Slightly bent tow hitch
Discussion in '5th Gen 4Runners (2010-2024)' started by leaguer4, Nov 25, 2024.
  1. Nov 26, 2024 at 6:26 AM
    TRD8
    TRD8 New Member
    North Georgia
    Was there a rubber Toyota receiver plug installed in the hitch when you purchased your new 4Runner? The plug is not an accessory that Toyota includes on delivery.
  2. Nov 26, 2024 at 6:30 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    I'm gonna go out on a limb here and say that was a defective hitch and nobody backed that vehicle into something. the paint at the deformed part is intact. If someone backed the vehicle into something hard enough for that to deform like that, the paint at the deformity would be damaged and there would probably be damage to the rear crossmember.
  3. Nov 26, 2024 at 6:36 AM
    We don't yet know if this was considered new, a loaner, demo, or what. Details are missing. Besides that, any dealership could add a rubber plug pre delivery.
    Another detail missing is whether a 2" hitch bar will go into this receiver, or is it deformed too much to allow that?
    Saker likes this.
  4. Nov 26, 2024 at 8:43 AM
    leaguer4
    leaguer4 [OP] New Member
    Thank you all for the replies to this situation. For anyone wanting the full story here it is:
    I purchased the vehicle in Tennessee (live in Oklahoma) with 159 miles or so. CARFAX came back clean and says it was a rental vehicle. I asked the salesman to elaborate and he said that this trim (SR5 Premium) was never intended to be a rental so the rental company sold it and that's how it came into the dealers hands.
    I did my best for a thorough inspection when I got there and got as many pictures of the engine bay and undercarriage before I got there but I never thought to look at the tow hitch. I bought the vehicle and drove it home (about 750 miles) with no issues. I work at a shop that has an alignment rack so I put it up high and snapped some pictures of it and didn't see any signs of damage. A technician mentioned that maybe someone might have put a tow hitch that was the wrong size and maybe it got bent with a nasty bump or braking. I'm taking it to the dealership tomorrow for an inspection and an oil change. Almost at 1000 miles.
    Here are some pics for reference. Hoping this isn't as big of a deal as some are saying.
  5. Nov 26, 2024 at 9:55 AM
    steelevo
    Utah
    Hmmm… A rental vehicle that left the fleet early is a red flag, regardless of the BS that the salesman feeds you.
  6. Nov 26, 2024 at 10:04 AM
    Hopefully this will just end up needing a replacement hitch. From the limited view available, everything else still looks new. I hope you got a great price on this...
  7. Nov 26, 2024 at 10:05 AM
    Toolguy73
    Toolguy73 New Member
    Dom
    South Jersey
    2023 Limited White/Redwood
    Have the frame measured and spec'd. Get the results in writing.
    TrailSpecial22 and leaguer4[OP] like this.
  8. Nov 26, 2024 at 10:26 AM
    Folks on this board think a tow hitch is some precision manufactured assembly :laughing:
    Typical steel square tube stock can have significant waviness in the sides, because it's made by bending a sheet into shape and welding the seam. You may have heard the term hot rolled electron welded (HREW):
    In addition there will be some warpage from welding the tube into the hitch.
    Paint has poor adhesion to welds and the tow hitch has a lot of welding concentrated in a small area. I've seen tow hitch rusting on Toyotas sitting on the lot. Expect the paint on welds on your frame to chip the same way after a year or so.
    MeefZah likes this.
  9. Nov 26, 2024 at 10:41 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Toyota hitches suck anyway, my 2013 was so shallow my bike rack wouldn't seat deep enough for the locking cross bolt. Had no issue in my previous Yukon, but was short by almost 2". I ended up having a local welder add on the extension using the proper steel. Hopefully just an easy swap for you to get this corrected.
  10. Nov 26, 2024 at 10:54 AM
    leaguer4
    I don't see any damage behind the tow hitch but then again I'm not sure what I'm looking for.
    Saker likes this.
  11. Nov 26, 2024 at 10:56 AM
    leaguer4
    No there wasn't anything like that installed
    TRD8[QUOTED] likes this.
  12. Nov 27, 2024 at 5:06 AM
    2X4Runners
    2X4Runners New Member
    Two pics: one has never been towed with and has about 7,000 miles on it up here south of buffalo NY so it’s seen some crappy weather. Other one has been towed with at times. This “towing” 4R has about 28K miles and sees more dirt roads, mud, snow and salt. Looks like someone probably backed in to something, but as others have said, the paint on these chips really easily and once that happens they start to rust right away. I’d replace the one on yours with a new one just because the damage and rust would bother me. It’s a quick 15 minute job, but you’ll probably need an impact gun to get the bolts loose.
  13. Nov 27, 2024 at 5:06 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    I don't think there's anything to worry about as long as the draw bar slides in okay. The welds look good from the picture and you're going to be using safety chains when trailering anyway.
