Steering while in 4WD question
Discussion in '5th Gen 4Runners (2010-2024)' started by Tylandus, Jan 21, 2020.
  1. Feb 25, 2020 at 1:12 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    WTF is a Prestige 4Runner
    And no part-time 4WD system overdrives the front differential. You'd have to have completely different ring and pinion ratios to do this. Or smaller tires up front.
    Drivetrain binding occurs when the front wheels travel more distance than the rears (and are therefore rotating more). This occurs when the truck is making tight turns. It has nothing to do with overdriving the front axle. You can drive in a straight line in 4Hi as long as you like.
  2. Feb 25, 2020 at 5:19 AM
    Dark Knight
    Dark Knight Get off my lawn
    The thread topic was about 5th gen. That’s what I replied to.
    alittleoff likes this.
  3. Feb 25, 2020 at 7:33 AM
    Tylandus
    Tylandus [OP] New Member
    Ryan
    Former Taco owner. 2019 4Runner SR5 Premium/3rd row.
    I have the 2019 StL Market SR5 Premium; not sure what a Prestige package is.
  4. Feb 25, 2020 at 8:35 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    2017 T4R Pro 040
    Is plasti-dip a mod?!
    Op, basically you are experiencing binding of the drivetrain, which you want to avoid if possible. For the tight turns, as long as it is not a slippery mess, just take it out of 4wd, then it won’t bind on you. Binding of the drivetrain can lead to excessive wear. So if you have decent traction, just put it in 2wd. Just keep in mind 4wd doesn’t help you stop, only go. Hope this helps.
  5. Feb 25, 2020 at 2:47 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    So I looked at the visor notice this morning. I had to pull it out of its pocket because I'm not 8 years old enough to see it from the seat :D It's even more vague than the manual, and nothing explicitly states that damage can occur in either the visor notice or the manual. So... Yeah. Still a good idea to avoid the binding from what I've read, though.
  6. Feb 14, 2021 at 7:57 AM
    Jay Tearules
    Jay Tearules New Member
    2018 Toyota 4Runner SR5 Limited
    Hey man, I just got a 2018 & noticed the exact same thing while in the drive through at Taco Bell, kinda freaked me out. Thanks for asking the question. Looks like the answer is we should switch out of H4 when on solid/dry-ish surfaces.
