Suspension suggestions
Discussion in 'Suspension' started by homesteader, Aug 20, 2021.
  1. Sep 27, 2021 at 4:00 AM
    They're pretty famous for leaking. They just don't seem reliable to me.
    7385, Roland and Crikeymike like this.
  2. Sep 27, 2021 at 8:19 AM
    homesteader
    homesteader [OP] New Member
    2022 4Runner TRD OR lunar rock w/KDSS
    Got it thanks.
  3. Oct 13, 2021 at 12:29 AM
    homesteader
    I'm in discussion with Mike on a lift set up.
  4. Oct 15, 2021 at 12:08 AM
    homesteader
    Anyone with Dobinson IMS or MRA want to share their experiences?
  5. Oct 15, 2021 at 9:52 AM
    Roland
    Roland New Member
    Thatbassguy and Crikeymike like this.
  6. Oct 15, 2021 at 11:15 PM
    homesteader
    Thanks Roland for your great info. Looks like your having fun with your 4Runner.
    Mike suggested the same setup except a different strut. I am going 3" up front and 1.5 " rear to get the almost level look or 1/2'' rake. I'm trying to decide if I should go IMS or MRA.
    I'm hoping to get 285/55/20 with a negative offset. Should I start another post in the general or tire and wheel section? I would like to see how much a -12 or -18 sticks out side of the fenders.
    Roland[QUOTED] and Thatbassguy like this.
  7. Oct 16, 2021 at 12:28 PM
    Roland
    Roland New Member
    Can you provide me with the reference numbers Mike gave you on shocks and coils/springs. MRA/MRR is a 3-way valving adjustment, meaning there is an external reservoir added which is great, top of the line, I don't know if Mike would advise you these for your application about $2,200.00 for shocks only, I could see if you would do high speed desert driving on regular bases for hours at the time.
    The IMS is actually the same shock, without the reservoir, they are very well tuned and are great on & off-road and cost $1,100 which is half for the 4 shocks, both systems are height adjustable in front. Don't forget It's the Coils/Springs that do the lifting & in case you are going to go a full 3" in front you might need aftermarket upper control arms as well, 2.5" is a bit at max.
  8. Oct 17, 2021 at 12:07 AM
    homesteader
    Roland this is what I got from Mike. C59-302 Front coils,IMS59-50574 or MRA59-A574 Front struts. C59-505 rear 1.5 coils,IMS59-50705 or MRA59-A701 rear shocks. UCA's SPC or Dobinsons. SPC biggest range for adjustment and Dobinsons with zero maintenance. Possible extended sway bar links.
    Mike did give me the run down between both the IMS and MRA's. I believe I mentioned it before, this 4Runner will probably not see very much off road. It will be my wife's 4runner.
    Roland[QUOTED] and Crikeymike like this.
  9. Oct 17, 2021 at 12:35 AM
    I have dobinsons IMS. Very happy with them. Here is the link to my install thread: https://www.4runners.com/threads/dobs-ims-going-in-5th-gen-trd-or.22129/
    Keep in mind, comfort is very subjective. The IMS are much firmer than the stock shocks. But I still consider them very comfortable because of their damping qualities. Just know it will ride like a totally different vehicle, in a very good way IMO.
    One thing about remote reservoir shocks for a daily driver. It’s great to have the performance and damping adjustability, but it’s probably best for someone who needs it and is willing to put up with possible need for maintanance. On each shock, you have two hose junctions, which means you have an additional 8 possible leak points for a whole set. Shocks without a resi only have the piston seals to worry about. Not knocking resi shocks at all, but it’s good to know what you’re getting into for daily driver use.
  10. Oct 17, 2021 at 11:39 AM
    Roland
    Roland New Member
    I see, Mike gave you a choice, they are both great setups; you can't go wrong with either of them. Well, you know what you are going to use your 4R for. Let us know & post pictures when done.
    Good luck. :thumbsup:
    Crikeymike likes this.
  11. Oct 19, 2021 at 10:45 AM
    homesteader
    Thanks MacSpazatron for your info.
    McSpazatron[QUOTED] and Roland like this.
  12. Jan 6, 2022 at 9:22 PM
    homesteader
    Ordered Dobinson IMS
  13. Jan 6, 2022 at 10:24 PM
    Sweet! You planning on installing them yourself? What model shocks did you get? What amount of lift are you aiming for?
  14. Jan 6, 2022 at 11:51 PM
    homesteader
    Yes I plan on doing the work. IMS Front shocks 574 rear 705. Aiming for 3” lift.
    McSpazatron likes this.
  15. Jan 29, 2022 at 10:27 PM
    homesteader
    Hey Guys,
    My Dobinsons IMS kit arrived. Just waiting on a few more parts.
    Any tips that someone may have learned while doing their lift?
    I have KDSS. Which do I do first? Would it be better to do KDSS first since it’s not on some kind of stress then it would be when lifted?
    thanks
  16. Jan 29, 2022 at 10:40 PM
    I cant comment on the KDSS aspect…but make sure that you tighten the lower control arm bolts with the weight of the vehicle on the ground. Otherwise You’ll shorten the life of those bushings.
    In my install thread in my post above, somebody linked me to some torque values for various bolts, that will be helpful.
    Good luck!
  17. Jan 30, 2022 at 12:09 AM
    homesteader
    Thanks I’ll look at the link.
    So for lower control arms snug bolts in air then set vehicle on ground with vehicle weight and torque bolts?
  18. Jan 30, 2022 at 12:24 AM
    homesteader
    Did you do UCA’s also?
    Just wondering what would be the best steps if replacing UCA at the same time.
    I’m thinking it would be easier to replace UCA with struts removed. Just need to support knuckle and rotors since both upper and lower UCA’s will be disconnected. Or is there a better way?
    thanks
  19. Jan 30, 2022 at 8:15 AM
    #49
    slixx1320
    slixx1320 New Member
    Great selection on lift. Dobinson are top notch. My buddy has it on his 5th gen and he loves it. Regarding UCA, it’s not hard to have them install later on down the road.
    And just for the record, I have icons cdcv and have had no issues. I read somewhere (forgot where) that kings also had same issues w/ leaks. I’m sure every manufacturer has their own little flaws, people just posts about it.
  20. Jan 30, 2022 at 8:23 AM
    #50
    homesteader
    I have UCA’s included with this kit.
  21. Jan 30, 2022 at 10:39 AM
    #51
    No, sorry, I havent done the UCAs. I bet Crickeymike could give you some thoughs on it if you give him a call!
  22. Jul 20, 2023 at 7:34 PM
    #52
    H3llRid3r
    H3llRid3r New Member
    2023 Ice Cap 4Runner TRD Off-Road Premium w/ KDSS
    100% Stock (for now)
    Update on the Dobinson choice?
  23. Jul 21, 2023 at 4:30 AM
    #53
    TrailSpecial22 New Member
    PA
    welcome!
    i love my set up and im 80% street. 2” lift Bilstein 6112 w/600 lb coils front, 1.5” lift Eibach T13 coils rear, Bilstein 5100 in rear, 285/70/17 Falken WP AT3, Energy Suspension front bumpstops, Durobumps 4.25” rear
    757T4R, H3llRid3r and Crikeymike like this.
