Switching to all LED?
Discussion in 'Lighting' started by Jasongee086, Dec 18, 2020.
  1. May 19, 2021 at 5:48 AM
    laceofbase
    laceofbase New Member
    2017 Black 4Runner Limited
    how are this 9005s doing? Did you modify anything or add a PWM interface module of some sort to keep the DRLs from flickering?
  2. Aug 16, 2021 at 6:02 AM
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    How bad is the flickering on the 9005 LED's? I suppose you could disable DRL and just use the 9005 LED for high beams only?
  3. Aug 16, 2021 at 6:05 AM
    VentureTRD
    Very happy with the LasFit front and rear turn signal lights - very bright, well made, solid construction. They cost a bit more than some others, but the quality is worth it.
    921 Backup lights would not stay in the sockets and kept falling into the housing (pain to get out). Ended up using Yorkim 921 and electrical taping the bulb to the sockets to prevent falling out.
    If you have trouble getting the rear turn signal bulb turned around when connected to the plug, just tug on the wire a bit and it will fit in.
  4. Aug 27, 2021 at 12:11 PM
    VentureTRD
    2021 Venture - I noticed the 9005 DRL only come on when you select DRL on the light stick (with DRL enabled), otherwise they don't come on at all with the low beams. I drive with my headlights on all the time anyway, so they never come on for me at DRL. So if you disabled DRL and replaced the 9005 bulb with a LED, this should work fine. Now to find a 9005 LED that has a good pattern, typically those with 1mm thick stems work. I also noticed some companies are coming out with round 9005 LED's to get around the dead spot in the pattern.
    Any suggestions for a 9005 LED High Bean that have a good beam pattern?
  5. Aug 27, 2021 at 12:18 PM
    Xenon Depot LEDs are the only ones I have tested that work good as a DRL and fairly good highbeam light output. I have tested several 9005 highbeams with really good highbeam performance but lack in DRL function. Either they flicker or light output is too bright as a DRL. Xenon Depot LEDs did a good job handling both scenarios.
    https://youtu.be/7W3I3PP0QT8
  6. Oct 8, 2021 at 1:13 PM
    VentureTRD
    I went with the 40W LasFit LED (no fan model) for the 9005 high beams on my 2021 Venture Model. I'm very impressed with the light brightness and the white color now matches the low beams. No missing areas in the beam pattern. I just disabled the DRL on the front console screen, since they only come on if selected and remain off during normal night driving. I think I paid $9 each open box on Amazon.
    j4unner likes this.
  7. Oct 8, 2021 at 1:28 PM
    Why did you disable DRL? They are flickering?
  8. Dec 8, 2021 at 2:43 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    With the DRL mode being de-activated, which 9005 LED did you find that had the best high beam output and pattern?
  9. Dec 8, 2021 at 4:05 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Isn't his answer in your quote?
  10. Dec 8, 2021 at 4:11 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    He says that LasFit is "good at both" but that doesn't mean it is the best overall for output and pattern if I don't need the DRL's... So, that's why I am asking.
  11. Dec 8, 2021 at 4:26 AM
    mynameistory
    Tory
    Ah, you meant deactivated. Also his original answer was XenonDepot, not Lasfit. If you're looking for best and brightest it's still likely going to be a good pair of 9011 HIR bulbs.
  12. Dec 8, 2021 at 4:29 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    "That's what I said, Booty Traps!" Data - The Goonies
    Thanks for the correction. I'll fix it in the post.
    mynameistory[QUOTED] likes this.
  13. Dec 8, 2021 at 9:25 AM
    I use Nilight 9005 LEDs for having best high beam output and pattern for now. Here's the comparison between Nilight vs Morimoto 2stroke 3.0.
    Nilight 9005 bulb only -
    VS
    Morimoto 2stroke 3.0 9005 bulb only -
  14. Dec 18, 2021 at 12:53 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    I too went with the LasFit 7443 turn signal bulbs all the way around.
    Amazon.com: LASFIT 7443 LED Bulb CANBUS Ready 7444 T20 Turn Signal Light Error Free Blinker Anti Hyper Flash, No Load Resistor Need, Upgraded Automotive Replacement Bulb- Amber Yellow (Pack of 2) : Automotive
    They advertise them as not having any hyperflash issues - even with no resistors. (That would be a big selling point.) The brightness I can't complain about. The hyperflash issue I will complain about.
    If you don't run your turn signals or 4-way flashers for more than a minute or two, you'll be fine. Run them for longer, and these bulbs will transition into hyperflash mode. It's actually quicker than that in the front where the bulb does double duty as running light and turn signal. I had the parking lights on the other night, then turned my right turn signal on. Less than 30 seconds after I activated the turn signal, I had full hyperflash. Not good.
    For some folks, hyperflash doesn't seem to bother them. I'm not a big fan of it though and this will probably cause me to pull the LasFit bulbs out and go back to stock.
  15. Dec 18, 2021 at 2:45 PM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    how about amber color for the DRL..?
  16. Dec 18, 2021 at 2:55 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    I have the same Lasfit 40w LED as well.. I find that my DRL project upwards rather than outwards.. am I missing something?
