Side mirror swap to add turn signal and puddle lamp
Discussion in '5th Gen 4Runners (2010-2024)' started by Das Capitolin, Sep 11, 2020.
  1. Sep 16, 2020 at 3:45 PM
    Sarcy
    Sarcy New Member
    Some more pics
    Definitely missing some wires to my door harness:
    Looks like I'm missing some wires back here, so even if I add wires to my connector they're not going to work.
  2. Sep 16, 2020 at 3:57 PM
    dolbytone
    dolbytone New Member
    2020 TRD Off Road
    It looks like you’d need to add the pins and wires that are missing in the kick panel connector, then exchange the mirror connector for the right one for the mirrors with signals and puddle lights, re-pinning what’s already there to the new connector with the added wires you need.
  3. Sep 16, 2020 at 4:00 PM
    Sarcy
    Sarcy New Member
    Looking at the backside of the connector in the kickpanel, it looks like I'm missing wires, so even if I add pins to the kick panel connector there's nothing there to connect them to, right? Where would I get the pins, wires and connectors from?
  4. Sep 16, 2020 at 4:17 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    sarcy,
    thanks for the pictures. well we tried. i was hoping for the best that the plug was just missing the wires. but looks like where the plug goes into is also missing wires. only if i had a truck with no turn signals, i could poke around more.
    perhaps if you have the time, you can turn on your blinkers and poke around with a meter :) try to find the turn signals somewhere in there.
    until the turn signal wires are found in the cab, only option is to wire thru the fender to the physical turn signals. perhaps you can look at the colors of the turn signals in the fender, they might match something in the cab.
  5. Sep 16, 2020 at 4:28 PM
    Das Capitolin
    Das Capitolin [OP] New Member
    2019 4Runner SR5
    My 2019 SR5 just has standard heated mirrors, no turn signals or lamps. I did try to dig into the driver's kick panel, but aside from the plastic nut I did not immediately see how to remove the panel. I'll need to research, so I don't break anything.
  6. Sep 16, 2020 at 4:32 PM
    Sarcy
    Sarcy New Member
    Since it's all off now I'll see if I can find where the turn signal wires are and also need to figure out what I'm going to splice into for the puddle lamps to work. Any thoughts where I can get a new connector for the mirror since mine is round and the replacement is rectangle? Is this something you can just order from Toyota?
  7. Sep 16, 2020 at 5:16 PM
    Sarcy
    Sarcy New Member
    Daytonaviolet, any chance you can take a look at this connector and give me the part #?
    Daytonaviolet[QUOTED] likes this.
  8. Sep 16, 2020 at 5:28 PM
    Daytonaviolet
    Bay Area, CA
    it may be an entire harness which you’ll need to replace. It may not be worth it. If you can find the turn signal signals, you can just hardwire directly to the mirrors without they harness. I believe you can just tap of the dome/vanity lights for the puddle.
  9. Sep 17, 2020 at 10:13 AM
    Das Capitolin
    2019 4Runner SR5
    2019 4Runner SR5 with standard heated mirrors (no turn signal, no puddle lamp)
    IM13dNZXwNtApQ5ySnXbF-IrPIesjhyRpNwIOf9D_7a216aaf95ac03a11be47a8082a2e42744f0ba8d.jpg
    JtxTXS-7ldZfgo6OFnt6o1fxTAVyc9NSFTxpzrMp_3d820bca2e013fd5b1fda33f7437fe6e1d58aa68.jpg
    Daytonaviolet likes this.
  10. Sep 17, 2020 at 11:14 AM
    Daytonaviolet
    Bay Area, CA
    Thanks for the pics. Sarcy posted the other day that that the receptacle for that 22pin plug is also missing the turn signal wires. That means non premium or models with out turn signals and puddles use a different harness under the kick panel.
  11. Sep 17, 2020 at 11:29 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If you get the super bright MESO puddle pod LED modules you can check for monsters before getting in at night.
    I wired mine with a switch for anytime control for use as pseudo ditch lights.
  12. Oct 17, 2020 at 8:46 AM
    jvinhj240
    jvinhj240 New Member
    Ben
    is there setting for these light. i open door, unlock turn on light all switch. puddle light would not turn on at all?
  13. Oct 17, 2020 at 10:04 AM
    Daytonaviolet
    Bay Area, CA
    did your truck originally have puddle ?
  14. Oct 17, 2020 at 10:06 AM
    jvinhj240
    Ben
    I just bought it 2021, I look under i see light bulb both mirror.
  15. Oct 17, 2020 at 10:07 AM
    Daytonaviolet
    Bay Area, CA
    afaik, they should automatically turn on when you unlock the door. Also when you walk by.
  16. Oct 17, 2020 at 10:08 AM
    jvinhj240
    Ben
    Mine is nothing, I wonder any settings?
  17. Oct 17, 2020 at 10:28 AM
    Daytonaviolet
    Bay Area, CA
    Is this a new truck ? I wonder if the dealer needs to program it ?
  18. Oct 17, 2020 at 10:53 AM
    jvinhj240
    Ben
    its 2021 , bought few days ago
  19. Oct 17, 2020 at 11:31 AM
    #49
    Daytonaviolet
    Bay Area, CA
    Take it back to dealer and ask them why puddle lights don’t work.
    TRDPro916 likes this.
  20. Oct 19, 2020 at 8:41 AM
    #50
    jvinhj240
    Ben
    ^^ it working properly, i closed my garage so there are no light then all good. I thinking it shud be on everytime unlock. but yes only at dark.
  21. Oct 19, 2020 at 8:52 AM
    #51
    Daytonaviolet
    Bay Area, CA
    Ohh okay, so it does work. It should also turn on if you walk close to your truck(doors locked).
    https://youtu.be/05DUE4Wvv3Y
    jvinhj240[QUOTED] likes this.
  22. Oct 19, 2020 at 8:55 AM
    #52
    jvinhj240
    Ben
    yes all ok. even jsut walk close , but when dawn only. Now need to shop for LED . lolzzz. Is that ur mirror? too sexy.
  23. Oct 19, 2020 at 8:59 AM
    #53
    Daytonaviolet
    Bay Area, CA
    this is the best and brightest led ever. They will email you when available
    https://mesocustoms.com/products/4-runner-puddle-pods
  24. Oct 19, 2020 at 9:00 AM
    #54
    jvinhj240
    Ben
    out of stock. did you add folding mod too? total cost and time to install? you know how much it cost for puddle light. website doesnt show
  25. Oct 19, 2020 at 9:06 AM
    #55
    Daytonaviolet
    Bay Area, CA
    Meso puddle is ~ $100 but worth every penny. Yes I have folding mirrors from Cartrimhome.
  26. Oct 19, 2020 at 7:56 PM
    #56
    jvinhj240
    Ben
    CTH folding motor work on 2021 models? they listed 2014-2019
  27. Oct 19, 2020 at 10:07 PM
    #57
    Daytonaviolet
    Bay Area, CA
    I know it works for you 2020. The only difference was the trigger wire for auto fold during unlock.
    I haven’t worked on 2021 yet, but It may be similar to 2020. If you read the diy, I explain the 2020 wiring which is slightly different.
  28. Oct 20, 2020 at 4:30 AM
    #58
    jvinhj240
    Ben
    can you show your diy write up for folding mirror?
  29. Oct 20, 2020 at 6:32 AM
    #59
    Daytonaviolet
    Bay Area, CA
  30. Oct 20, 2020 at 10:57 AM
    #60
    jvinhj240
    Ben
    wow thanks nice write up. I will read thru it. Look like only different only lock/unlock different on 2021
