Show us your wheel and tire setup
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R21, Oct 3, 2021.
  1. Feb 26, 2024 at 8:45 PM
    #361
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    My phone background...LOL
  2. Feb 26, 2024 at 8:47 PM
    #362
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    How do they perform in rain?
  3. Feb 26, 2024 at 9:01 PM
    #363
    Yotaholic
    Olympia, WA
    Going with these after my KO2s die
    djwantke[QUOTED] likes this.
  4. Feb 26, 2024 at 9:47 PM
    #364
    Big Daddy's!
    Yotaholic[QUOTED] likes this.
  5. Mar 13, 2024 at 7:13 AM
    #365
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Moving into a new house the end of this year.
    Once I'm in I'll be looking for a new set of tires. (I know, priorities are annoying)
    I think I'll order from trailbuilt and get the
    SSW Dakar 17x9 -25 (Black)
    285/75/17 Nitto RG's
    Anyone out there with a similar setup?
    I love my RRW's but I noticed the lip (for optional beadlock mounting) catches so much mud the wheels have to be washed so the rig doesn't shake itself to pieces on the way home.
    Very annoying detail with the design of these wheels.
    You can see the lip here and imagine how it might catch excessive amounts of mud:
  6. Mar 13, 2024 at 5:27 PM
    #366
    Cisco Kid
    Cisco Kid New Member
    Just put new wheels and tires on my ‘15 Limited. 18” FN BFD wheels with 275/65/18 Milestar XT’s. The lift will go on here in a few weeks when time allows.
  7. Mar 16, 2024 at 2:17 AM
    #367
    schu3507
    schu3507 New Member
    Daniel
    2024 TRP ORP
    Tires, lights, steps and more to come
    265/70/17s discoverer AT3 XL…
  8. Mar 16, 2024 at 9:26 AM
    #368
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  9. Mar 22, 2024 at 2:45 PM
    #369
    Man I always seem to see nice jeep wheels parked at No Frills grocery store
  10. Mar 22, 2024 at 3:35 PM
    #370
    FastEddie6
    FastEddie6 New Member
    Eric
    2023 TRD Off-road
    285 70 17 Baja Boss
  11. Mar 22, 2024 at 5:33 PM
    #371
    ^sick truck
  12. Mar 25, 2024 at 10:13 PM
    #372
    maximum
    maximum New Member
    SCS SR8
    SCS Blaze 10
  13. Mar 26, 2024 at 11:23 AM
    #373
    Rizen
    Rizen New Member
    Long time lurker and finally able to contribute something. :)
    Picked up some Method 707's in black wrapped in MT Baja Boss AT in stock 265.
  14. Mar 29, 2024 at 3:25 PM
    #374
    Guys, find yourself a woman who loves you as much as I love myself some Mickey Thompsons.
    Setup:
    Mickey Thompson²
    captrussia253, SlvrSlug and RusPro17 like this.
  15. Mar 29, 2024 at 3:28 PM
    #375
    Gorgeous
    My sharing anything you folks chose to chop and cut?
  16. Mar 30, 2024 at 3:01 PM
    #376
    Latrans
    Latrans New Member
    Wichita, Kansas
    2023 4Runner SR5
    Nothing different, just the OEM TRD matte black wheels with BFG KO2s. 265/70/17 with no lift or level kit, no rubbing but my god it looks close.
  17. Mar 30, 2024 at 6:09 PM
    #377
    Texas-Gorilla
    Texas-Gorilla New Member
    2015 Toyota 4Runner SR5
    How about a photo that shows how far out the tires sit? I'm looking to improve the stance on my vehicle by having the tires stick out as close to the edge of the body as possible
  18. Apr 16, 2024 at 1:09 PM
    #378
    kuyaariel
    kuyaariel New Member
    Really like this. Thinking about these or the Atlas myself
  19. Apr 16, 2024 at 1:32 PM
    #379
    Manhattan
    Manhattan New Member
    I promised myself I'd keep this one stock... but the 20s and minivan tires had to go. I'm counting the 265/70/17s as stock (as opposed to original)... a loophole!
    Skywarner, J.A., brodeyo and 6 others like this.
  20. Apr 16, 2024 at 1:45 PM
    #380
    captrussia253
    captrussia253 New Member
    Ruslan
    SCS gen5 17x8.5 -10mm
    35x12.50r17 KO2s
    Kad2112 and Manhattan like this.
  21. May 5, 2024 at 4:55 PM
    #381
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    2013 Limited DitchMaster
    Bagman and captrussia253 like this.
  22. May 5, 2024 at 5:08 PM
    #382
    kuyaariel
    Here's mine.
    Before and after
    Greg D, Bagman and captrussia253 like this.
  23. May 5, 2024 at 5:25 PM
    #383
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    brodeyo, Greg D, steelevo and 2 others like this.
  24. May 5, 2024 at 5:40 PM
    #384
    Static03
    Static03 New Member
    Jacksonville Florida USA
    2021 Silver TRD Offroad
    Bilstein 5100's, 1" Cornfed Rear Spacer, Aluminum Skid Plate, Powerstop Z23 Pads/Rotors, 4WDKING 30" Light Bar, Nilight Ditch Lights, BBG4x4 Front Recovery Points, American Outlaw Gunslinger wheels 17x8.5 -6 Offset with Toyo Open Country AT3's
    American Outlaw Gunslinger wheels 17x8.5 -6 offset 265/70r17 Toyo Open County AT3's 1.88" lift up front, 1" spacer in the rear.
    rwturbo, Greg D, Bagman and 1 other person like this.
  25. May 5, 2024 at 7:34 PM
    #385
    TRD PANTHER
    TRD PANTHER New Member
    Southern California
    2018 Black TRD Pro
    IMG_3294.jpg IMG_3300.jpg IMG_3299.jpg MT AT Baja Boss 285/70’s on Method double black 312’s 17x8.5+0
  26. May 5, 2024 at 10:10 PM
    #386
    Boss man, you had the stock wheels powder coated, what is the color is that a matte black?
    Do you plan on keeping the stock wheels or selling them?
    TRD PANTHER likes this.
  27. May 5, 2024 at 10:15 PM
    #387
    TRD PANTHER
    Southern California
    2018 Black TRD Pro
    The double blacks were sold for a limited time only. Gloss black outer rim with black bolts and matte black centers. I sold my Pro wheels a year ago.
    Edit. I think that question was for someone else. First day on this forum.
    Bob likes this.
  28. May 6, 2024 at 4:47 AM
    #388
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I love the color. I would like to be able to disappear in the woods better.
  29. May 6, 2024 at 8:51 AM
    #389
    1SilverRunner
    Tejas
    New rubber... 34's fit nicely
  30. May 6, 2024 at 9:00 AM
    #390
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Little tight in the rear? You are like me. I want to go where I want but I'm not tearing anything up to get there. I think a lot of people here have more money than sense. I was young and did same thing. I'm still trimming mine a little for the 33s
