Show us your wheel and tire setup
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R21, Oct 3, 2021.
  1. Apr 9, 2023 at 8:37 AM
    #211
    jsinnard
    jsinnard New Member
    Jason
    2021 T4R SR5 Premium / 2016 Tacoma DCLB OR
    None
    New version of the T4R Pro wheels with 265/70/17 Nitto G2.
    I have the older version T4R Pro wheels on my Tacoma.
    hossler1788 likes this.
  2. Apr 9, 2023 at 8:39 AM
    #212
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Badass
  3. Apr 9, 2023 at 9:00 AM
    #213
    3/2 lift, 17x9 0/5.5, LT285/70R17 Load E, 1.25" black Spidertrax, high stage high clearance cut, BMC, fender mount cut n weld, hammered wheel well
    TrailSpecial22 and Harringbr99 like this.
  4. Apr 9, 2023 at 12:15 PM
    #214
    asanner
    asanner New Member
    2022 4Runner ORP
    Pro wheels with stock size Wildpeak ATs
  5. Apr 9, 2023 at 1:57 PM
    #215
    TrailSpecial22 New Member
    PA
    2” lift Bilstein 6112 w/600 lb coils front, 1.5” lift Eibach T13 coils rear, Bilstein 5100 rear shocks, 285/70/17 Falken WP AT3 on stock Trail rims, Energy Suspension front bumpstops, SSO Slimline Bumper w/ Badland Shackles
    Bagman likes this.
  6. Apr 19, 2023 at 1:08 PM
    #216
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    RRW RR7-H: 17x8.5" with a -12 offset wrapped in 285/70R17 BFG KO2's.
    Diggs9, TRDSD, MTB Chris and 7 others like this.
  7. Apr 19, 2023 at 1:24 PM
    #217
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    KMC Mesas in 17x8.5" 0 offset, wrapped in Mickey Thompson Baja Boss A/T's in 285/70R17.
    Starkhaus, Fortuner, soze and 7 others like this.
  8. Apr 19, 2023 at 2:30 PM
    #218
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Pro wheel with Wrangler Duratac LT285/70R17 - nothing bothers me more than the chrome lugs. I will be buying matte black soon.
    Fortuner, djwantke and TrailSpecial22 like this.
  9. Apr 19, 2023 at 3:12 PM
    #219
    telog
    telog GreenMachine
    TL
    CO
    ArmyGreen
    Method 701, RSG rock sliders, Dobinsons uca, Cali Raised Bumper Warn Evo Winch
    Method Wheels 701’s 17x8.5- Wild Peaks 285/70/17 and the Eibach spring lift.
    jth, TrailSpecial22 and hossler1788 like this.
  10. Apr 19, 2023 at 3:12 PM
    #220
    1bad2k
    1bad2k New Member
    Sam
    2000 SR5 4x4 4R
    SCS Ray10 17x8.5 -10 and factory sized cooper rugged trek.
  11. Apr 19, 2023 at 4:10 PM
    #221
    JP_CO
    JP_CO New Member
    Justin
    2023 Silver ORP
    Off-Road wheels with Mickey Thompson Baja Boss A/T in 265/70R17
  12. Apr 19, 2023 at 4:48 PM
    #222
  13. Apr 19, 2023 at 5:11 PM
    #223
    PA
  14. Apr 19, 2023 at 5:30 PM
    #224
    dgrenier15
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Yeah! I was going to go with the OEM lugs for those Pro wheels. Why do you recommend those just curious?
  15. Apr 19, 2023 at 6:41 PM
    #225
    My wheel required spline lugs, do yours?
  16. Apr 19, 2023 at 6:45 PM
    #226
    I got em all for $59.99 CAD at the time from shop
  17. Apr 19, 2023 at 7:00 PM
    #227
    dgrenier15
    Dayne
    Oklahoma
    2022 AG TRD ORP
    I don't think so but I may be wrong!
  18. Apr 19, 2023 at 7:01 PM
    #228
    17" pro wheels I think say "This wheel is designed for use with OE Flat-Seat lugnuts (90942-01058)". So no not yours, but mine required tapered acorn style
  19. Apr 19, 2023 at 7:08 PM
    #229
    dgrenier15
    Dayne
    Oklahoma
    2022 AG TRD ORP
    I was like am I running the wrong lugs right now?! Haha
    How you do like your Mickeys?
  20. Apr 19, 2023 at 7:16 PM
    #230
    Hahaha it looks like your good, I just recommended incompatible lugs that's all
    Dude I've really liked the Mickey Thompson's on Mickey Thompson's. Perfect
    dgrenier15 likes this.
  21. Apr 19, 2023 at 7:47 PM
    #231
    dgrenier15
    Dayne
    Oklahoma
    2022 AG TRD ORP
    I am fine with the Duratrac's right now, but I've always wanted a vehicle to try Mickey's on and the 4R is it! I have always driven trucks with standard AT's.
  22. Apr 19, 2023 at 8:03 PM
    #232
    RRW on bronze - 285/70/17 - faulken wildpeak.
    donnermel, cderr14, MTB Chris and 3 others like this.
  23. Jul 9, 2023 at 1:58 PM
    #233
    KA1OTE
    KA1OTE Just a KA1OTE drivin' a 4Runner
    Kai
    Southern Wyoming
    2021 NBM Venture SE
    Looks great! I've got the same wheels but have chrome lug nuts that I hate. I've looked into black lugs and really want to stay OEM. I found these PT076-60200-02 (and the wheel locks PT276-35200-02) but they appear to be shorter than the chrome ones I currently have so I've been afraid to pull the trigger and buy them. Which black lug nuts are you using that fit? Are they the shorter ones on the Toyota site? Or is there another part number option I've missed? Thanks for any help!
  24. Jul 9, 2023 at 3:12 PM
    #234
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    SRS flat dark bronze wheels -10 offset with Falken AT3 285/70/17 tires.
  25. Jul 10, 2023 at 2:45 AM
    #235
    redneck pilot
    redneck pilot New Member
    DFW
    2023 4Runner TRD ORP
    Wheels: Fuel Covert 5” backspacing (0 offset)
    Tires: 285/70 r17 (load range C) Nitto Ridge Grapplers
    Suspension: Bilstein 6112/600lb springs. 2.3” front
    Bilstein 1” coils 5160 rear
  26. Jul 12, 2023 at 5:55 AM
    #236
    HighSierraGuy
    HighSierraGuy New Member
    Looks great, how much lift are you at in the front/rear?
  27. Jul 12, 2023 at 2:06 PM
    #237
    conan7190
    conan7190 New Member
    2023 TRD off-road premium
    3” RC lift with UCA 285 70 17 on -18 Black Rhino Arsenal
  28. Jul 12, 2023 at 3:10 PM
    #238
    GreatDane
    GreatDane New Member
    Dane
    2017 4Runner SR5, Red
    17x9 -12 Falcon TX2 Stratos on 265/70-17 Kumho Crugen Tires.
  29. Jul 17, 2023 at 11:01 AM
    #239
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    22x9 with 275/45/22 Pirelli
  30. Jul 25, 2023 at 12:08 PM
    #240
    spensane
    spensane New Member
    Nitto Terra Grappler G2 285/70R17 Stock height TRD Pro. No trimming slight rub. Westcott Designs lift kit in the near future.
    TrailSpecial22 and JerryC like this.
