Stop on hill, go, brrrrrrrr traction control!!!
Discussion in '5th Gen 4Runners (2010-2024)' started by wolfman, Dec 16, 2022.
  1. Dec 20, 2022 at 9:28 PM
    1022PRO
    1022PRO New Member
    5th Gen 4Runner
    This happened to me on relatively steep inclines in my 2018 4Runner (e.g. stopped on a hill in the SF Nob Hill area) and I found it annoying at stoplights and wondered why it was happening, and thought that something could be actually faulty on my vehicle such as a certain sensor, etc. I haven't yet driven on such hills in my 2023 4Runner, but I'm curious if the behavior will be any different and I'll report back if there is any difference.
  2. Dec 21, 2022 at 3:24 PM
    1022PRO
    1022PRO New Member
    5th Gen 4Runner
    Well, for what it's worth, I just went on a hill where I experienced the "brrrrrr" before and my 2023 behaved exactly the same way as my 2018 did, so it wasn't a faulty or hypersensitive sensor...
  3. Dec 21, 2022 at 3:50 PM
    Curt56
    Curt56 New Member
    Curtis
    2021 TRD ORP
    My driveway is a hill. I leave from it all the time from a dead start. No issues.
  4. Jul 19, 2024 at 8:21 PM
    mopudding
    mopudding New Member
    Chris
    Burnaby, BC Canada
    2018 4Runner Limited
    I just picked up a 2018 Limited and it does the exact same thing on a hill - slip indicator lights up and the truck shakes as it rolls back, kinda feel like ABS shake.
    So I'm confused, is this the intended function or should this be fixed?
    I've owned other cars with hill assist, and none of them operate like this.
  5. Jul 19, 2024 at 11:24 PM
    Intended function, just a bad execution of it.
  6. Jul 20, 2024 at 12:45 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I have to yield on a steep hill as I leave home. Avoiding the described behavior is a two-foot operation - hold the brake and hit the accelerator just as you're releasing it. Not a lot different than using a handbrake with a manual on an uphill.
  7. Jul 20, 2024 at 12:45 PM
    mopudding
    Chris
    Burnaby, BC Canada
    This is beyond ridiculous.
  8. Jul 20, 2024 at 1:58 PM
    It’s all they can do without a electronic parking brake and it does keep you from stalling the engine for a time.
  9. Jul 20, 2024 at 2:10 PM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Are you guys complaining the same guys they make brake hold for on manuals? Or would you even attempt to drive a manual?
    It happened to me once when I first got the car. After that I just... hit the gas faster when starting on hills
    backpacker likes this.
  10. Aug 14, 2024 at 1:32 PM
    Girth13
    Girth13 New Member
    2024 4runner SR5
    My friend and I both have a 2024 4runners and they both do the exact same thing as the OPs issue. We both have stored messages in our infotainment system under "Vehicle Alert". The message says that it's a vehicle stability control system malfunction, see pic. Both of our throttles cut out when this happens so 2 footing it is a must or roll into whoever is behind you. The first time this happened to me, I was stopped on a pretty steep hill at a stop sign, and, when I let off of the brake pedal and attempted to accelerate, the brakes held for a quick second as they are supposed to. I then started rolling so I hit the gas....to late! This is what set all of the "safety " systems into a tizzy. The brakes did "attempt" to stop the truck in a very hurkey-jerky manner but I continued to roll backwards until I finally realized that my gas pedal wasn't doing anything and I hit the brakes. Now I know better. Quite sure the dealer will say this is "normal".20240812_192926.jpg
  11. Aug 14, 2024 at 1:48 PM
    Look at the 12/12 date and time. More than likely factory testing, not what you encountered.
    TrailSpecial22 and McSpazatron like this.
  12. Aug 14, 2024 at 2:20 PM
    Daddykool
    If you live near each other, maybe take both vehicles to the same dealership at the same time and let them have a look. Perhaps they could do some comparing. It's always easier to diagnose a problem when there's more than one example in front of you.
  13. Aug 14, 2024 at 2:50 PM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    Yup, my 2024 had 3 alert messages including this one, all dates before I bought the rig. I've had what OP is talking about happen on a some dirt inclines, there's no alerts from those dates.
  14. Aug 14, 2024 at 3:52 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    If I'm stopped on a steep hill, it's just second nature to "two foot" it. Not doing so just seems like asking for a problem and blaming the vehicle. Assuming I have two feet, what's difficult about it?
    OverRunner likes this.
  15. Aug 14, 2024 at 4:09 PM
    Girth13
    Girth13 New Member
    2024 4runner SR5
  16. Aug 14, 2024 at 4:11 PM
    Girth13
    Girth13 New Member
    2024 4runner SR5
    The funny thing is that the alert was not there before this happened, it appeared afterwards. I received a second alert that appeared about two months after a close call on the Pa turnpike for the pre collision system, and it has the same 12/12 date and same time. I'll have to trigger another alert after I delete the current ones and see what date pops.
