Survey on gas octane
Discussion in '5th Gen 4Runners (2010-2024)' started by PR48, Jan 21, 2019.
  1. Jan 25, 2019 at 6:28 AM
    Snow Packed
    Snow Packed New Member
    The oil cartels love people like you and so do their investors.
    Slopemaster and 2016Pro like this.
  2. Jan 25, 2019 at 12:23 PM
    Snow Packed
    No worries. PT Barnum said it perfectly.
    2016Pro likes this.
  3. Jan 25, 2019 at 2:01 PM
    Snow Packed
    Morons abound. I know a self fulfilling prophesy when I see one. Let me guess... you are so tough you wipe your ass with dollar bills.
  4. Jan 25, 2019 at 2:44 PM
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    I use V-power cause That red button looks cooler than the two yellow ones. Before i had the runner i had an 06 Taco with the 2.7 4 bang. Ran nothing but shell chevron or exxon 93 the whole 9 years of owning it. Now listen to this and I need your opinion. At around 130k the catylitic converter went to shit and while changing it out, my dad swears it was from me using nothing but 93 in a low compression engine and that was causing buildup from unburnt gas. Is he right about that? Im not sure he knew that it was a vvt
  5. Jan 25, 2019 at 2:47 PM
    Snow Packed
    Yes, the system will adjust the timing to account for the octane difference. There is no benefit. If there was, it would be required.
  6. Jan 25, 2019 at 2:58 PM
    WallyT4R
    WallyT4R New Member
    Your opinion of it "would be required" is simply not true. Let's give it a rest here. People should be able to spend their own money how they see fit. It's their money.
  7. Jan 25, 2019 at 3:57 PM
    And name calling is stupid.:poking:
    7385, WallyT4R[QUOTED] and Backslider like this.
  8. Jan 26, 2019 at 4:22 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    yes IMO dad is correct on 93 in a 4 banger. most vehicles designed for 87 will not have a PCM programed for 93 use .. so yes the 93 will leave some un burned fuel.
    ON some GM V8 engines PCM does have ability to change the fuel management with 91 .. 93 PCM does not have that ability. Toyota not sure if it can do it with 91..
    I did try 93 in runner and did 2 fuel tanks no change in MPG so why would I use extra $$$ for nothing gained ?
    Top tier fuels are with additives to keep the nasty alcohol from doing the damage in the fuel system for a period of time.
    Ramrod88[QUOTED], 7385 and 2016Pro like this.
  9. Jan 31, 2019 at 8:02 AM
    Crusifix
    Crusifix New Member
    2015 TRD Pro (Inferno)
    3.5 lift all around. King in the front OME in the rear.. Other stuff..ya know, 4runner stuff...
    As long as the computer can adjust and throw enough spark advance at the combustion chamber, then you will get better performance and usually even better fuel mileage out of higher octane. Better mileage is based on you not utilizing your right foot like it has a rock attached to it. However, that extra bit of pep could mean the difference in when your transmission downshifts to compensate for load. Now, I don't know what the maximum tables look like for octane (knock detection threshold), but I would wager you will at least see a boost in performance with 91 octane. If it is able to add enough timing in spark, and possibly even with the cams to run 93 octane efficiently and with a clean burn, well even better.
  10. Jan 31, 2019 at 8:50 AM
    j cat
    j cat New Member
    massachusetts
    what tuner do you have or had the tune from ON YOUR TOYOTA ?
    family member has a diablo tuner for dodge/GM .. tuner can change anything .. can change so much it can blow up the engine..
    DIABLO TUNER NO TOYOTA !
  11. Jan 31, 2019 at 11:12 AM
    Crusifix
    Crusifix New Member
    I don't have anything on my 4runner.
  12. Jan 31, 2019 at 12:31 PM
    j cat
    j cat New Member
    massachusetts
    many are looking for a performance tune .. less down shifting when going up hills on hywy @60-70MPH..also shift point change .
    Crusifix[QUOTED] likes this.
  13. Feb 10, 2019 at 8:07 AM
    fsroader
    fsroader New Member
    james
    E.TN.
    $0.20 difference between reg & hi-test? Lucky you. It's at least $0.75 per gal here. This is the 1st ride Ive owned in quite awhile that uses reg and I'm not complaining.
    7385 likes this.
  14. Feb 10, 2019 at 8:27 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
  15. Feb 10, 2019 at 9:58 AM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    OP should have added a poll. :notsure:
    kolter45, 7385 and HoBoDanny like this.
  16. Feb 10, 2019 at 10:03 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Would help keep some of the bickering down.
    TN_FunRunner[QUOTED] and 7385 like this.
