Shock’ing Discovery
Discussion in '5th Gen 4Runners (2010-2024)' started by Slopemaster, Jul 2, 2022.
  1. Jul 5, 2022 at 2:23 PM
    Will watch the video later. However my current Bilstien5100 flex pretty good in the rear. May be when I remove them will see the difference stock shocks vs Bilstien5100 (i still have old shocks of my ORP).
  2. Jul 5, 2022 at 6:35 PM
    Sure!
    It’s interesting how many things start to interact with each other the higher you go. A 3/2 lift is really on the high end. Seems like a safer and a more useful bet is a 2/1 lift. And when I say lift, I mean suspension lift (not spacer).
    I like that he said the shock also functions as the limiting strap for full extension under normal circumstances. But you just need to make sure the shock is not reaching full extension on a frequent basis under your normal driving situations.
  3. Jul 6, 2022 at 1:30 PM
    I’ve been doing some research on limiting straps for suspensions. Apparently it’s common on extreme off road vehicles like Razors. If I can figure out some good anchor points on the front, I may be able to use straps to restrict the excessive droop.
    For the back, I need to find some shocks that have about 3” more travel than stock.
    https://www.4wheelparts.com/v/toyota-4runner/suspension/limiting-strap/_/N-1snq4Zcm7oi
  4. Jul 6, 2022 at 1:48 PM
    Mtbpsych
    Mtbpsych New Member
    Those are only needed for long/extended travel setups.
    the UCA will limit how much the suspension drops.
    https://www.tacomaworld.com/threads/limiting-straps-on-basic-lift-set-up-lets-discuss.451962/
  5. Jul 6, 2022 at 2:09 PM
    Normally true, but thanks to my spacer lift, the UCA is ramming into the coil springs and also binding the upper ball joints. See my earlier posts.
    It’s a getto fix, but it’s a last ditch effort to keep the 285’s.
    https://www.drivingline.com/articles/how-to-protect-your-ifs-with-limit-straps/
    Mtbpsych[QUOTED] likes this.
  6. Jul 6, 2022 at 3:35 PM
    After searching I’ve discovered that quite a few Tacoma guys and a few 4R owners are utilizing straps to keep their shocks from topping out.
  7. Jul 6, 2022 at 3:45 PM
    Get rid of the 3" spacers. 2"front/1" rear is still plenty to run 285s. You could get 5100s and do it "right", or even just go with shorter spacers.
    3" of lift is just too much for these unless done properly, and spacers are not properly.
  8. Jul 6, 2022 at 3:50 PM
    From what I've seen rear shocks not been long enough is the problem. One can run full 1.5in spacer on top of the stock suspension to give 3in lift front and use 2in spacer in back with Bilstien5100 replacing just rear shocks. I could be wrong. Suspension experts can correct me if im wrong.
  9. Jul 6, 2022 at 3:58 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Umm… I am running 285/75/17 with a minor lift. Just do a little trimming and remove the 3” spacers. If you have a little bit of money saved up get an aftermarket suspension like Ironman foam cell pro (What I have) and call it a day. Otherwise if money is a stopping factor just remove the lift and trim a bit and you should be fine.
    Trail Runnah likes this.
  10. Jul 6, 2022 at 4:01 PM
    He's saying his (front) UCA is banging on the shock body.
    You are correct though, too short rear shocks are an issue as well.
    Personally I would strongly suggest spending the money to do it the correct way. The proper length 5100s are fairly inexpensive.
    kmeeg[QUOTED] likes this.
  11. Jul 6, 2022 at 7:31 PM
    Good points, so do the 5100’s come in different lengths?
    would I have to replace the front and rear springs as well?
    Thanks
  12. Jul 6, 2022 at 7:39 PM
    Honestly, I wouldn’t mind having less lift and being able to keep the 285’s. I think the 3/2 lift is a little much.
  13. Jul 6, 2022 at 11:04 PM
    We have three full service 4x4 custom shops in my area, so I’m gonna go talk to them and see what my options are. :)
    SlvrSlug, GrantA and McSpazatron like this.
  14. Jul 7, 2022 at 5:28 AM
    This is why I lifted my front end 1.6" using Eibach adjustable shocks and my stock coils. The angles aren't extreme, I can fit 285's no problem, and the ride is fantastic. $140 per shock. Done.
    You could also lift the front 0.85" with these shocks if you choose (same height as the Pro).
  15. Jul 7, 2022 at 3:39 PM
    GrantA likes this.
  16. Jul 8, 2022 at 10:02 AM
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    Bro, don’t do that to your truck. 1) Putting limiting straps to restrict it will keep the UCA off the spring, but you are going to feel that in your ride quality. Spacers lift the truck essentially via using up existing downtravel without increasing uptravel, already reducing your overall travel. You want to put a strap to limit it further? Not the best idea unless you never drive off road. 2) Rear downtravel is restricted by shocks, brake lines, control arms…if you just add the extended shocks without addressing all of those other things there will be problems off road. You will find yourself adding limiting straps to keep your coils from tipping out when you flex it hard and that is the least of the problems you may encounter.
