snow driving in parking lots sucks - normal or just a me issue?
Discussion in 'Performance' started by girlcat4runner, Oct 30, 2024.
  1. Nov 4, 2024 at 6:01 AM
    #61
    roc
    roc New Member
    Michigan
    2021 4Runner TRD ORP
    I got permission to go back to an 1850's stamp mill but to get there I had to drive up part of the waste rock pile, they had just excavated where the trail used to be.
    Must have hit an old blacksmith shop because there was metal all over. Spent about a half hour rolling rocks out of the way and picking out metal. Figured that would be a perfect place to use the locker
    with all that trash in the rocks to keep from spinning a tire. Of course the locker wouldn't lock ,messed with it quite awhile and finally the dash lit up saying four wheel drive malfunction see your dealer.
    Shut it off, was going to go for it anyway, double checked for any more metal. Started it back up and all went back to normal and the locker locked right up.
  2. Nov 4, 2024 at 6:05 AM
    #62
    2X4Runners
    2X4Runners New Member
    For some reason I thought the locker could only be engaged in 4 lo? Maybe I’m thinking of my rubicon.
  3. Nov 4, 2024 at 6:17 AM
    #63
    icebear Recovered Kia Owner
    You’re correct, it’s a limitation imposed by Toyota and not uncommon (Xterra also required 4Lo before locker, stock)
    Shredder and Thatbassguy like this.
  4. Nov 4, 2024 at 6:25 AM
    #64
    Correct. But it’s possible to take it out of 4 low with the locker still engaged . At least on the manual shift transfer case. If I recall, in the situation I mentioned where my locker did not disengage and I drove on the highway with the locker light blinking…. i had to pull over, go into 4lo, then I commanded locker on, then off, then slow pulling forward with the left/right steering, then it turned off.
    The locker is really one of those things that’s best used with some discipline. Only turn it on for a particular obstacle or situation, then turn it off once you’re done. Right then and there. I got sloppy and forgot to turn it off until I was faced with getting back onto a paved highway.
  5. Nov 4, 2024 at 6:28 AM
    #65
    This seems similar to the situation I had that led to the locker not working anymore. I think you might have even been there while I was driving back and forth in the parking lot at TK Country Convenience trying to get it to disengage.
  6. Nov 4, 2024 at 6:40 AM
    #66
    Maybe…I would hope that these would be a little more tolerant to these kinds of mistakes. But who knows. The actuator may have failed, or maybe something mechanical in the actual locking mechanism.
    If only we all had enough time and motivation to find out :laugh:
    My old transfer case is also sitting under the bench waiting for it’s own post-mortem inspection. But my curiousity hasn’t been motivating enough for me to tear into it yet lol
  7. Nov 4, 2024 at 7:19 AM
    #67
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    This is the 4Runners way of telling you to do doughnuts in the parking lot.
  8. Nov 13, 2024 at 9:24 PM
    #68
    girlcat4runner
    girlcat4runner [OP] New Member
    2016 SR5 Premium gray
    Thanks for all the comments! I've talked with other 4runner owners I know and none have had the issue I've had, so I'm thinking something is wrong with mine. I've been testing it a bit lately and when I move back to 2WD, it takes a minute to disengage and the panel light stays on. Yesterday, I backed from my driveway (in 2WD) and as I pulled forward...the 4WD dash light flashed on and off...first time it had done this. I'm now looking into trading in for a used Limited Nightshade.
    djwantke likes this.
  9. Nov 13, 2024 at 10:23 PM
    #69
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Interesting.
    Big thanks for the update, folks care about helping other folks out. Often times the OP of threads disappear after gathering insight.
    Goodluck!
