SPC UCA failures
Discussion in '5th Gen 4Runners (2010-2024)' started by 2021venture, May 4, 2023.
  1. Feb 21, 2024 at 2:54 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Dobs Billet. I’m 2.5” lift and amazing alignment!
    Kad2112 likes this.
  2. Feb 21, 2024 at 3:00 PM
    2021venture
    2021venture [OP] New Member
    Todd
    2021 Venture
    The billet are bling and I know provide adjustability. I am on the fence if tubular meets my needs.
    raimieb[QUOTED] likes this.
  3. Feb 21, 2024 at 3:13 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Same thing with my local shops re: recommending SPC. Correct. But not only that about the high amount of adjustability, it's recommended because until the notorious manufacturer material issues SPC was rock solid. The control arm is also robust and heavy
  4. Feb 21, 2024 at 4:33 PM
    When I was considering going down the ‘lift’ rabbit hole, the local 4x4 shop was recommending SPC. As I remember, it was for the adjustability. My concern was that adjustability could lead to more opportunities for parts to loosen.
    djwantke likes this.
  5. Feb 21, 2024 at 4:40 PM
    Adjustability is mostly for things like castor, and is set with the star plate before torquing the 32mm nut to a whopping 150ft-lbs.
    It ain't loosening.
  6. Feb 21, 2024 at 9:06 PM
    Wow! Now that’s torque.
    djwantke[QUOTED] likes this.
  7. Feb 22, 2024 at 11:43 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Lots of dead SPC UCA's at the Tread Depot.
    I just ditched them and went with Apache Off Road UCA's. They come with Moog problem solver ball joints. Also, these arms accept OEM sized ball joints; No more proprietary ball joints.
    I was still able to get 4.5 - 5 degrees of caster. Truck drives perfect.
    Full disclosures my SPC ball joints failed in 10 months with around 15k miles on them. I greased them 3 times in total. Once on install. Once every oil change after that. And yes I bought some of the grease that SPC calls for specifically. I do wheel every couple of months and drive pretty hard. Maybe that contributed to them failing so early...
    When they were first going bad I could barely hear a squeak. Eventually when I would turn right my drivers side ball joint would make a "thunk" noise. I could feel it in the steering wheel as well. It took my a while to track down the noise frankly because the arms were so new I just checked the torque and ruled them out. I should have investigated more. The pop/thunk noise got worse and worse, I eventually jacked the rig up and noticed excessive play in the SPC UBJ.
    I threw the SPC arms in the garbage. Buying another set of proprietary ball joints every few months is not something I want to do.
    Honestly, buying them was one of my most expensive mistakes... Next to purchasing Rivian stock.
    :laugh:
    If you have them already, run em. Lots of people have great luck with SPC's. But my personal recommendation is have another set of UCA's ready to buy. Or at least another set of SPC's ball joints in your spare parts box. I won't run them again.
    Rocko9999, djwantke and Slopemaster like this.
  8. Feb 22, 2024 at 11:48 AM
    2021venture
    Todd
    2021 Venture
    Are you in DFW? Not sure if there are Tread Depots elsewhere.
  9. Feb 22, 2024 at 11:49 AM
    1SilverRunner
    Tejas
    Yea
  10. Feb 22, 2024 at 12:11 PM
    Branden967
    Branden967 New Member
    6400' in CA
    2023 TRDOR Premium
    Kings Suspension SCS 17X9 -10 OS Ridge Grapplers If its chrome....black it out.
    Sorry for if this is a dumb question....Do you have to do another alignment when you switch to the sealed ball joint or does it stay in spec by putting it back in the same detent?
  11. Feb 22, 2024 at 2:06 PM
    Technically they say yes, but I marked the star plate and nut when swapping balljoints to sealed, and the truck drives perfect now afterwards (to me). I honestly don't think there's anything the alignment shop would do that I didn't do already to exactly match the same setup I had with grease zerk balljoints.
    1SilverRunner likes this.
  12. Feb 22, 2024 at 2:40 PM
    1SilverRunner
    Tejas
    Sad to see but maybe SPC has went down hill. I used to see so many positive reviews on them, that's why I bought them.
    So many accounts of people running them for years without issue.