  17. Jul 8, 2022 at 10:23 AM
    Yes, you are correct,
    I am currently researching my options for an appropriate shock coil setup. My plan is to completely remove the stock shocks and spacers and start from scratch.
    I would like to reduce the lift as much as possible while keeping the 285’s. Currently is a 3/2 and I don’t think I need that much. Dealership did the front fender liner nip and tuck and I was able to keep the mud flaps which I prefer.
    I’m seriously considering the Bilstein 6112/5160 setup. This would fit my budget. With coil springs as close to stock as possible. I have no intention of adding additional weight to the vehicle in the form of mods.
    Thank you for the input.
  18. Jul 8, 2022 at 10:29 AM
    This sounds like a plan.
    2" front, 1" rear should be plenty. That's my intention for mine.
    2Toys and nimby like this.
  19. Jul 8, 2022 at 10:38 AM
    #49
    Thats what I was thinking too.
    I have had no rubbing issues with my current 3/2 spacer lift. The 5100’s seem to be the standard go to shock but what attracted me to the 6112 was the 2.5” shock body. It’s a bit more money but seems like good bang for buck.
    Most online reviews at this price point seem to favor the 6112.
  20. Jul 8, 2022 at 10:54 AM
    #50
    Yeah, everyone has good things to say about them. Check out Shock Surplus and Alldogs Off-road on YouTube, they've done quite a few videos of them.
    The only issue seems to be finding them, they never seem to be in stock anywhere.
    I was initially set on the 6112/5160 combo myself, but since I'm on the fence about adding a winch, I'm thinking I might go with the Einach Pro 2.0. that gives you an adjustable front coilover, which you can adjust while it's still on the vehicle.
    The 2.5-in body of the Bilstein is an attractive feature, but from what I understand that is really only a benefit if you do a lot of high speed driving on rough terrain. Even the shock surplus guys said that they didn't notice a difference between the 6112 and the 5100 on the street, it was only off-road they noticed a difference.
    BionicRandy likes this.
  21. Jul 8, 2022 at 11:16 AM
    #51
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    You will be a lot happier with the truck with the new suspension. I bought my truck used with a dealer installed 3/2 spacer lift and replaced it with OME springs and 5100s. The ride difference is indescribable - completely different truck. It stayed the same height & 285/65/18s don’t rub, but I have done some trimming. 2/1 should definitely be enough as long as you don’t catch the mod bug and start adding a lot of weight. Hehe They can get heavy fast.
    Slopemaster[OP] likes this.
  22. Jul 8, 2022 at 11:29 AM
    #52
    Which OME springs did you go with - also, front and rear both with new springs? And, what was your ultimate lift amount?
    BionicRandy[QUOTED] likes this.
  23. Jul 8, 2022 at 11:44 AM
    #53
    I off road at least every couple of months, sometimes several times a month if the wind is good for slope flying. The trails in my area are brutal! with large imbedded lava rocks. Currently I have to go really slow or the back shocks clunk hard.
    Also, I have a couple of destinations on my bucket list that would require driving long distance on corrugated dirt roads.
    So that’s why I’m leaning towards the 6112 setup.
  24. Jul 8, 2022 at 12:26 PM
    #54
    GrantA
    North Carolina
    All the more reason for those Ironman. Just saying… ;)
  25. Jul 8, 2022 at 1:05 PM
    #55
    Yes, too many choices!
    I can tell from previous threads that many people have preceded me with these important decisions.
    My favorite thing about the Iron man shocks are those Gravedigger green coil springs. So cool!
    4runGirl88 and GrantA[QUOTED] like this.
  26. Jul 8, 2022 at 2:29 PM
    #56
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I agree the green springs got my attention, might look cool under the lunar rock. I’m just not ready yet. Thank you for sharing this info, as I continue to learn for when I am.
  27. Jul 8, 2022 at 4:37 PM
    #57
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    It's interesting...
    Eibach pro truck struts/shocks
    FRONT
    -Extended 22.39" -16.55"compressed
    Rear
    -extended 21.45" - 13.25 "compressed
  28. Jul 8, 2022 at 6:40 PM
    #58
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    I got the OME/Bilstein Stage 1 kit and Dobinson’s UCAs. Front springs are 887 (stiffest) and rear are 898 (2nd stiffest). My truck has too much rake empty, so I just got a set of daily driver rear springs to level it out.(Eibach 2” @ +150#) Easy enough to swap out before a trip. I no longer have the measurements I took, but initially the truck was 1/2” lower front left than front right and 1/4” lower on rear left than rear right with the spacer lift. The 5100s on the lowest setting and those springs leveled the left with the right. I have since added skids and a hidden winch and the front has come down probably another 3/4”-1” and the rear has not budged. lol Looks like a fucking stinkbug if I take out my tools and kitchen.
    4runGirl88 and Slopemaster[OP] like this.
  29. Jul 8, 2022 at 6:44 PM
    #59
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    Don’t buy based on color. You can paint any springs any color you want. o_O
  30. Jul 9, 2022 at 3:35 AM
    #60
    Spare Parts
    Southern Maine
    22 LR ORP
    True, but they look pretty cool. After thinking about it longer, the green wouldn’t work, it needs to be red or something.
    oh, and it’s always nice if I don’t have to paint.
