Skinnies vs Wide(315/70R17 vs 255/85R17)
Discussion in '5th Gen 4Runners (2010-2024)' started by RedRunner87, Jul 30, 2023.
  1. Aug 1, 2023 at 2:16 PM
    ToyotaRDie
    ToyotaRDie New Member
    I've had great success with my Kenda 33x10.5. I absolutely love these tires in any road condition.
  2. Aug 1, 2023 at 8:03 PM
    RedRunner87
    RedRunner87 [OP] Mall Crawler LVL Expert
    Vince
    The Springs, CO
    16 4Runner SR5
  3. Aug 1, 2023 at 8:04 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    255's only come in load range E tire. Not sure about 315 though
  4. Aug 2, 2023 at 1:09 AM
    Jasonst4r
    Jasonst4r New Member
    Jason
    2021 offroad barcelona red
    275 70 17 at3w
    Thats the only MT ive run so far. Id never go back to that tire, even if they were half off sale. Im considering going to a MT when i go from 275s to 33s or 34s. whats your impression with them in wet and snow?
  5. Aug 2, 2023 at 3:21 AM
    So, you are comparing an MT to other types of tires as far as rain performance? Of course they are going to be worse than anything else you've ever used. This is just like putting DOT slicks on a car and then complaining about wet traction.
    If you are concerned about wet and snow performance, you definitely should not be thinking about running an MT. You should be looking at 3PMSF all terrains.
    Mine have been beyond satisfactory to my expectations in most conditions. Do they stop like highway tires in wet conditions? Hell no. But, I knew this before I even bought them.
    nimby and SlvrSlug like this.
  6. Aug 2, 2023 at 7:28 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    This is one of the reasons I am leaning towards the Baja Boss AT, it is 3PMSF. I am also looking at the Wildpeak RT, but it is not 3PMSF. Ruby is still my daily in the winter, so I will need the snow performance in the winter.
  7. Aug 10, 2023 at 11:23 PM
    Jasonst4r
    Jason
    275 70 17 at3w
    read what i said.
  8. Aug 11, 2023 at 12:37 PM
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    This is a good thread. I ran Toyo AT3’s in 255/80/R17 on my Tacoma and really liked them. I’m about to upsize my 4Runner tires and can’t decide between 255’s and 285’s. My Tacoma really liked the lighter weight 255’s (53 lbs) as I wasn’t regeared but was tuned which worked well.
    I’d rather not regear my T4R and I also like that 255’s shouldn’t require much trimming, if any, where 285’s may need a BMC. There are some lighter 285 options but I like E-load for the durability.
    I have the 4Runner pro wheels and right around 2” of lift so offset should work well for both tire sizes and minimize my need for trimming things. Alignment is set to push the wheels forward as much as possible with OME UCA’s.
  9. Aug 11, 2023 at 7:17 PM
    RedRunner87
    Vince
    The Springs, CO
    16 4Runner SR5
    Go 255's and have no regerts(lol). I love my 255's and I don't think I will ever go wide
    BortisYeltzen[QUOTED] likes this.
  10. Aug 12, 2023 at 10:50 AM
    You said that they're the only MT you've run. So, you have nothing to judge them against.
    And then you said you're considering switching to an MT again, and I said that you shouldn't be considering MT's if you're concerned about snow and wet traction.
    Did I miss something?
  11. Feb 3, 2025 at 6:17 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    HuskyMike likes this.
