SLIDERS
Discussion in 'Armor' started by mcharfauros, Jun 20, 2019.
  1. Apr 3, 2024 at 2:02 AM
    #91
    BoiseG
    BoiseG New Member
    2024 Off-Road Premium
    Great thread with some years on it so I’m hoping someone with a few years experience with RSG can give some feedback. Any issues with rust or powdercoat?
    I’m considering the RSGs on a 2024 ORP with kdss. Any active discount codes available?
    Thank you
  2. Apr 3, 2024 at 5:56 AM
    #92
    can0nfan2379
    can0nfan2379 New Member
    Arid-zona
    2019 T4R ORP...2013 TRD OR DCSB Tacoma
    BAMF 10 degree sliders with kickout, bolt on. Had them on the Tacoma as well - top notch design and mounting.IMG_2141.jpg IMG_2026.jpg
    djwantke, R4Adventure and dgrenier15 like this.
  3. Jun 14, 2024 at 9:33 AM
    #93
    R4Adventure
    R4Adventure New Member
    Omaha, NE
    2004 Gray 4Runner SR5 V8
    2.5" Bilstein lift, 1" body lift, 34" tires on 17x9 Method Racing 312 wheels, CBI front bumper with Warn EVO10s winch, full RCI under armor and rock sliders, ARB front and rear air lockers, 8.2" rear axle house swap, etc....
    In my opinion, the Shrockworks sliders I had on my 2019 4Runner TRD OR where the best looking ones on the market. They had the more extreme angle but the top plates were still flat. They were very stout as well. To bad they went out of business.
  4. Jun 14, 2024 at 9:39 AM
    #94
    R4Adventure
    Omaha, NE
    On my current 4th Gen 4Runner, I am running RCI rocksliders, who recently updated there design that allows you to remove or add the top plates after the fact. I ordered mine without them. The kickout matches well with my wheel offset and tire width.
    djwantke and dgrenier15 like this.
  5. Jun 14, 2024 at 9:47 AM
    #95
    I went All Pro Apex on my 19. I had them on my Tacoma as well.
  6. Jun 17, 2024 at 7:58 AM
    #96
    jake long15
    jake long15 Cali Raised LED
  7. Jun 20, 2024 at 9:44 PM
    #97
    FourT6and2
    FourT6and2 New Member
    Looking at either RSG or Cali Raised. Angled, no kick. Anybody know how far each ones sticks out? I've seen some other threads with measurement but there were some odd inconsistencies. I'm actually wanting ones that stick out the LEAST.
    jake long15 likes this.
  8. Jun 21, 2024 at 7:50 AM
    #98
    jake long15
    Great questions! I can get you some pics, if you DM us on instagram, or email info@caliraisedled.com, I can send you over some different angles!
    FourT6and2[QUOTED] likes this.
  9. Jun 21, 2024 at 3:42 PM
    #99
    FourT6and2
    Sounds good, thank you. And if you have a measurement of how far yours sticks out from the rocker panel, that's all I need for the most part.
  10. Jul 21, 2024 at 5:03 PM
    #100
    Hilux1
    Hilux1 New Member
    Jon
    2024 TRD Off Road-Premium
    Just ordered a set of RCI sliders. I’m local and figured it’ll be easier then worrying about shipping.
    I do have a question, anyone know if you can fit sliders in the back of the 4Runner? I have a trailer I can load them onto but wondering if I can get away with not using the trailer.
  11. Jul 21, 2024 at 7:04 PM
    #101
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    July 14
    JR Customs: CNC Cutting and Fabrication
    custom powder coated dom
    1/4” mounting plate (w/ KDSS)
    10°, no top plates
  12. Jul 23, 2024 at 9:14 AM
    #102
    R4Adventure
    Omaha, NE
    I would suspect you could fit them in the back with your 2nd row seats folded down. If you got your sliders in raw steal, may be easier to remove them from the boxes, or wrap them in something if you got them powdercoated.
    Hilux1[QUOTED] likes this.
  13. Jul 23, 2024 at 2:45 PM
    #103
    Hilux1
    Hilux1 New Member
    Jon
    That’s good. I’ll bring a set of furniture pads to wrap them in and put the seats down. Should fit I would think.
  14. Jul 28, 2024 at 8:10 PM
    #104
    Damn! No sliders :eek: :canada:
