Show us your wheel and tire setup
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R21, Oct 3, 2021.
  1. Jul 25, 2023 at 5:14 PM
    #241
    GrantM64
    GrantM64 New Member
    M/T 285/70/17 Baja Boss A/T's on Method MR312
  2. Jul 25, 2023 at 5:22 PM
    #242
    TrailSpecial22 New Member
    PA
    Damn nice!! Can you please provide a semi-long term review on and off road experiences?
  3. Jul 25, 2023 at 5:26 PM
    #243
    GrantM64
    GrantM64 New Member
    After viper cut and rock slider install
  4. Jul 25, 2023 at 5:27 PM
    #244
  5. Aug 1, 2023 at 9:12 AM
    #245
    mal10015
    mal10015 New Member
    Connecticut
    2023 Lunar Rock Great Value TRD Pro aka TRD ORP
    265/70/17 Yokohama Geolandar G015 on new gen OEM TRD Pro wheels
    Stock suspension
    Tires made a huge difference in ride quality over the factory Dunlops
  6. Aug 1, 2023 at 10:21 PM
    #246
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Summit Wheels 17x9 -25 with KO2s - 275/70/17
  7. Aug 3, 2023 at 6:38 AM
    #247
    Grn4rnr
    Grn4rnr New Member
    Vannack
    ORP
    Bronze TE37 with 285/70/17
  8. Aug 3, 2023 at 6:43 AM
    #248
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Love that desert sled!!! I want one sooo bad
  9. Aug 3, 2023 at 6:45 AM
    #249
    Grn4rnr
    Grn4rnr New Member
    Vannack
    ORP
    Of all the bikes, the desert sled puts the biggest smile on my face on and off road.
    hossler1788[QUOTED] likes this.
  10. Aug 26, 2023 at 11:15 AM
    #250
    ak1215
    ak1215 New Member
    2022 Army Green ORP
    Love the truck. Just wondering what exact spring you went with in the rear? And is your truck kdss? Wanna fully do my research before I decide
  11. Aug 26, 2023 at 5:05 PM
    #251
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    285/70/17 BFG and Method 703's.
  12. Aug 26, 2023 at 6:11 PM
    #252
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Load E 285's
    84lbs ea. total :eek:
  13. Aug 26, 2023 at 6:14 PM
    #253
    Restored '16 spare, never been dropped luckily chain wasn't seized, hah
    Thatbassguy and TrailSpecial22 like this.
  14. Aug 26, 2023 at 7:06 PM
    #254
    Treetopflyer
    Treetopflyer New Member
    2018 TRD off road
    I just bought the same ones. Just waiting for my Ray10s to come… can’t wait.
    Thatbassguy and djwantke[QUOTED] like this.
  15. Aug 26, 2023 at 7:40 PM
    #255
    @Treetopflyer
    no way, great minds think alike
    Ooo slick wheel choice
    Thatbassguy and Treetopflyer like this.
  16. Aug 26, 2023 at 7:52 PM
    #256
    Treetopflyer
    2018 TRD off road
    Thanks. They’re quite backordered at the moment
  17. Aug 26, 2023 at 8:14 PM
    #257
    redneck pilot
    redneck pilot New Member
    DFW
    2023 4Runner TRD ORP
    Thank you! Non-KDSS. Rear coil is the Bilstein B-12, part number 36-281817
    ak1215[QUOTED] and Thatbassguy like this.
  18. Aug 26, 2023 at 9:07 PM
    #258
    Is that right eh, not surprised these days.
    In '21 I din wait crazy long for Mickey wheels, but waited months and months for Duratrac Wranglers only to get a call that I should pull the plug cuz the eta switched to unknown due to factory material and supply chain issues. I thought I was finally getting the call they had arrived. I switched to Mickey Thompson rubber instead; couple more months and it was a blessing in every way that happened. I don't actually like Goodyears in hindsight
  19. Aug 27, 2023 at 6:09 AM
    #259
    Treetopflyer
    2018 TRD off road
    How are the mickeys in rain, snow etc?
    I had a look again at yours. Mine are just the Baja boss AT. But they’re similar.
  20. Aug 27, 2023 at 3:17 PM
    #260
    Trd trail OR wheels. Came with brand new Dunlap AT20s. So years before bigger tires. But look tons better than the SR5 snowflake wheels.
    Before
    After
  21. Aug 27, 2023 at 4:02 PM
    #261
    Joeaztrd
    Joeaztrd New Member
    Joe
    2019 TRD 4RUNNER
    Currently stock
    285 70 17 2" front lift zero rubbing 17x9 wheels just photoed in some stripes there going on this week 95964.jpg
    Lc200, gomiami, SlvrSlug and 4 others like this.
  22. Aug 27, 2023 at 7:21 PM
    #262
    Bobafett
    Bobafett New Member
    Philly area
    2021 Army Green Trail Edition 4x4
    275 70/r17 General Grabber A/TX
    Matte bronze Falcon T2s
  23. Aug 27, 2023 at 11:03 PM
    #263
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Are you lifted?
  24. Aug 28, 2023 at 5:39 PM
    #264
    @Bobafett Super cool. Unique 4R my friend, ain't seen one like that - a few dollars into that eh
    Bobafett and Treetopflyer like this.
  25. Aug 28, 2023 at 6:46 PM
    #265
    Stoney Ranger
    Stoney Ranger Lockers? Pffft
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-F/R Bpr-Winch-Stickers-ALF
    The red accents are the ticket.
  26. Aug 28, 2023 at 6:49 PM
    #266
    RetiredTRDowner
    RetiredTRDowner 2022 TRD Off-road Premium
    Fain
    Bella Vista, Arkansas
    Tint windows, replaced valences (black), 3x2 READYLIFT, Black Rhino Abrams (olive green) wheels, 185/70/17 Falken Wildpeak AT3 tires, AMP Power Running Board
    Black Rhino-Abrams (drab olive green) & Falken AT3 Wildpeak 285/70/17.
    Bagman, dgrenier15, SlvrSlug and 5 others like this.
  27. Aug 28, 2023 at 6:58 PM
    #267
    That's right ya man, I believe my Baja ATZ's from '21 are discontinued old models, now known as Baja Boss All Terrains; still a hybrid A/T-M/T aggressive tread.
    True to their performance description, money in the rain and snow. Few get more rain than British Columbia. That being said Duratrac Wranglers have great rain/snow rating but they uglyyyy
  28. Aug 29, 2023 at 4:32 AM
    #268
    Guppy1301
    Silver 2019 TRD ORP
    2" 6112's in front. T13 spring and 5100's 1.5" ish in rear.
  29. Aug 29, 2023 at 4:15 PM
    #269
    Bexar237
    Bexar237 New Member
    Harleysville, PA
    2022 TRD OR
    New purchase, wheels and tires on the way. [​IMG]
    redneck pilot and TrailSpecial22 like this.
  30. Aug 31, 2023 at 11:42 AM
    #270
    Bobafett
    Bobafett New Member
    Philly area
    Thank you! Yes, just a few $. I stopped keeping track. I don’t want to admit I have a problem.
    Thanks, I thought so. Red accents carry into the interior too.
    Harringbr99 likes this.