  17. Aug 11, 2021 at 7:34 AM
    dudewheresmy4rnnr
    dudewheresmy4rnnr New Member
    Just reading this thread. Good info. Dealer said only 87 on the 5th gen. Based on research it’s ok to run 91 selectively in extreme heat as the fuel burns slightly cooler. Otherwise yes, higher octane in lower compression engine isn’t necessary and could actually do harm in the long run.
  18. Aug 11, 2021 at 8:13 AM
    M12_FAV
    M12_FAV New Member
    2020 Army Green TRD Pro
    Been running 91 since day 1. Always owned cars that required premium so force of habit.
    MiamiMark likes this.
  19. Aug 11, 2021 at 9:51 AM
    #49
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I use 87/91 because of anecdotal evidence that my vehicle performed in a certain way based on my own biased observations.
    Since we're on the topic of fuel octane, what weight oil and change frequency are ya'll doing? :bananadead:
  20. Aug 11, 2021 at 10:07 AM
    #50
    On the flip side, some states, especially mountain states e.g. Utah sell 85 octane rather than 87 octane.
    What do you guys think about that?
    If 85 is where you reside, then that's your option.
  21. Aug 11, 2021 at 11:45 AM
    #51
    M12_FAV
    M12_FAV New Member
    Not an expert but I know higher octane burns slower so 87 more combustible than 91. Maybe easier burn better at high elevation due to efficiency? My guess of why 85 available at high altitude :notsure:
  22. Aug 11, 2021 at 12:27 PM
    #52
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    It’s all to do with less oxygen at higher elevations. Less oxygen tends to slow the detonation, acting like higher octane gasoline. So the theory is the lower octane 85 available in high elevation areas acts like a higher octane at sea level and will save you money.
    It’s recommended that you use up most of the 85 octane in your tank and fill up with 87 or higher before returning to sea level. That’s too much bother for me, I just use 87 all the time.
    kolter45 likes this.
  23. Aug 11, 2021 at 12:59 PM
    #53
    2016Pro
    87 zero issues
  24. Aug 11, 2021 at 1:28 PM
    #54
    Interesting, I normally run regular 87 too, but if I'm traveling through an area with 85, then so be it.
    Never had a problem, just curious.
  25. Aug 11, 2021 at 1:45 PM
    #55
    Daddykool
    I remember a trip out west in 2012 (I’m in Ohio) and at some point began noticing more options for either straight gasoline or 10% ethanol (hard to find undiluted gas in Ohio). The straight was more expensive, but I decided to opt for that for several fill-ups as an experiment. I was driving a 2001 SR5 with five people and a 4x8 U-Haul trailer. Averaging about 17mpg. The straight gas bumped me up to 19mpg. I think the octane was 90 for gas and 87 for ethanol blend. Probably a wash cost-wise, but an interesting experiment nonetheless.
  26. Aug 11, 2021 at 2:15 PM
    #56
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    My 2013 has run off of 85 octane for seven of the eight years I’ve owned it.
  27. Aug 11, 2021 at 2:22 PM
    #57
    Tama1968
    Tama1968 New Member
    Florida
    T4R SR5 in Classic Silver
    both my older brother who is a petroleum engineer, and my late father who was a mechanic and notorious cheapskate used regular all along. I've followed suit and used regular in everything from my POS '78 Malibu to my gorgeous '19 4Runner with no problems.
  28. Aug 15, 2021 at 11:40 AM
    #58
    VentureTRD
    VentureTRD New Member
    Blowing Rock, North Carolina
    https://en.wikipedia.org/wiki/Toyota_GR_engine#1GR-FE
    The 1GR-FE is the 4.0 L (3,956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a bore and a stroke of 94 mm × 95 mm (3.70 in × 3.74 in). Output is 236 hp (176 kW; 239 PS) at 5200 rpm with 266 lb⋅ft (361 N⋅m) of torque at 4000 rpm when tuned for 87 octane, and 240 hp (179 kW; 243 PS) at 5200 rpm with 278 lb⋅ft (377 N⋅m) at 3700 rpm when tuned for 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1. Service weight, including fluids, is 166 kg (366 lb).
    An updated version of this engine features Dual VVT-i, increasing output to 270 hp (201 kW; 274 PS) at 5600 rpm and 278 lb⋅ft (377 N⋅m) at 4400 rpm on 87 octane.
    On the 1GR-FE, there appears to be a slight horsepower increase when running Premium Gas.
  29. Aug 15, 2021 at 11:57 AM
    #59
    MiamiMark
    MiamiMark New Member
    Seriously?
    '21 MGM TRD Pro
    I only put Chevron or Shell 93/91.
  30. Aug 15, 2021 at 12:10 PM
    #60
    Instead of getting on it to get past them, let off and let them go by. Guaranteed your mileage will improve.
    I have 122k on my 2013 on all terrains and rarely get much below 20mpg because I drive conservatively.
    Daddykool likes this.
