Solar Octane Thread
Discussion in '5th Gen 4Runners (2010-2024)' started by steelevo, Apr 10, 2023.
  1. Sep 5, 2024 at 8:30 PM
    #481
    epnk
    epnk New Member
    Eric
    BC, Canada
    ‘24 TRD ORP Solar Octane
    17x8.5” Fuel Oxide Rims Gunmetal/Black +1 offset
    What width are those rims? I have +1 offset and would like to go to 285s as well just was worried about having to do BMC. Looks good
  2. Sep 5, 2024 at 8:42 PM
    #482
    K1mJ0ngTr1ll
    K1mJ0ngTr1ll New Member
    Trd Pro Solar Octane
    8.5! I think I’ll be able to not have to do the BMC after my could are on.
    epnk[QUOTED] likes this.
  3. Sep 6, 2024 at 4:56 PM
    #483
    epnk
    epnk New Member
    Eric
    BC, Canada
    How much of a lift will you have afterwards? And I’d definitely like to know if you got away without the BMC that’s the only thing stopping me from wanting to push 285s. Bumper trim and fender push back isn’t a big deal to me if needed. Thanks
  4. Sep 6, 2024 at 5:27 PM
    #484
    K1mJ0ngTr1ll
    I think it’s 1.4in in the front. I haven’t taken of the flaps yet but rarely rub there.
  5. Sep 13, 2024 at 9:01 PM
    #485
    K1mJ0ngTr1ll
    No chop needed! Did need to remove the flaps though.
  6. Sep 13, 2024 at 9:02 PM
    #486
    K1mJ0ngTr1ll
    Wrong pic lol. This is lifted.
    epnk, RusPro17 and MooreKen like this.
  7. Sep 14, 2024 at 5:00 AM
    #487
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Nice. I just added the Eibach springs also. If you want to keep front flaps. I added the Rockbloz flaps they will work with no rub.
    epnk likes this.
  8. Sep 14, 2024 at 5:14 AM
    #488
    K1mJ0ngTr1ll
    Truck looks great!
    RusPro17[QUOTED] likes this.
  9. Sep 14, 2024 at 5:19 AM
    #489
    RusPro17
    Don
    Pa.
    Curious what were alignment specs you got? Thank you!! So does yours.
  10. Sep 18, 2024 at 8:53 PM
    #490
    K1mJ0ngTr1ll
    Id have to call the shop that did it but I have no wander or rubbing on the cab mount after pulling the flaps.
  11. Sep 18, 2024 at 8:53 PM
    #491
    K1mJ0ngTr1ll
    This color just does it for me.
    Naville, icestud and epnk like this.
  12. Sep 19, 2024 at 5:00 AM
    #492
    RusPro17
    Don
    Pa.
    No problem usually the alignment place gives you a print out on the specs. I just wanted to compare to what I have on mine. I have no issues either with wandering or rubbing and I’m running with Rockbloz mudflaps on mine. I prefer to have them on cause of the aggressive off set on my SCS wheels with the poke on my tires a little.
  13. Sep 19, 2024 at 3:01 PM
    #493
    K1mJ0ngTr1ll
    just the stock pro rack.
  14. Sep 19, 2024 at 8:29 PM
    #494
    Sorry. I meant to quote @Tooly - his roof rack is different. Just wondering if that is an early 5th gen roof rack.
  15. Sep 19, 2024 at 8:49 PM
    #495
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Yes it's off a 2010 to 2013 4Runner trail. I think it's the best looking factory rack Toyota offered on the 5th gen and function wise it's better then the standard one as the crossbars sit at least an inch higher from the roof.
    MeefZah likes this.
  16. Sep 19, 2024 at 8:51 PM
    #496
    Mounts using the same holes?
  17. Sep 19, 2024 at 9:42 PM
    #497
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Yup same holes. Just some additional brackets under the rails. Different bolts at well but I actually used the same installation package as you would use to mount the Pro rack.
  18. Sep 20, 2024 at 7:24 AM
    #498
    epnk
    epnk New Member
    Eric
    BC, Canada
    Pushed front Bilstein 5100s to 2.5” to level it better with the 1.5” rear and added Nokian Outpost nAT tires in LT275/70/R17. So much better and smoother ride then the stock dunlops, they do rub in full lock reverse will have to do some trimming.
  19. Sep 20, 2024 at 7:28 PM
    #499
    Naville
    Naville New Member
    In this color it is one of the best looking trucks on the market in decades....superb!
    Wawa 4runner and RusPro17 like this.
  20. Oct 3, 2024 at 2:12 PM
    #500
    RusPro17
    Don
    Pa.