    Now I'm hearing shops say they revised the materials they used and that's what contributed to these issues.
    I've also heard other people say it was an isolated quality issue that was quickly resolved. Unless I bought old stock, I don't believe this was the case...
    What I know is that SPC did not want to warranty my ball joints when they failed. They aren't a cheap thing to replace. Instead of dealing with the run around from their warranty dept I decided to ditch them. Sucks to eat that cost, but sometimes you've gotta pay to play I suppose.
    JBA's are a great option as well, but with the state of the world right now I don't want a lot of proprietary service parts on my rig. I want to be able to go to a parts store or even a Toyota stealership and buy replacement ball joints. This is what lead me to Apache. There are many other options that provide additional caster without adding additional points of failure or proprietary parts.
    When the ball joints go, consider upgrading.
  13. Feb 22, 2024 at 3:18 PM
    Very true, and I'm in the same boat not knowing if I bought a good batch or bad batch. My balljoints did last 3 years but they were fucked when I removed them.
    I don't think I've heard of Apache. But boy I'm listening now!
    But @1SilverRunner do you have any idea how your axis bushings held up, not the balljoints
  14. Feb 22, 2024 at 3:19 PM
    1SilverRunner
    Tejas
    Didn’t even look at them.
  15. Feb 22, 2024 at 3:37 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    There shouldn't even be a question of good batch or bad batch after the recall. The fact that any non-trivial number of bad parts were delivered to customers after such a major wake-up call doesn't speak well for their commitment to quality. They are off my list for any future mods.
  16. Feb 22, 2024 at 7:06 PM
    I mean I don't know if I follow, there very much is a good batch or bad batch. It's a matter of if you fall within the defective material product run, or not. You'll never get an answer to what exact dates the bunk balljoints were sold. You need to understand that SPC was a solid trusted name with much more happy customers than them brands ya'll are citing now. SPC was great, until it wasn't. But now apparently that's been resolved, but it's hard to say which product material you're receiving; good, or bad/suspect sku. I know many people who have received free warranty replacement. They are committed to making things right. Hell some people have had zero probs with their SPC, ever.
    Now you go
  17. Feb 22, 2024 at 7:35 PM
    backpacker
    2023 TRD ORP
    Yes, I agree a batch can be bad. They have to know by testing, and after having had to do a major recall, it behooves them to know whether a batch meets specs before it ever reaches a customer's hands. Also, as part of the recall, they should know who they delivered parts to, and which delivered goods have or haven't been replaced by recall. Is there still a manufacturing problem? Is SPC being lax about letting their customers resell recalled parts, either to end users or resellers?
    I'm not impressed by formerly solid reputations. In my life as a small-scale manufacturer, I had to disqualify or put training wheels back onto a lot of suppliers that previously had stellar reputations. Some of them worked through their problems. Others did not. The ones that did were diligent about tracking down and following up.
  18. Feb 22, 2024 at 7:59 PM
    1SilverRunner
    Tejas
    Coming from the manufacturing industry I can understand batch failures and recalls. I want SPC to succeed and I want their customers to have a good experience.
    I’m cautiously hopeful that I got a bad batch and others will have a better experience.
    :computercoffee:
  19. Feb 23, 2024 at 7:02 AM
    #49
    No ya ur right. I agree
    Problem is I don't always buy direct from manufacturer, especially in Canada who doesn't manufacture or invent a damn thing lol
    So when someone buys SPC's here, it could be a crapshoot. More than anything I would love SPC to use the knowledge they surely have regarding material testing so identify which channels were distributed bunk parts. I just don't know how much they've invested in doing so!
    And "is there still a manufacturing problem?"
    I actually don't know if we can believe them when they say no, but I think they say no
  20. Feb 23, 2024 at 7:37 AM
    #50
    backpacker
    2023 TRD ORP
    I hope for their sake that any post-recall problems stem from a new failure mode that somehow escaped renewed vigilance. Unscrupulous resellers dealing in recalled parts worries me more, since it's harder for them to control. One strategy is demanding physical return of all unsold parts and submission of sales documentation to show that the balance went to end users (that information is also useful for recall cost estimation). If a reseller can't or won't comply with that, the manufacturer has to weigh the reputational risk of continuing to supply that reseller. That technique can also identify resellers who may have dumped recalled parts to third-party resellers. This is where the authorized dealer model has some benefit, although it usually adds to end-user cost.
