T4RCLT
Discussion in '5th Gen Builds (2010-2024)' started by dgtulsaguy, Apr 10, 2022.
  1. Jan 2, 2024 at 12:04 PM
    dgtulsaguy
    dgtulsaguy [OP] Rocklanding Jedi Master equivalent
    22 MGM ORP long travel
    Thanks! I don't like all that weight hanging off the back nor the look of a swingout. I keep the spare inside the car. I haven't measured the new departure angle but the difference is insane! So far, I have a couple of different setups depending on the application.
    Every day:
    I use the stock tie down spots. I also strap my tool bag and box on top. I'm a little concerned I'll rip them out one day but they have survived many hard whoops with no issue.
    For overlanding, I tie it down to a piece of 3/4 mdf I had laying around I use as my sleeping platform. It's cut to fit and supported on the bottom to stay level. It rubs the ceiling a bit now and I'll need to thing of something else once I move to bigger tires. Here's the only picture have of it
    kolter45 and Harringbr99[QUOTED] like this.
  2. Mar 5, 2024 at 12:50 PM
    dgtulsaguy
    Threw on king bump's and tubbed the front for 38's. Had to relocate a bunch of stuff to make it all fit.
    Started on the rear. Lengthened all links 1 inch, new bumper will need trimming.
    20240204_155506.jpg 20240204_155428.jpg 20240302_083058.jpg 20240302_174344.jpg
  3. Mar 5, 2024 at 2:05 PM
    Oakboro, N.C
  4. Mar 6, 2024 at 7:43 AM
    dgtulsaguy
    Battery ended up in the center console with another fuse block. Bolted the battery box to the same holes the safe used.
    Added a battery disconnect to the cup holder for piece of mind.
    Needs a wash and a good detail!
  5. Mar 6, 2024 at 7:51 AM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Those wheels and tires gotta kill the already poor mpg, and make it even slower than it already is. But a lot of thought went into making those huge tires work, that's for sure. It's quite the rig!
  6. Mar 6, 2024 at 7:55 AM
    dgtulsaguy
    MPG's isn't a thing you worry about at this stage. I've heard it called smiles per gallon and this rig is unmatched on that metric.
    With 488's and other mods I can still gap my buddy's 18 ORP with stock gearing and 285's from a rolling start on the highway.
    Harringbr99 and Jareds Toyota like this.
  7. Mar 14, 2024 at 12:48 PM
    dgtulsaguy
    A buddy snapped this pic while out at Gruber ORV. Looks great from the back!
    ChessGuy, Harringbr99 and Netloop like this.
  8. Mar 14, 2024 at 1:53 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Your rig looks awesome! I'd love to do that to mine but for now I need to keep it a bit more subdued. Cool build!
  9. Mar 14, 2024 at 2:20 PM
    PointmanUSMC
    PointmanUSMC New Member
    Illinois
    2023 Black TRD ORP 4 Runner Bronze Rims
    GLORY GLORY Hallelujah. . . . Mine eyes have seen the glory of the coming of the lord . . .
    38's on a 4 Runner Nice !!! Only in MERICA :bowdown::bowdown::bowdown:
  10. Apr 2, 2024 at 1:16 PM
    dgtulsaguy
    Differential side gear gave up the ghost on the rocks. Back on the road now, got the new one in pretty easily. Doing the job maybe adds an hour to a CV shaft swap. Wish I brought a spare (will in the future). Deleting ADD next time it happens.
    Big tire problems i guess! :itllbuffout:
    J0hnny and 1SilverRunner like this.
  11. Apr 29, 2024 at 7:57 AM
    dgtulsaguy
    New front diff side gear and some frame mounted rear hydro bumps.
    Redemption run! Had to show that hill who's boss after it broke me a little further down last time.
    Minefield obstacle at Gruber ORV in OK last weekend. My buddy Long with the assist
    ChessGuy, ID_Yeti, Garlic and 7 others like this.
  12. Apr 29, 2024 at 8:32 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    GatDayum
    Noice
    dgtulsaguy[OP] likes this.
  13. May 2, 2024 at 12:25 PM
    OldJeepGuy
    OldJeepGuy New Member
    2021 4Runner TRD
    That's a great looking build! This sport is quite the addiction. It looks like you have welding down. Have you considered replacing the IFS with a solid front axle?
    ColoradoTJ and dgtulsaguy[OP] like this.
  14. May 2, 2024 at 12:42 PM
    ColoradoTJ
    ColoradoTJ I drink...and I know things. Staff Member
    Chris
    Bad ass, balls out build!!!
  15. May 2, 2024 at 12:49 PM
    dgtulsaguy
    Thank you. This rocklander will stay IFS. It's nice to take the hard lines on the trail then hit 85 on the highway on the way home.
    You can see the Jeep JKU in the background in some of the driveway pics, that will be the solid axle buggy one day soon.
    ColoradoTJ and 1SilverRunner like this.
