Show us your wheel and tire setup
Discussion in '5th Gen 4Runners (2010-2024)' started by 4R21, Oct 3, 2021.
  1. Dec 6, 2023 at 2:58 PM
    #301
    Branden967
    Branden967 New Member
    6400' in CA
    2023 TRDOR Premium
    Kings Suspension SCS 17X9 -10 OS Ridge Grapplers If its chrome....black it out.
    What side rails are those?
  2. Dec 6, 2023 at 8:26 PM
    #302
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Look like power running boards
  3. Dec 7, 2023 at 3:02 PM
    #303
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Mickey's on Mickey's
    raimieb likes this.
  4. Dec 7, 2023 at 4:51 PM
    #304
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Nice! Dimensions of the wheel?
    djwantke[QUOTED] likes this.
  5. Dec 7, 2023 at 6:47 PM
    #305
    raimieb[QUOTED] likes this.
  6. Dec 7, 2023 at 6:51 PM
    #306
    >oh tires are Mickey Thompson Baja ATZ
    LT285/70R17 10ply load E m+s
    raimieb likes this.
  7. Dec 7, 2023 at 7:05 PM
    #307
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    You think you could have gotten 285/75s under there without rub? BMC?
  8. Dec 7, 2023 at 8:03 PM
    #308
    @raimieb
    I mean without looking at your profile, if you have info, it's hard to say. Cuz I have a 3/2 suspension lift and SPC UCA's @ near 3.8⁰ castor.
    But, with that said ;
    With the setup I mentioned, I didn't rub anything, except for bottom of inner front fender during full lock which my shop took a Dremel to (very common).
    The key to my no rub was also surely 0 offset wheels.
    The key to my trajectory rubbing like crazy was adding 1.25" Spidertrax wheel spacers into the mix. I used red Loctite lmao so a BMC happened asap
  9. Dec 7, 2023 at 8:06 PM
    #309
    285/75 will rub more than 285/70 cuz 75's are true 33's, 33.8" actually
  10. Dec 8, 2023 at 1:00 AM
    #310
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Appreciate the info brother! Dose some big ol tires!
  11. Dec 8, 2023 at 1:03 AM
    #311
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Looks like a clean BMC. Nicely done. I have a similar setup but am too lazy to type it all into my profile. So you kept the spacers or took them off with the new MT wheels?
  12. Dec 8, 2023 at 4:51 AM
    #312
    KYFHO
    KYFHO Generic Scumbag
    UT
    2017 SR5P with some stuff
    LT285/70R17 Toyo AT3 on 17x8.5 Fuel Anzas with -6 offset. No BMC. Very minor rub when fully stuffed and the wheels turned left
  13. Dec 8, 2023 at 6:41 AM
    #313
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    New setup(well atleast tires)
    285 70 17 goodyear territory mt(c rated)
    17x8.5 rrw rr5v -12
    Nick4RNR, djwantke and dgrenier15 like this.
  14. Dec 8, 2023 at 9:12 AM
    #314
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    LCJ77, TxTRD, djwantke and 2 others like this.
  15. Dec 10, 2023 at 5:11 PM
    #315
    thanks bud, ya BMC was so good the dude was a pro. at the same time I had him mod for 35's if you look close in that photo;
    fender liner trim between body mount and fender mount + wheel well hammering, fender mount chop n weld, black spray paint everything. even my valance caps r removed now, further inner fender chop behind wheel in November. I want 1" body lift last
    *No, I didn't remove the spacers, I accommodated them and then some. I was implying the red Loctite was permanent and I couldn't turn back lol
  16. Dec 10, 2023 at 6:35 PM
    #316
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Ahh. Now I get the locktite joke haha. Took me a bit there!! Good stuff overall!
  17. Dec 10, 2023 at 6:45 PM
    #317
    :D lol ya I jumped the gun
    thanks buddy
    the wife came around too eventually, cost me 300 extra $$
  18. Dec 10, 2023 at 10:33 PM
    #318
  19. Dec 28, 2023 at 1:00 PM
    #319
    dgrenier15
    dgrenier15 New Member
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Anyone have any experience or pictures with Nomad Wheels? I noticed on their configurator menu if you have stock they have wheel available for 4Runners but when you switch to lifted (3") they go away. I love the look of them, but couldn't find any 4Runners that run them (even on their Instagram).
  20. Dec 28, 2023 at 1:09 PM
    #320
    Chillmatic
    Chillmatic New Member
    I have a set of nomad wheels mounted on some 265 blizzaks i plan to run eventually this winter just havent put them on yet. I am debating even putting them on because i like my 285 KO2's and TRD wheels so much.
  21. Dec 28, 2023 at 1:41 PM
    #321
    dgrenier15
    Dayne
    Oklahoma
    2022 AG TRD ORP
    Dang so no pictures?! HAHA I have debated the same thing. In my mind I would rather spend the money on some other mods, but I like the classic look of the nomads. I love them on the old Land Cruisers - just haven't seen them on 4Rs.
  22. Dec 28, 2023 at 1:50 PM
    #322
    Chillmatic
    I only have pictures of the wheels and tires off the car, if i end up putting them on ill post a picture. I normally wouldnt run winter tires/wheels with my 4R but I got a deal that i couldnt refuse on these.
    dgrenier15[QUOTED] likes this.
  23. Dec 28, 2023 at 2:06 PM
    #323
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    Voss “Pro” in Bronze
    17x8.5 zéro os
    SL 285/70-17
    JFarm, Nick4RNR, Harringbr99 and 2 others like this.
  24. Dec 28, 2023 at 2:07 PM
    #324
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    TRD Pro knock offs. Love them. Flat black and wider than the OEM ones. I'm not willing to spend a lot on wheels just to beat the hell out of them on rocks. Can easily hit these with flat black paint lol.
    Tires are Cooper Rugged Trek. My new favorite tires. I've had MTRs, KM2s and Duratecs on my Jeep and for an all terrain these are everybit as grippy in wet muddy conditions as those. Ride fantastic on the highways!Screenshot_20231228_145437_Photos_1703801026973.jpg Screenshot_20231228_145518_Photos_1703800926086_1703800969886.jpg
  25. Dec 28, 2023 at 3:30 PM
    #325
    TxTRD
    TxTRD New Member
    Tx
    22 TRD ORP
    Looks great. Do those center caps fit OEM TRD wheels?
  26. Dec 28, 2023 at 3:35 PM
    #326
    LANHLOY
    LANHLOY New Member
    Sal
    '23 ORP Lunar Rock
    Hey, I love the wheel setup. I have the same year/spec 4runner. Are the wheels a direct fit? Plug and play? I'm only asking because I've been seeing mixed reviews about installing trd wheels on a orp. You need to trim fender, etcs to prevent rubbing. Mines is stock, and I plan to keep it like that for while. Thanks
  27. Dec 28, 2023 at 3:36 PM
    #327
    RusPro17
    Don
    Pa.
    Thank you. I don’t think they will fit.
  28. Dec 28, 2023 at 7:23 PM
    #328
    wow super nice
  29. Dec 29, 2023 at 4:31 AM
    #329
    Higgbra73
    Brad
    Chicago
    16' SR5 Premium 4WD
    Thanks…!! did the Matte black on my Tacoma… wanted the Bronze this go around.
  30. Jan 1, 2024 at 12:17 PM
    #330
    Back at my summer watering hole.
    4 Season All Weather MICKEY THOMPSONS, no season changeover needed.
    Wide stance look achieved w/ 9" wheels & Spidertrax.
    Polar bear swimming family at the lake this morning.
    broken-giver, raimieb and justinfro like this.
