Show us your wheel and tire setup
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R21, Oct 3, 2021.
  1. Oct 22, 2021 at 1:34 PM
    #91
    Taco4R
    Taco4R New Member
    2022 TRD ORP Classic Silver Metallic
    nicest pre-2014 5th gen I've ever seen.
    Diggs9 and chan2018 like this.
  2. Oct 22, 2021 at 8:39 PM
    #92
    Cisco Kid
    Cisco Kid New Member
    Thank you very much. :thumbsup:
    4R21[OP] likes this.
  3. Oct 31, 2021 at 6:54 AM
    #93
    4R21
    4R21 [OP] New Member
    AK
    Land of Cheese
    That is one sharp looking vehicle :hattip:
  4. Oct 31, 2021 at 7:01 AM
    #94
    4R21
    AK
    Land of Cheese
    4 Weeks Later ... NO Rubbing !! Here is my setup :D
    GFX TR18 by VOXX wrapped in TOYO Open Country AT3
    Dabigono and Thatbassguy like this.
  5. Oct 31, 2021 at 1:13 PM
    #95
    NotAnotherWhite4runner
    NotAnotherWhite4runner New Member
    ‘14 SR5
    Total Chaos upper and lower control arms S2 shocks upfront. 37” toyo MT Tons of little extras
    SCS SR8’s in brushed copper with Toyo MT’s in 37x12.50x17
    Lots of rubbing. Haven’t finished attempting to make more clearance at the firewall.
  6. Oct 31, 2021 at 1:19 PM
    #96
    Aaron4x4
    Aaron4x4 Short cuts are not always the cheapest way out.
    Aaron
    Magnetic grey 2021 trd off road
    Warn hybrid winch bumper. Bfg ko2, 2/1 lift. Trd pro front skid.
    2021 trd pro wheels. 285/70r17 bfg ko2
    Dabigono and 4R21[OP] like this.
  7. Oct 31, 2021 at 1:22 PM
    #97
    Aaron4x4
    Aaron
    2021 trd pro wheels
    DrewMan, Dabigono and 4R21[OP] like this.
  8. Nov 10, 2021 at 9:33 PM
    #98
    banxwondar
    banxwondar @t4r08
    San Jose,CA
    21trdp
    -King 2.5 w/ adjusters -Westcott sliders 0 degree, DOM, no kick, plates, TIG -1.25" Spidertraxx Spacers -305/70/17 Maxxis Razr -CVC tune -20% Ceramic all around - Total Chaos UCA, cam tab, lower link skid -Black Rhino sradium 17 x 9.5 -18 -Joes side load panel -prinsu non drill rack -gobi ladder -eimkeith PCK
    37s?!
  9. Nov 10, 2021 at 9:34 PM
    #99
    banxwondar
    banxwondar @t4r08
    San Jose,CA
    21trdp
    17x9 black rhino primm -12 offset and 1.25” spidertrax. 295/70/17 Yokohama geolander g003 M/T
  10. Nov 10, 2021 at 11:26 PM
    #100
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    BAD!!! ASS!!! :headbang:
  11. Nov 11, 2021 at 6:32 AM
    #101
    4R21
    AK
    Land of Cheese
    I luv that blizzard pearl color. :hattip:
  12. Dec 29, 2021 at 5:51 PM
    #102
    ICEMAN600
    ICEMAN600 New Member
    Did you have issues with the 285s on a 2.5" lift? Im having second thoughts on buying a 285's on a 17x8.5 -12 offset. Your input must be my deciding factor. Thanks
  13. Dec 29, 2021 at 5:55 PM
    #103
    Not trying to butt in, but lift doesn't actually clear tires. Some are running 285's at stock height. With -12 offset, you'll almost certainly need some trimming, and possibly a BMC.
    michow87 and (deleted member) like this.
  14. Dec 29, 2021 at 5:59 PM
    #104
    ICEMAN600
    I'm pretty sure 285's will NOT fit in stock height.
    And yeah I want to know what the OP did to fit those 285's in his ride. I just want to make sure what issues I'm going to face when installing the wheel. It just happen that the OP have the same wheel specs that I want to put in mine. Its my first time to own a 4runner s
  15. Dec 29, 2021 at 6:57 PM
    #105
    Again, lift doesn't actually clear tires. Alignment and trimming do. The tire winds up in the same place when they're stuffed. It might not rub when you driving around town, but It might when you flex the suspension.
    You're going to need to get as much caster as possible. This might require upper control arms. You'll also need to adjust your inner fender liners. You might need to trim or adjust your mudflaps. Negative offset wheels make it more challenging to clear, as you increase the scrub radius by pushing the tires out.
    Everyone's build is a bit different. But, these are the things that are typically needed to clear 285's.
    7385, GrantA, atk411 and 1 other person like this.
