Stumped!! entire right side lean!
Discussion in '5th Gen 4Runners (2010-2024)' started by raimieb, Aug 21, 2023.
  1. Sep 13, 2023 at 1:46 PM
    raimieb
    raimieb [OP] Hobby Mechanic - Love Our 4Runner!
    raimie
    2021 ORP 4x4
    Lots…
    UPDATE: Moved the rear 1.25” spacer to the passenger side coil. Then reset the KDSS by opening the valves two turns and rocking the truck back and forth. Finally, raised the passenger side with KDSS valves open to the same height as the driver, then closed the valves, and finally set the truck back down. I”m now within 1/8 inch driver to passenger in the rear!
    Many thanks to all of you for helping me solve this issue. Appreciate you guys very much. Love how this forum gets to help one another save $$ and spend it on our mods. :)
    Rock on! -Raimie
    Y0TA, TrueTexas, JETSPD1477 and 2 others like this.
  2. Sep 13, 2023 at 2:39 PM
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    Nice, my advice is to not obsess too much over the lean. I find it comes and goes on mine depending on how and where I’ve driven it.
    My front end is basically level within 0.25” all the time, but my rear end will vary between 0.250” and 1” of lean. I rarely get over 1” of lean now though, but it does happen occasionally, and usually just the rear. I’ve mostly decided to stop looking for it, but still measure more than I care to admit :anonymous:
  3. Sep 13, 2023 at 3:18 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    thanks Boris!!! Much agreed.
  4. Feb 10, 2024 at 5:08 AM
    Wren
    Wren New Member
    Have any of you noticed more lean once parked, engine off, than when driving?
    I had a theory that most of this lean is static, not while the truck is in motion. So I found a level spot and did some measurements. After sitting over night I had a 1/2” passenger side lean front and rear. I drove the truck around the block, parked, and left the engine running. Less than 1/4”. I turned the engine off and waited for a bit. Back to 1/2”.
    My theory is that some pressure that builds in the accumulators to balance the system while driving, bleeds back out once the engine is off and so the rams get a little pressure which lifts the driver side up while parked. This would help explain why the valve based lean correction works and also why it doesn’t tend to stick long term.
    jgalt, djwantke and raimieb[OP] like this.
  5. Feb 10, 2024 at 8:07 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Happens all the time. It will work itself out over time. If it gets really bad, just loosen the KDSS valves 1.5 turns (have to count exactly) and rock the truck back and forth. Then close them back to the original location.
    djwantke likes this.
  6. Feb 10, 2024 at 11:51 AM
    In GX world they have a service bulletin to fix KDSS lean
    raimieb[OP] likes this.
  7. Mar 6, 2024 at 10:49 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I'm going to follow your lead on these valve tricks, I have a consistent passenger lean. I also have the DrKDSS kill switch, so first maybe I take a bunch of right turns with the valves open over 12mph, and park sloped to the passenger.
    *Part of me wonders if my garage floor sloping to the driver side is what is causing this since the 4R is garage parked for as long as 36 hours at a time, multiple times a week
    I kinda wanna continue to grow my skills and tackle adding spacers too. Invest in one of the death spring compressor tools.
    raimieb[QUOTED][OP] likes this.
  8. Mar 6, 2024 at 11:00 PM
    Thank for this
    Your theory is very smart, that is part of my problem, that and my garage floor lean!
  9. Mar 7, 2024 at 3:55 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    It’s really pretty simple and with your abilities it will be easy. Just do the minimum recommended turns on the valves and mark them so you can count the turns. Rock it back and forth and close the valves . You got this!
    djwantke[QUOTED] likes this.
  10. Mar 7, 2024 at 10:29 PM
    Hah! Ur such a nice dude always
    I needed that pep talk, I’ll absolutely keep ya posted and post my results here
