Show us your wheel and tire setup
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R21, Oct 3, 2021.
  1. Jan 6, 2024 at 5:53 PM
    #331
    Diggs9
    Diggs9 New Member
    Keith
    wheels. tires, lift
    what is the actual height of the BFG's on the wheels all aired up ? I have had many different sizes of the BFG's and they have never been the advertised height . (285x70x17=32.8" tall)
  2. Jan 6, 2024 at 9:52 PM
    #332
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    Yokohama Geolander X-AT, 265/70r17 load range C...
    justinfro likes this.
  3. Jan 7, 2024 at 9:40 AM
    #333
    Chillmatic
    Chillmatic New Member
    was going to put my winter package on today - nomads and blizzaks but found out stock lug nuts won’t work with them IMG_8277.png IMG_8277.png
    dgrenier15[QUOTED] likes this.
  4. Jan 7, 2024 at 10:48 AM
    #334
    Durango Dave
    Durango Dave New Member
    Durango, Colorado
    2023 4Runner Off-Road Premium w/ KDSS
    2023 ORP with OEM 17"x7.5" off-road wheels in charcoal gray that only came on the 2021-22 Trail Special Edition :bananadance:
  5. Jan 13, 2024 at 3:36 PM
    #335
    Chillmatic
    Winter mode 265 blizzaks wirh 17x8.5 et 0 nomad wheels and summer mode 17x7 TrD wheels with 285 K02sIMG_8313.jpg IMG_8115.jpg
    TrailSpecial22 and justinfro like this.
  6. Jan 13, 2024 at 4:59 PM
    #336
    2chains
    2chains New Member
    New to me T4R RWC 20 x 9 +18 245/55/20
    Going to switch out to the TRD OEM running boards when it warms up here.
    Looking for 9" wide by -25 or more o/s rim upgrade.
    Not decided on diameter yet but love this look and poke. Someone here perhaps chime in please..plate is from New York.
    Would love to see pics of Limited's with SCS 9" with -38.
    Diggs9 likes this.
  7. Jan 15, 2024 at 12:35 PM
    #337
    Diggs9
    Diggs9 New Member
    Keith
    wheels. tires, lift
    Rev 2 : 285/70/17 BFG KO2's considerably better that the 265 street tires.
  8. Jan 15, 2024 at 1:46 PM
    #338
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Absolutely !
    Slick 4R
  9. Jan 15, 2024 at 2:12 PM
    #339
    @2chains
    hah your 4R. com account name is great.
    as for your post, for what it's worth here's a photo of the poke on my 9" wheels at -32mm offset. (except 4R is Offroad trim, and 17" wheels, plus a 3/2 suspension lift)
  10. Jan 15, 2024 at 2:35 PM
    #340
    Diggs9
    Diggs9 New Member
    Keith
    wheels. tires, lift
    Thank you sir
  11. Jan 15, 2024 at 5:01 PM
    #341
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    Yokohama Geolander X-AT, 265/70's, load rating C...
    SlvrSlug and Diggs9 like this.
  12. Jan 30, 2024 at 4:39 PM
    #342
    seen this Jeep at the No Frills grocery store
    kinda like it, and the wheels
    unique
    anyone heard of the brand "Dirty Life"?
  13. Jan 31, 2024 at 11:45 AM
    #343
    chan2018
    chan2018 New Member
    2018 Barcelona Red 4Runner
    What’s the make of your rear bumper? Looks sick dude
  14. Feb 14, 2024 at 4:37 AM
    #344
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    No need to thank me for the speedy response *rolls eyes* LOL
    JCR OFFROAD/VICTORY 4x4
  15. Feb 14, 2024 at 4:52 AM
    #345
    hake0015
    hake0015 New Member
    Andy
    2019 4Runner SR5 in white
  16. Feb 14, 2024 at 5:12 AM
    #346
    broken-giver
    broken-giver BFD
    Nice ride.