    Anyway, I wish them luck.
    EDIT: I wanted to add a subcategory of reseller misbehavior, which is rather than sending back recalled parts, vendors are often given the option to scrap them. That's a gold mine for crooked vendors who sell recalled part for which the supplier reimbursed them which they claim to have scrapped.
  21. May 22, 2024 at 11:02 AM
    #51
    2021venture
    Todd
    2021 Venture
    Saw this pic from my shop on SPC failure stack growing. I can see mine in the stack. Most people must not use the yellow zirk caps to keep dirt out.
    Rocko9999, Kad2112 and djwantke like this.
  22. May 22, 2024 at 11:40 AM
    #52
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    When I had my lift put on (6112/5160) the shop recommended the newer SPC. I had asked for JBA based on reviews here, but they didn't have an account with them. As my front was going up 2.7" I wasn't keeping stock UCA's so went with their suggestion. Anecdotal I know but per my local shop they claim they have had zero issues with the newer SPC's. So I'm hoping that's accurate and holds true for me. Either way I have a 3 year parts/labor warranty with the shop, so if they do die I sure hope its within that window.
  23. May 22, 2024 at 12:07 PM
    #53
    1SilverRunner
    Tejas
    Savage.
  24. May 22, 2024 at 1:57 PM
    #54
    Sealed balljoints or zerk grease fitting?
  25. Jun 27, 2024 at 9:09 AM
    #55
    Leadnuts
    Leadnuts New Member
    I’m on my 3rd set of SPC ball joints in 3 years.. I replaced them last year on the quick. Took it to my mechanic for some steering issue. He said they had way too much play and needed replacing. I was about to leave a 4 days on a long camping trip. He said luckily I don’t need an inspection as he couldn’t pass it like that. So they quickly got some somewhere and put them on.. ended up leaving from his shop from to travel
    So I’m 5 days from leaving to camp around the Boundary Waters area..and yesterday, I took it in for a slight clunk when stopping, and he says, “didn’t we just replace these? Cause they are shot.”
    I’ve been greasing them religiously with the special moly grease they told me to use as they told me the last set went bad due to the wrong moly grease…
    I contacted SPC yesterday but I don’t have the actual receipt so they “can’t help”. I keep bugging the mechanic, but he can’t remember where he got them, it was so rushed he paid the overnight shipping but can’t remember where from.. this is a small shop guy and I pressured him to get them on as fast as he could.
    Im not sure I have time to change out the whole UCAs at this point. I’ll have to do the joints then when they go bad (and I’m totally certain they will) move to another set maybe oem.
    id spend my money elsewhere if i had the choice.
  26. Jun 27, 2024 at 11:42 AM
    #56
    1SilverRunner
    Tejas
    Sorry about your luck bud.
    I'd start putting some money aside for Dobinsons, Apache, or JBA if you're cool with proprietary ball joints.
  27. Jun 27, 2024 at 3:36 PM
    #57
    2021venture
    Todd
    2021 Venture
    Got rid of the SPC and went with Apache. No proprietary ball joint. If it ever fails I can get a Moog problem solver ball joint easy. Very heavy duty.
  28. Nov 28, 2024 at 2:50 PM
    #58
  29. Feb 21, 2025 at 6:30 PM
    #59
    Spare Parts likes this.
  30. Feb 26, 2025 at 5:38 AM
    #60
    johnnyg182
    johnnyg182 New Member
    2019 TRD Pro
    2” lift - SPC UCA - 285s - RCI skids - C4 Gas Skid - C4 Sliders
    Did you end up with completely new SPC arms or did you replace your X axis bushings? My bushings have play in them. I have the new black ball joint version to install and noticed the bushings have play too. Trying to determine if I return the BJ and just fork over cash for a diff UCA. But would consider swapping the bushings on my own. Found this video on how to do it.
    https://youtu.be/dQ9H4nocUhE?si=eKx1oQ1VNvXzgTW2
