rich ko2’s!
  13. Apr 9, 2022 at 9:56 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    Last time I went through this with Firestone they had to replace all four tires two times with road Force balancing everything each time to get it right on their dime. Sounds like you made out pretty good to me. I'd be happy with that outcome as long as she still rides smooth at 80 to 85 mph
  14. Apr 9, 2022 at 12:10 PM
    Gumpus
    Gumpus New Member
    Have you had your tire/wheel assemblies road force balanced? When tire/wheel vibration "comes and goes" it is often because you have two tire/wheel assemblies that are moderately imbalanced so every time you go around a corner the high spots on your wheels change phase to each other and when they line up you feel vibration.
  15. Apr 9, 2022 at 12:29 PM
    Tmiesowicz
    Yes I had it done at the dealership. It was very bad and constant @ 2 miles.
  16. Apr 9, 2022 at 6:47 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    I went to the tire shop over 40 yrs and the owner was a tire employees working great !!!!
    I was a costco member and I did not change my tires in costco ...I was looking on the costco tire shop and they sprayed acetone then they used a air gun that damaged the lug nuts whacked the chrome wheels ....other tire shops are damaging the vehicles...
  17. Apr 10, 2022 at 3:02 PM
    TrailGuy2016
    TrailGuy2016 New Member
    2016 Trail Premium, Silver
  18. Apr 10, 2022 at 6:10 PM
    X-INMRN
    X-INMRN New Member
    Charlie
    1995 4runner sr5
    Yea i have a ‘95 and the thing feels like it’s going to shake itself apart sometimes other times it rides just fine. But, that’s after adjusting tire pressures. Maybe check on that since it seems simple to do. If it works for any you here please let me know so i don’t go crazy trying to figure out what im missing
  19. May 25, 2022 at 5:39 PM
    #49
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    We used to use color coded ones like that at Sears in the auto center around 2000. Worked great but I can't claim to know that particular brand.