  16. May 4, 2024 at 2:09 PM
    Metal_Head
    Metal_Head New Member
    Eric
    St. John’s, FL
    2017 ORP
    Dobinsons MRR, FN 17x8.5 Wheels, EIM Keith PCK, Metal Tech Sliders, Custom made rear lower links with Duroflex Joints, GOBI-no-rise roof rack, C4 overland front & rear bumpers, Smittybilt 10K X20 winch, LASFIT H11 LED low beams, C4 full skid plate package, custom machined ARB compressor, safety hub mounts and battery hold down.
    Did you make any other mods when extending the rear links 1"? Wondering if you had to use a driveshaft spacer, bend the panhard bar to clear the pumpkin, etc.
  17. May 5, 2024 at 3:01 PM
    dgtulsaguy
    I have the panhard correction kit that raises the axle side mount but haven’t needed to do anything else you mentioned.
    Harringbr99 likes this.
  18. Jun 24, 2024 at 8:59 AM
    dgtulsaguy
    Another busted front diff ADD tube. Another trail fix. This time I deleted the ADD actuator by replacing it with the tube off a GX and zip tying the actuator to the new tube. No lights on the dash and the new tube has survived a 2k rocklanding trip through the KAT with no shineys in the diff or T-case fluid after. We will see how it holds up to abuse.
    Harringbr99 and 1SilverRunner like this.
  19. Jul 1, 2024 at 11:23 AM
    #49
    dgtulsaguy
    Picked up a rf1a on marketplace. 4.7 gears and dual case adapters ordered from Marlin. Tacobox Tuesdays are about to get a little more spicey!
    meats and Harringbr99 like this.
  20. Aug 13, 2024 at 11:44 PM
    #50
    FatbooT4R
    FatbooT4R New Member
    AZ
    2017 4Runner TRD off road
    4.88 Nitro - 37” Nitto - 17” method 103 - 5” LT - RC fab tie rods - Dirt designs rear suspension - F&R Kings 2.5 C/O 3.0 Bypass 3 tube
    Such a beast. Did you cut the firewall as well for clearance?
  21. Aug 14, 2024 at 6:30 AM
    #51
    dgtulsaguy
    Thanks! The RCLT kit pushes everything forward (2 inches I think) so all I had to do behind the wheel was a small BMC and hammer the firewall back a bunch. Most of the work was in the front.
  22. Aug 29, 2024 at 8:24 AM
    #52
    dgtulsaguy
    Clearanced the donor case and threw the doubler together with 4.7 gears and the adapters. I'm going to pull the stock T case next weekend and split the stick for Trident triple sticks. Can't wait for this to come together!
    Harringbr99, ChessGuy and 2021venture like this.
  23. Aug 29, 2024 at 8:48 AM
    #53
    Damn....this is one serious build. Congrats on all the work you have done here.
  24. Sep 3, 2024 at 1:50 PM
    #54
    3lPorTu
    3lPorTu New Member
    Fernando
    2022 trd off road 4runner
    Hello , excelent work. It is a beast. What RCLT did you go with? 2.75 or 3.5?
  25. Sep 3, 2024 at 2:02 PM
    #55
    dgtulsaguy
    Thank you. Welcome to the forum!
    I went with the +2.75 kit as it was the only RCLT kit available when I placed the order. I'd go with +3.5 if it were to happen again as I believe there would be less tub work to do.
  26. Sep 11, 2024 at 6:48 AM
    #56
    dgtulsaguy
    Stock TCase takes approximately 3 beers to remove. Tearing it down and splitting the stick tonight hopefully.
    ID_Yeti and ChessGuy like this.
  27. Sep 12, 2024 at 6:52 AM
    #57
    dgtulsaguy
    Dug into the stock case last night. Clearanced the shift rail interference and pulled the pin between the 2 rails to split the stick. Easy job, maybe 2 beers. I'll mate the 2 cases and start the reinstall this evening.
  28. Sep 30, 2024 at 7:10 AM
    #58
    dgtulsaguy
    This tacobox has been a freaking beast to install!
    Latest issue was the NorthWest fab triple stick. It sits pretty tall and a small body lift would have lessened the BFH work I had to do on the dog house. Only problem with a body lift is my LC200 steering rack sector shaft to motor mount clearance prevents it without removing even more of the driver side motor mount and replating.
    Also, had to do some heavy clearancing and module relocating on the trans shifter to clear the 3rd stick. Even after all that work I am paying my friend to TIG weld the doubler's shifter mount at around an 80 degree angle so the stick can clear the rest of the trans shifter.
    Exhaust will need notched to clear the new T Case mount.
    ALSO, the doubler leaks like a freaking waterfall. Mainly because I sheard a bolt off in the adapter during install so the case likely needs to come out AGAIN!
    But it fits... Or will eventually...
    and everything works... mostly!
    There's an end in site anyways haha.
    New custom length driveshafts with Spicer 1330 joints for easy changes on the trail and a little more BEEF.
    SOOOOOOOO stoked to button this project up. Hoping it's done in time for the Ultra4 race in OK later this month. Not racing yet ahah.
    Next phase will likely be a 3 link of some sort and coilovers on the rear.
    ID_Yeti likes this.
