Stiffer sway bar for an SR5?
Discussion in '5th Gen 4Runners (2010-2024)' started by a522467, Oct 10, 2021.
  1. Oct 12, 2021 at 2:44 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    I might have missed it, but are you still running the stock tires? The change from P265/70's to a BFG 255/75 C-rated was dramatic for me. I have the Toytec 1.6's in front and Bilstein 1" in the back with 5100's on all four, but it wasn't until the tire change that a real difference in handling was noticeable.
    a522467[OP] likes this.
  2. Oct 12, 2021 at 3:59 AM
    a522467
    a522467 [OP] Life’s short. Live now.
    Michelle
    Ohio
    2020 Black 4X4 SR5
    Black TRD wheels, Nightshade running boards, Morimoto (fog, head, tail) lights, pedal commander, carbon fiber accents, black exhaust tip, ballistic seat covers, Eibach lift, blacked out emblems, CPLAY2air Bluetooth adapter, console & glovebox organizers, all weather mats, LED interior lighting.
    @Deuxdiesel
    Yes. Good point! The stock Bridgestones are awful. I’ll be changing them to BFG KO2s soon. Thanks. Curious why you went with the thinner 255/75 though. I was thinking of going with 275/70R17. Wouldn’t they fit?
  3. Oct 12, 2021 at 8:14 AM
    Though I think skinny tires does not look good on a 4Runner looking dead straight skinny tires seems to be more functional than wider tires. I think those who like skinny tires highly recommend 255/80R17. Most 255/80R17 tires are 33in tall tires and very few 285/70R17 tires are 33in tall.
    Here's a good explanation -
    https://youtu.be/dvIZSq9D4Zg
  4. Oct 12, 2021 at 3:39 PM
    Deuxdiesel
    SE MI
    '18 SR5P
    Once you experience how well a moderately tall-n-skinny tire works, you quickly forget about the style aspect. In snow, soft surfaces (farm mud) and aired down for sand they are great. I have a set of DuraTrac's for winter and sloppy conditions, and KO2's for my 70/30 dirt road/paved driving.
  5. Oct 12, 2021 at 7:14 PM
    Cajunhunter67
    Cajunhunter67 New Member
    Don
    2021 SR5 Premium 2wd
    I was hoping to find aftermarket sway bars for my wife's new 4 Runner. It also has IMO excess body roll in turns.
    I replaced the stock sway bar bushings with Whiteline bushings and it helped. My wife could tell the difference. For me, it still needs better sway control.
    IMO there is no substitute for a heavier sway bar when it comes to controlling body roll. From my research, no one offers an option for Gen5 4 Runners.
    I'm hoping different springs and shocks will help in the near future.
  6. Oct 12, 2021 at 9:03 PM
    a522467
    Michelle
    Ohio
    2020 Black 4X4 SR5
    Thanks. I’ll update the thread if I find something that fits. ADDCO is saying p/n 2301 for the rear, and I might try Hellwig’s Tacoma bar on the front.
  7. Oct 14, 2021 at 4:06 AM
    Deuxdiesel
    SE MI
    '18 SR5P
    Another fairly easy option would be air bags in the rear. I haven't tried them yet, but they worked well in my Frontier, and others like them in the 4R.
  8. Oct 14, 2021 at 10:07 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    I'd try changing your tires and see if that improves anything. I found the handling of my similarly equipped 4Runner to be fantastic. I had stock size Falken Wildpeak AT3w put on day one, immediately after leaving the dealer.
    Next up was my Eibach Pro Truck Lift (4 shocks / 4 springs). I have it set at the lowest setting on the front shocks. Finally I had SPC upper control arms added with my next tire size - 285/70R17.
    Best handling in the curves was with 265 Falkens. 285's are bigger and heavier. While the steering is tighter with the UCAs, the mud tires don't grip as well. I can go pretty fast in the curves when it's dry. Wet / damp, I have to really slow down.
    I'd try some different tires.
    Otherwise I hate to say it but...
    You just need to get used to the way the 4Runner handles. It handles differently that most pickup trucks.
    Off-road I find tippy is fun and am amazed about how sideways I get my 4Runner.
  9. Oct 14, 2021 at 10:35 AM
    Funny, I have a similar pic:
    :D
    You have to tilt it until the trees are straight to really see. I think you're more tilted than me in yours.
    DRobs[QUOTED] likes this.
  10. Oct 14, 2021 at 8:54 PM
    a522467
    Michelle
    Ohio
    2020 Black 4X4 SR5
    I had an ‘08 4Runner for many years, so I thought I knew what to expect. It had the Urban Runner package though, which probably had sportier suspension for on-road shenanigans. Im pretty confident that tires and sway bars will do the trick on this ‘20 SR5.
  11. Oct 15, 2021 at 3:45 AM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I honestly believe in suspension. I put an Ironman suspension on and it was night and day difference. So much stiffer through the turns. This was me this past weekend going through a deep rut and my hood was just below this picture (phone was recording a video so I took a picture from that). I could reach out with no problem and touch the berm.
    DRobs and SlvrSlug like this.
  12. Jun 9, 2022 at 2:01 PM
    Self-Sponsored
    Self-Sponsored New Member
    2020 4runner SR5 4x4
    Eibach stage 1 lift kit, aFe intake, aFe throttle body spacer, Magnaflow Overland exhaust, 285/70/17 Mickey Thompson Baja Boss AT tires, Black FN FX Pro Wheels, 3/4 roof rack
    I have the same truck and problem with my eibach stage 1 kit. You really have 2 options besides finding a thicker sway bar.
    1- go back to oem front springs and click up on your front eibach shocks to keep the ride level the same but stiffen it up.
    2- purchase the Tacoma eibach front springs which are about 100lbs stiffer on each side and same geometry but longer and then click down on your front shocks to keep the ride height the same.
    I am leaning towards the 2nd choice. Let me know what you end up doing.
  13. Nov 1, 2022 at 6:16 PM
    Helix
    Helix New Member
    Ron
    OP, did you find a solution? I have been looking for heavier swaybars myself to control the bodyrol but have not been able to find any. Someone mentioned that the TRD Sport might have thicker bars. I have not been able to confirm that thus far.
  14. Nov 1, 2022 at 7:39 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    Use the swaybar that comes on the Supra. This means you should trade it in the 4Runner for a Supra. It will handle the curves on the paved roads beautifully. You will never find a sway bar for the 4runner that does a better job.
    J/K - Keep the 4Runner
  15. Dec 27, 2022 at 7:08 PM
    RT Coker
    RT Coker New Member
    I too, have a 2022 4 Runner TRD Pro. I have a 2006 Taco SR5 4 wd. My Taco can take curves and exit ramps about 20% faster than the 4 runner, due to body roll. I am looking at replacing the front sway bar with the Tacoma bar offered by Hellwig (part NO. 7719 looks like it should work). Anyone switched out theirs for this? Remember, also, the Taco has leaf springs in the rear, whereas the 4 runner has coil springs. I love the highway ride I am getting with the 4 runner, but hate the body lean/roll. It's actually scary compared to what I am used to with the Taco.
    Any help is appreciated. i am wondering what the O.P. ended up doing.
  16. Dec 27, 2022 at 8:14 PM
    Stiffer coils and tires with thicker sidewalls.
    SlvrSlug and kmeeg like this.
  17. Dec 28, 2022 at 11:35 AM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Your 4runner is also 600 lbs heavier than your taco... And a lot of that weight is up higher as well...
    mrmike7189 likes this.