  16. Dec 29, 2021 at 7:18 PM
    #106
    ICEMAN600
    Again, I'm asking if the OP what issues he had with his setup. Same truck, same lift, height same tires, same wheels. I'm asking if he had some rubbing and what did he do to fix it and make the 285's fit in his truck. I know I need to modify some things. I asked about the lift because I'm running a 3" lift and he put a 285's on a 2.5" lift.
  17. Dec 29, 2021 at 7:24 PM
    #107
    Ok. Just trying to give you some general info.
    Same truck here. 2.3" lift, 285's on -6mm wheels. I also have 295's on 0 offset wheels.
    Sorry, I was just trying to help.
    See post #26 on this thread for more information. Page 1
    7385, GrantA, Toy4X4 and 1 other person like this.
  18. Dec 29, 2021 at 10:20 PM
    #108
    Rock-N-Roll
    Rock-N-Roll TRD Amateur
    2021 T4R ORP w/ KDSS
    I haven't had any issues and I've wheeled it pretty hard already. I did get the BMC done when getting the lift installed so I can't tell you if I would have had any rubbing without it.
    ICEMAN600[QUOTED] likes this.
  19. Jan 15, 2022 at 6:16 PM
    #109
    pastorea
    pastorea New Member
    Tony
    2019 Metallic Gray SR5 Premium 4Runner
    Pedal Commander BFG KO2 265/70/17 Method 703 Matte Black 17 x 8.5 0 offset
    BFG KO2 265/70/17 on Method 703 17 x 8.5 0 offsetB509F4AB-9189-41F5-A41F-F6BF3431B558.jpg
    GDawg, justin03, kolter45 and 5 others like this.
  20. Jan 16, 2022 at 9:04 PM
    #110
    ICEMAN600
    I just bought the same wheels but on -18 offset. Did you do BMC?
    I'm hoping i don't do BMC and rock with a 285's on these
  21. Jan 16, 2022 at 9:11 PM
    #111
    I did a BMC, but mostly because I had the 4runner at a shop already to get a custom skid built. I'm not positive it was really necessary.
    You might be ok with just trimming and adjusting the inner fender liner.
  22. Jan 16, 2022 at 9:17 PM
    #112
    smatson
    smatson New Member
    Scott
    2019 TRD PRO
    Westcott lift / Mickey Thompson Baja Boss AT’s / S&B CAI/ Sprint Booster / DDS3 Max PODS / TRD Exhaust
    Westcott Lift
    285/70/17 (Load-C)
    KO2’s
    Jonjc5159, Toy4X4 and Thatbassguy like this.
  23. Jan 17, 2022 at 3:31 AM
    #113
    Bobby_Boulevard
    Bobby_Boulevard New Member
    Bobby
    22 TRD Off-Road Premium
    RRW RR7-H gunmetal
    17x8.5 -12
    Falken Wildpeak MT01
    285/70-17
    King Shocks 2.5” lift
    5DE589B8-8011-4F9A-A0E0-BC723D68425F.jpg 4B9DCAE0-7CB3-49F7-B131-C18E6CFFCF2B.jpg
  24. Jan 17, 2022 at 7:12 AM
    #114
    afret
    North Idaho
    The problem with black/dark wheels is that they are hard to see in photos unless the sunlight is hitting them like in the above post. They look great in person though.
    Bobby_Boulevard and Thatbassguy like this.
  25. Jan 17, 2022 at 7:15 AM
    #115
    ICEMAN600
    Did had some rubbing issues? You have a badass 4runner there!
  26. Jan 17, 2022 at 8:51 AM
    #116
    Kfish
    Kfish New Member
    2020 4Runner SR5
    FN FX 17in wheel, zero offset.
    Toyo Open Country AT3 265 17R70 stock size tires.
    Eibach Pro Coilover 2.0 in front, 1" lift springs and Pro truck shocks in back.
    ak1215, 5six, mrmike7189 and 7 others like this.
  27. Jan 17, 2022 at 9:17 AM
    #117
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    Side shot plz. SL or E on the Toyo's? Looks Great !
    Kfish[QUOTED] likes this.
  28. Jan 17, 2022 at 9:22 AM
    #118
    4R21
    AK
    Land of Cheese
    I like your setup but I cheaped out now on my wheels for now! Too many hobbies !
  29. Jan 17, 2022 at 9:38 AM
    #119
    MTB Chris
    MTB Chris New Member
    San Diego, Ca
    Summit Dakar -25 offset/BFG KO2 285/70/17 combo:
    michow87, Bagman, Commited and 7 others like this.
  30. Jan 17, 2022 at 9:57 AM
    #120
    Kfish
    Kfish New Member
    2020 4Runner SR5
    Thanks! They're SL load ID. I don't do heavy off road or anything, no RTT or bumpers.