    I kinda was looking forward to the polar bear family, until I scrolled down and was disappointed, but then chuckled :p
  17. Feb 14, 2024 at 5:41 AM
    #347
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    RRW 17x8.5 -12
    Nitto Ridge Grappler 285/70/17
    OME 3" lift
    (Soon to move down to a 2.5" lift to gain better articulation and improve CV angles)
  18. Feb 26, 2024 at 4:19 PM
    #348
    JSP127
    JSP127 New Member
    Just picked up a 2018 4Runner. Love it. Got some new wheels on it today.
    DX4 Rhino
    17x8.5 with -18 offset
    265/70/17 BFG Trail Terrains
    Absolutely love the stance. Just the perfect amount of poke.
    It does slightly rub only on one side in full lock reverse. Easy to remedy.
  19. Feb 26, 2024 at 4:36 PM
    #349
    TrailSpecial22 New Member
    PA
    Stock trail rims with Falken 285/70/17
    Bagman, Durango Dave and JSP127 like this.
  20. Feb 26, 2024 at 5:16 PM
    #350
    HuskerRunner
    O,NE
    2023 SR5P
    The bottom one looks like Ron Perlman :D
  21. Feb 26, 2024 at 6:10 PM
    #351
    laxman09
    laxman09 Gassy Member
    Mahoning Valley, OHIO
    New TRD pro w stock Dunlops :anonymous:
    Still waiting on center caps
    JSP127 likes this.
  22. Feb 26, 2024 at 7:51 PM
    #352
    DangitDad
    DangitDad New Member
    Ken
    2023 White 4Runner
    3"/2" Ironman lift, Method 703 wheels, K02's, Pedal Commander, more to come
    Very nice.
    Resurrecting your old post @Yotaholic, but I'm curious about how much it took to fit those. That's what I'm putting on this week. I expect to drive a hammer for a while and BMC, but was there anything else?
    Yotaholic[QUOTED] likes this.
  23. Feb 26, 2024 at 8:03 PM
    #353
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Stock wheels can take 285/75/R17s. To have no rubbing, you need BMC, mud flaps removed, and Viper cut.
  24. Feb 26, 2024 at 8:08 PM
    #354
    DangitDad
    Ken
    2023 White 4Runner
    Sweet. Thank you! I got Method 703's, 0 offset. Already removed flaps, will do my own BMC, and was planning the viper cut in the future anyway. And the 3" lift is going in first. I do wonder if I'll need to consider adjusting the top of the well or put in an extended bumpstop. We shall see. Thanks again!
    djwantke and Yotaholic[QUOTED] like this.
  25. Feb 26, 2024 at 8:15 PM
    #355
    Yotaholic
    Olympia, WA
    You absolutely need the Viper cut to be able to turn at full flex. It is cheap, removes rubbing, lets you put a foot on the boulders, and makes your truck look awesome.
    20240127_164357.jpg 20240116_165447.jpg 20240127_164144.jpg 20240224_211321.jpg
    djwantke likes this.
  26. Feb 26, 2024 at 8:39 PM
    #356
    Nice. You're on path to success if your willing to do those things. I recommend chopping your fender liner too when viper cutting. I sprayed my pink washer fluid black, and a tank skid plate (or relocation kit) are options too. I have 3' lift too, extended bump stops is something that should def be high on our list to save the strut and such.
    Good luck
    Yotaholic likes this.
  27. Feb 26, 2024 at 8:41 PM
    #357
    Ok just gunna leave a photo of my wheels and tires here, for like the 3rd time. It's ok, it's a fresh photo
    justinfro, JSP127 and Yotaholic like this.
  28. Feb 26, 2024 at 8:43 PM
    #358
    Yotaholic
    Olympia, WA
    MTs?
  29. Feb 26, 2024 at 8:44 PM
    #359
    Yes sir
    Mickey Thompson on Mickey Thompson's
    I'm the one and only !
    ThomasL and Yotaholic[QUOTED] like this.
  30. Feb 26, 2024 at 8:45 PM
    #360
    My phone background...LOL
